MaxSpeed - LB
Russell Karting - SS
Animal carb adjustments
Richard Robuck
PostPosted: Wed Sep 09, 2009 12:01 pm    Post subject: Animal carb adjustments Reply with quote
Can someone please give me a starting point on the carbureator adjustments on an Animal. I race roadcourses in the midwest and we run a spec. fuel. I'm just not sure where I should have them set.
Also, the breather or drain on the bottom of my carb is constantly dripping fuel after I have the engine running. Why is that happening?
PostPosted: Wed Sep 09, 2009 2:58 pm    Post subject: Reply with quote
Second problem first, you either need to set the float level, replace the inlet needle, or seat.
Then you can check out:
http://www.briggsracing.com/racing_engines/animal/animal_carb-tuning.pdf
That'll get you in the ballpark for your carb settings, once you get close (make sure you're not trying to run methanol jets with gas or vise/versa) you can ask more questions here or on Bob's 4 cycle.
Good luck,
Heartbeat Power, LLC.
DB time: 0.172158 (49.38%), total time:0.348642, queries:38
