2D2W - LB
Russell Karting - SS
Franklin / Merlin USA - FB
Brakes
Goto page Previous  1, 2
Gene Heagney
PostPosted: Fri Nov 30, 2012 5:26 pm    Post subject: Reply with quote
Robbie,
The Righetti Ridolfi master cylinders (sold at Fastech and I'm sure other sites) will bolt right up to the CR32 chassis. The bias adjuster and everything bolts right back up with no real modification necessary. The only thing I noticed is that you might have to put a washer between the inner master cylinder and the bracket because of the way the dust cover is on the master cylinder. And you will have to use a different spacer between the two mc's, which are both easy problems to solve.
Page 2 of 2
DB time: 0.144982 (52.8%), total time:0.274577, queries:38
