MIR Racewear - LB
New to karting, LO206 Briggs Good Idea?
Josh Kestner
PostPosted: Sun Aug 23, 2009 6:35 pm    Post subject: New to karting, LO206 Briggs Good Idea? Reply with quote
I'm new to karting down in Orlando, FL and looking to purchase my first kart. I spoke with the a gentlemen up at 103rd in Jacksonville about weather or not there would be any competition for me with this setup. He said that the stock animal class was one of their most competitive and I asked him if I could run my LO206 with them, he said "I don't see why not"
By my understanding, the 206 is the same as a stock animal correct? or am I wrong? If not, would I still be competitive with it?
Picking up a nice used 2stroke chassis and putting on a 206 onto it seems to be a rather in-expensive endeavor <$1800 with a decent chassis. <$1500 with a lesser chassis.
What do you guys think? I love feedback, positive or negatie
Josh
Josh Kestner
PostPosted: Sun Aug 23, 2009 7:20 pm    Post subject: Reply with quote
I guess not, Lo206's have a 6100rpm limiter correct? Whats the rpm of a stock animal?
Benn Herr
PostPosted: Sun Aug 23, 2009 8:04 pm    Post subject: Reply with quote
The LO206 should be legal in the Stock Animal class. You will be a little down on power to a fully blue printed Animal and you will be a couple thousand RPM short - 6100 vs. whatever a good Animal does. But it will get you on the track and running. Figure out the kart, the mechanics, the gearing, the handling. Then you can switch the ignition and get a blue print if you want.
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
Josh Kestner
PostPosted: Sun Aug 23, 2009 8:14 pm    Post subject: Reply with quote
That is exactly what I'm thinking. If I get a decent chassis (2005) or so, and using it in a stock animal class I shouldn't wear on it much so I should be able to "grow" with it. I have to start somewhere, and with the restrictor on it, it should make the motor very reliable. Once the motor poops on me, I could either have it blueprinted or switch classes all together. I just want to race, as long as there is a class for me to race in I'll be enjoying the hell out of it. It will surely make me "smooth" on a kart.
Who knows, the LO206 is new, maybe there will be a class for it soon.
Todd Snider
PostPosted: Sun Aug 23, 2009 8:31 pm    Post subject: Reply with quote
I believe you can swap the ignition or just the coil on the 206 if the rev limiter was an issue. Something to consider. Might want to ask one of the Briggs builders.
Todd
Devin Smith
PostPosted: Sun Aug 23, 2009 10:08 pm    Post subject: Reply with quote
Swap the Magneto about $90, add A Dyno an001 or 002 cam with CR for you can still pull start it about $80. Are Animal without the restrictor will pull 7150 never had much time to play with it since we usually run JR1 with the gold IKF restictor on gas. We will pull 6500 when geared right in Jr1.
Jeff Smith
Jamie Webb
PostPosted: Mon Aug 24, 2009 5:48 am    Post subject: Reply with quote
You will not be anywhere near competitive with a built "stock" WKA Animal with a LO206.
If you are looking to take the LO206 and convert it to a blueprinted Animal, then yes you will be fine. But if you plan on pulling the LO206 out of the box and running the Animal class, I think you will be disappointed.
Jamie Webb
Call or email for Home, Auto, Life, or Health Insurance quote (Florida only).
PostPosted: Mon Aug 24, 2009 11:46 am    Post subject: Reply with quote
As a new guy you won't be anywhere near competitive with a blueprinted Animal, there's just too much other stuff to learn like chassis set-up, driving, tires, etc.
The LO206 will get you out on track with a set-up that will run for as long as you need to learn the other stuff. Then you can send it to Jamie, or any one of us engine builders and get it converted to a competitive stock Animal.
But, what you might find is some of the guys who are running stock Animal might just want to join you with the LO206 to save a few bucks. Or, they might get some of their buddies started with their old chassis and the LO206 engine. You might just be the start of a new class down there, you never know. But what you won't be is stuck with the TaG engine of the month for $3k that costs a fortune to maintain Laughing
In any case the LO206 will provide what you need to get started without trying to figure out all the details on buying/operating a "competitive" stock Animal. When you're ready to step up you will already have the base engine and your chassis will be tuned so you can use the extra power. Most importantly, you will have taken the time to learn how to drive smoothly so your chances of running up front will be much higher.
Good luck,
Heartbeat Power, LLC.
Josh Kestner
PostPosted: Mon Aug 24, 2009 5:24 pm    Post subject: Reply with quote
Is running 2stroke chassis very popular in 4cycle sprint racing? Because i'm looking to get a decent chassis that I can possibly upgrade in the coming years kt100 or whatever.
Les Prins
PostPosted: Mon Aug 24, 2009 5:40 pm    Post subject: Reply with quote
Why not get an Animal, not the LO206? I believe they are around same price. They have the same parts except for a fire-ring head gasket, a blue coil and no pull starter but you could find one of them fairly easy. It will have a 12,000 rev limiter but gear it to 7,000 to 7500 for sprint tracks, they can take it. It would get you closer to the others and have the blue coil to blueprint it later.
Just a thought.
Mitch Wright
PostPosted: Mon Aug 24, 2009 5:42 pm    Post subject: Reply with quote
Yes you can use a 2/ chassis, Burris has a really nice jackshaft setup that makes it easy and eliminates the rear sprocket/rear cross bar fit issues if they exsist.
www.burrisracing.com
Shannon Schmidt
PostPosted: Mon Aug 24, 2009 6:52 pm    Post subject: Reply with quote
Josh..If you choose a 2 cylce chassis, I would try and find a good 30/32 frame. You can use a 32/32, but you will find more adjustability with the 30/32. I hav done very well with my 32/32, but everytime I get on a 30/32, I am faster.
Miller Motorsport Park
2006 Rotax Masters Champion
2007 Rotax Masters Runner-Up
2009 F200 Champion
Monza Z32C #7
"Don't brake till you see God!"
"A great racing driver has his head in communication with his balls." -Richie Evans
charles hunter
PostPosted: Fri Oct 09, 2009 5:53 pm    Post subject: Reply with quote
Benn is correct, the 206 is down on power to the animal but we can stay somewhat close to the world formulas ALSO if you have never raced karts I assure you two areas of your body will violently tighten and shrivel up even with the rev limiter on when you take the green for the first time and fly into turn one.
swampwater smyth concurs "If you aint first, yer last."
------------------>DRSWAMP RACING INC<-----------------
DB time: 0.129186 (37.94%), total time:0.340525, queries:38
