SCCA Enterprises - FB
world formula service intervals ?
George Vorrilas
PostPosted: Fri Jan 29, 2010 6:39 pm    Post subject: world formula service intervals ? Reply with quote
what is the general consensus as to time ( actual estimate of hours) between rebuilds on the Briggs World Formula and what are the main differences between the different generation engines.? I understand that regular oil changes and routine valve adjustments should be done but looking for a good estimate of how many race hours are safe to run before dis-assembly and rebuild.
Last edited by George Vorrilas on Sat Jan 30, 2010 5:25 am, edited 1 time in total
Todd P Weaver
PostPosted: Fri Jan 29, 2010 7:11 pm    Post subject: Reply with quote
I've heard of people running them for 2 seasons between rebuilds. That might be pushing it.
Figure once a year provided you change your oil often and check your valve lash a few times each season.
Main differences are the updated flywheel coil. it's now a digital ignition and the flywheel is aluminum as opposed to cast iron. They're a nice stock, ready to race package.
tw51
Margay 4.7
Turner World Formula SS
#51 Team Axles of Evil
Bernie Lacotta
PostPosted: Fri Jan 29, 2010 7:33 pm    Post subject: Re: world formula service intervals ? Reply with quote
George Vorrilas wrote:
what is the general consensus as to time between rebuilds on the Briggs World Formula and what are the main differences between the different generation engines.?
I know this may be unfamiliar to many but if you get a leakdown gauge ( make sure it has 10 mm spark plug hole hardware ) it can help you keep track of your engine's condition , easily telling you the condition of your valves and piston rings. If you don't know much about those things make friends with someone that does and owns a leakdown gauge !!
I breathe ,therefore,I race
DB time: 1.391143 (89.7%), total time:1.550807, queries:38
