KartSport North America - LB
Top Kart USA - SS
Franklin / Merlin USA - FB
Tony Seat chart
Goto page 1, 2  Next
James Jordan
PostPosted: Wed Dec 23, 2009 6:53 pm    Post subject: Tony Seat chart Reply with quote
Does anyone have a Seat chart fot a Tony Kart?
or have a link?
jamesjordan@hotmail.com
jeff grose
PostPosted: Wed Dec 23, 2009 7:05 pm    Post subject: Reply with quote
http://orlandokartcenter.com/
Give this a shot. It's Andre Martins place here in Orlando Fla. Andre is Mr. Tonykart. He can give you the best info, e-mail them or give them a call.
Hope this helps you
And Merry Christmas to you and yours Very Happy
jlgracing
#31 Gillard/PDBAmerica
IAME Leopards by P1 Engines
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Brian Seward
PostPosted: Wed Dec 23, 2009 7:23 pm    Post subject: Reply with quote
James,
Check you e-mail. I sent you a chart.
James Jordan
PostPosted: Wed Dec 23, 2009 7:40 pm    Post subject: Seat Chart Reply with quote
I'm trying to figure which seat suits my son. (Size 1, 2 , 3 , 4) what do the numbers mean in real life?
James
Dillon Felber
PostPosted: Wed Dec 23, 2009 8:44 pm    Post subject: Reply with quote
Just get him a size 1. I'm taller than Marc and about 125-130 lbs and the size 2 is slightly large for me...but make sure he sits in the seat before you buy it because if it happens to be too tight, then he will regret getting the seat
edit: size 1 is the smallest otk seat
size 2 is close to the same size as my tillet 1/4 pad medium large
Dillon Felber
Kosmic Mercury
HPV 4
Jonathan Knevels
PostPosted: Mon Jan 18, 2010 4:16 pm    Post subject: Reply with quote
can anyone tell me what the ideal seat placement is when i have a evr front brakes, mojo d2 ? I am 1m81 ( i think its 5,9 ft ) and weigh 74 kg ( 163 lbs )
Many thanks Wink
Ryon Beachner
Advertiser
Advertiser
PostPosted: Wed Jan 20, 2010 6:48 pm    Post subject: Reply with quote
Many thanks Wink
61cm Front Rail to left side seat lip.
61.5cm Front Rail to right side seat lip.
19 - 21cm Top of axle to top of seat lip. (Center)
Also, with the OTK Seats, make sure you sit in more than one of the same size, typically because the seats are stacked in shipping and storage you get different sizes within the range. For instance, I use a size 1, however sometimes certain size 1's will be too small or too big for me.
Evan Simms
PostPosted: Thu Jan 21, 2010 9:15 am    Post subject: Reply with quote
Many thanks Wink
61cm Front Rail to right side seat lip.
61.5cm Front Rail to left side seat lip.
So the seat is actually staggered to the left slightly? It's seems 99.9% of seat specs have the seat staggered to the right. Why is it the reverse on the Tony?
I have a Kosmic so I'd like to know.
Jonathan Knevels
PostPosted: Thu Jan 21, 2010 10:42 am    Post subject: Reply with quote
Many thanks Wink
No, its or little bit left or straight, never to the right !!
Ryon Beachner
Advertiser
Advertiser
PostPosted: Thu Jan 21, 2010 1:00 pm    Post subject: Reply with quote
Many thanks Wink
Jonathon is correct, its easy to confuse the two when you're not looking at the kart. I'll edit that to correct it.
Elbert Thompson
PostPosted: Thu Jan 21, 2010 1:39 pm    Post subject: Reply with quote
Tillett T8 Xl Seat position
Height 5"11
Weight: 249 (& Sexy)
63cm Front Rail to right side seat lip.
63.5.5cm Front Rail to left side seat lip.
21 - 23.5cm- Top of axle to top of seat lip. (Center) I couldn't get the seat any closer to 21cm. It feels better to me at 23.5.
Evan Simms
PostPosted: Fri Jan 22, 2010 1:34 pm    Post subject: Reply with quote
Ryon,
Easier if you say "driver right" or "driver left"...Smile
So the farther distance is driver right correct?
Kyle Kuntze
PostPosted: Fri Jan 22, 2010 1:41 pm    Post subject: Reply with quote
Correct.
ART Grand Prix America Team Manager
artgpamerica@gmail.com
gregg boyce
PostPosted: Fri Jan 22, 2010 5:27 pm    Post subject: Reply with quote
http://www.j3competition.com/downloads/technical/J3_Seat_Setup_Form_v2.pdf
Go here for Koz or Tony.
Jonathan Knevels
PostPosted: Mon Jan 25, 2010 3:56 pm    Post subject: Reply with quote
when i place the otk seat at 61 and 61.5 cm , same hight as chassis, and the flat part of the seat horizontal, the distance i have between axle and seet is 22 cm . Can i leave the front and lower the rear of the seat until 20.5-21 cm ? or do i lower the seat entirely ? i am 1m81
thx
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.066757 (36.76%), total time:0.18159, queries:38
