Top Kart USA - SS
spark plug for a WF
Patrick Hubbell
PostPosted: Wed Dec 30, 2009 10:56 am    Post subject: spark plug for a WF Reply with quote
what brand and plug number do you use in a briggs world formula engine?
Patrick Hubbell
michael schorn
PostPosted: Wed Dec 30, 2009 12:53 pm    Post subject: Reply with quote
Patrick
Stock Champion RG4HC copper core. $3-5 each
I have been using the NGK CR9EIX or CR10EIX Irridium you will need to buy the terminal caps for these. $7-10 each
Serveral guys are using the ND 24ESR, ND27ESR or ND31ESR I believe you need to buy the terminal cap for these also. $5-10 each
All of the plugs work well and last a good long time since the switch to the PVL ignition.
Almost all of the manufactures now make 10mm copper core plugs too which I have used some of the Autolite 4302 and 4303 you will need to buy the terminal caps for these also. $2-4 each
Hope this helps
Mike
OK everyone It's my opinion only, no one elses, and does not reflect any organization or office that I belong to or hold. Thank you for your support.
Portland Karting Association
Host 2013 IKF 4 Cycle Sprint
& Road Race Grand Nationals
Steve Nieto
PostPosted: Wed Dec 30, 2009 5:45 pm    Post subject: Reply with quote
NGK CR7, 8 or 9 depending on the the air temp and fuel. $ 2.99 at the Honda MC shop.
DB time: 0.130813 (41.77%), total time:0.313175, queries:38
