MIR Racewear - LB
Where to buy real CR125 clutch cables
Goto page 1, 2  Next
Mike Goebel
PostPosted: Thu Jan 28, 2010 8:02 am    Post subject: Where to buy real CR125 clutch cables Reply with quote
I've got the motion pro clutch cable with the curved piece of steel sheathing on the end that goes into the cases. Where can I get just the inner braided cable that has the proper end on it that goes into the pull mechanism on the engine side. I’m not sure if the standard CR125 cable is long enough to work on a shifter kart. I had some piece of crap cable sent to me by a shop that has a giant cylinder on the end that won't even fit into the pull mechanism.
Mike G.
Closet KZ Lover!!!
mfg Technology Centre
Larry Andrews
PostPosted: Thu Jan 28, 2010 9:21 am    Post subject: Re: Where to buy real CR125 clutch cables Reply with quote
Nope, not long enough by at least a foot.
You can try going to a bicycle shop and seeing what cables they have, but it's unlikely that they'll have a cable thick enough.
You can call motion-pro and see if they'll sell you just the cable without the housing. Should be about $5 before shipping if they'll do it.
Jim Derrig
PostPosted: Thu Jan 28, 2010 10:05 am    Post subject: Re: Where to buy real CR125 clutch cables Reply with quote
Mike G.
Did you try fixin' it with a hammer?
Mike Goebel
PostPosted: Thu Jan 28, 2010 10:10 am    Post subject: Reply with quote
Damn I completely forgot about the hammer!
Mike G.
Closet KZ Lover!!!
Chris Deckard
PostPosted: Thu Jan 28, 2010 10:39 am    Post subject: Reply with quote
Brian Fisher 703 474 7122
Mike Goebel
PostPosted: Thu Jan 28, 2010 11:57 am    Post subject: Reply with quote
Thanks that might be good for the long run but I need the cable today Shocked
I guess I'll just need to bust out the hammer.
Mike G.
Closet KZ Lover!!!
joseph hollinger
PostPosted: Thu Jan 28, 2010 12:05 pm    Post subject: Reply with quote
Mike G.
Just carve down the ball on the end of the bad cable. Should work for today at least.
Mike Goebel
PostPosted: Thu Jan 28, 2010 12:08 pm    Post subject: Reply with quote
I started doing that last night but then thought I could get the correct cable easily. Then I forgot that nothing is easy.
Mike G.
Closet KZ Lover!!!
James Frank
PostPosted: Thu Jan 28, 2010 1:28 pm    Post subject: Reply with quote
Try www.worldofpowersports.com or www.bikebandit.com
They have OEM parts for just about every year for all bikes. I use the OEM YZ-125 clutch cable and it works fine with the Trackmagic clutch handle.
James Frank
Baker's Creek Kart Club
2009, 2007 & 2004 125cc ShifterKart Champion
Trackmagic FTR/YZ-125
JT Miles
PostPosted: Thu Jan 28, 2010 6:00 pm    Post subject: Reply with quote
www.fastech-racing.com
Miles Racing
2nd Place 2012 Kid Kart Nationals
Energy Kid Kart/ CKS C51
Birel Kid Kart/ LAD C51 #7C
Intrepid/MY09 Comet Leopard #722
Emmick/K78 and TT25
jack lachut
PostPosted: Thu Jan 28, 2010 7:10 pm    Post subject: clutch cable Reply with quote
mike, try msquared karting in utah. they sell for about $10.
1-800-866-4631
Mike Goebel
PostPosted: Thu Jan 28, 2010 7:54 pm    Post subject: Re: clutch cable Reply with quote
1-800-866-4631
You are the MAN!
Mike G.
Closet KZ Lover!!!
Jeff Stamper
PostPosted: Fri Jan 29, 2010 6:57 am    Post subject: Reply with quote
http://www.fastech-racing.com/product.php?productid=1180&cat=343&page=1
Racing is a State of Mind ! ... A very nice state to be in !
Mike Goebel
PostPosted: Fri Jan 29, 2010 7:39 am    Post subject: Re: clutch cable Reply with quote
1-800-866-4631
You know what, I think those are not the correct ones, damn.
Mike G.
Closet KZ Lover!!!
Stu Hayner
PostPosted: Fri Jan 29, 2010 11:42 am    Post subject: Reply with quote
Mike,
I just had a custom clutch cable made at MOTOWEST for $35 complete (cover/adjuster/cable/ends). The owner (Steve Marolda) understands what we need for shifter karts and made the nicest cable I have used.
He explained that using certain types of outer covers covering the cable makes the cable slide easier and last longer. I gave him the measurements and my old cable and he had it finished in a day. He said with more orders, he can have the parts in stock and pre-make some up. I am sure there are many different ways to configure the cable up to the clutch handle, but the length, the adjuster and the end that goes into the engine would be the same. Guys with Yamahas and Kawasaki engines can order them, also.
He can do custom throttle cables, as well (less money).
MOTOWEST
2358 E Orangethorpe
Anahiem, Ca.
714 526-3234 - Steve Marolda
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.063007000000001 (36.19%), total time:0.174104, queries:38
