Italian Motors - LB
MRP - SS
SCCA Enterprises - FB
Racing Sims
Goto page Previous  1, 2
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Non-Karting Motorsports Discussion
PostPosted: Fri Feb 12, 2010 7:22 am    Post subject: Reply with quote
Quote:
My first impression is that using a smooth technique with the wheel does not provide the speed that a herkie jerkie technique does with the wheel. The same with the brakes.
It all depends on the car. You still need to be super smooth in all cars but some of them require you to be more aggressive with steering input on entry.
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
Paul Hutt
PostPosted: Fri Feb 12, 2010 4:03 pm    Post subject: Reply with quote
I am glad to know that someone agrees with me. I made the same comment on the IRacing forum and was beat up real bad.
Race Grandpa
Panic Motorsports West
John Denman
PostPosted: Sat Feb 13, 2010 8:25 am    Post subject: Reply with quote
Smooth steering inputs work best under most but not all conditions. Take an oval like Indy; gotta be glass-smooth. Take a twisty bumpy road course like Monaco; gotta be twitchy with the steering wheel.
Some tracks work front tires harder, some work rear tires harder. The harder they work the more they heat. You can't always use tire pressure to balance out the heat. On tracks that work the rear tires a twitchy steering style generally works better, and vice versa.
Dario Franchetti is a master of tire (and fuel) management. Watch him on a road course; he favors super smooth and mostly runs in "conservation mode" but when he puts on the charge he makes it evident and is anything but silky smooth. Mario was like that in his younger days but seemed to have lost that edge about the time he retired from F1.
I can understand the perceptions from iRacers, the tire physics feel a bit inconsistent to real tire slip angle physics making them harder to drive at the edge - kind of like the reactions to inputs are a bit retarded or delayed.
John Denman
Producer for RTMP
http://www.kartweb.com
VINCE SCHNEIDER
PostPosted: Mon Feb 15, 2010 8:38 pm    Post subject: Racing Sims Reply with quote
I have the Xbox EA sports Formula One software, which took me almost 4 years to find a mint one to purchase. Also the Papryus Indy car racing is not half bad, just the graphics are old, but car setup, etc. is very adjustable.
John Denman
PostPosted: Mon Feb 15, 2010 9:30 pm    Post subject: Reply with quote
Any Indycar simracers? We may have a spots open for the 2010 season. Just got done testing Sao Paulo. Talk about a drag strip connected with tight turns. Cool track.
John Denman
Producer for RTMP
Dan Morera
PostPosted: Tue Feb 16, 2010 11:52 am    Post subject: Re: Racing Sims Reply with quote
How many people here are simracers? iracing
What platform do you run? computer with 32" LCD and G25
What cars do you run? Mostly Skip Barber and Trucks. Would like to race the Corvette but can't find easy to drive set ups for it.
View user's profile Send private message AIM Address MSN Messenger
John Denman
PostPosted: Tue Feb 16, 2010 5:14 pm    Post subject: Reply with quote
Dan, its nice having a 32" screen isn't it?
As for setups I found the same principals that worked for real cars work for the better sims like iRacing and rFactor. There is a Tune To Win Tutorial you might want to take a look at if you're interested in learning how to tune that Corvette.
Tire pressures and temperatures are a major factor to get right and that it takes a few laps to reach temps.
One thing that was missing when I was running iRacing was the MoTec data system.
John Denman
Producer for RTMP
Dan Morera
PostPosted: Thu Feb 18, 2010 9:33 am    Post subject: Reply with quote
Oh yes it's great, couldn't go back to a 22" or something like that, specially at 1920x1800.
Thanks for the link got to read that, that corvette is way loose, got to be VERY gentle with the throttle
thanks
Dan
Jeff Field
PostPosted: Thu Feb 18, 2010 10:35 am    Post subject: Reply with quote
thanks
Dan
My vette setups have quite a bit of rear toe in to help launching off the exits.
Have you been going in the iracing forums looking for setups that have been shared? I usually go there for a starting point.
It's just kart racing.
http://shifter102.blogspot.com/
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Non-Karting Motorsports Discussion All times are GMT - 8 Hours
Page 2 of 2
DB time: 0.919862 (65.78%), total time:1.398361, queries:38
