2D2W - LB
KG Plastics - FB
219 Chain Dimension
JOHN PARSON
PostPosted: Wed Jul 08, 2009 9:58 pm    Post subject: 219 Chain Dimension Reply with quote
I'm doing some CAD drawings and don't have a piece of 219 chain handy. Could someone give me an accurate measurement of the OD of the rollers? I've found online the chain pitch is .306" (center to center of pins). I'm trying to draw an accurate sprocket.
Pete Muller
PostPosted: Wed Jul 08, 2009 10:05 pm    Post subject: Reply with quote
According to Azusa, the pitch is .306", and the roller diameter is .200".
Info here: http://azusaeng.com/Sprockets/AzSDno219.pdf and here: http://www.azusaeng.com/chain/krtchn.html#Anchor - 219 (you may need to scroll down the page on that second link, I don't think the anchor works correctly).
JOHN PARSON
PostPosted: Wed Jul 08, 2009 10:08 pm    Post subject: Reply with quote
Thanks Pete. Good source.
John
Kyle Vallarino
PostPosted: Fri Jul 10, 2009 4:03 pm    Post subject: Reply with quote
hey john, when your drawing a sprocket how do you figure out the diameter of the sprocket?
#31 Intrepid
www.leadingedgemotorsports.com
JOHN PARSON
PostPosted: Tue Jul 14, 2009 9:49 pm    Post subject: Reply with quote
Kyle,
You can start with the nice table from Azusa Engineering or use a CAD program that allows you to specify the number of teeth and then lay in the proper chain pitch (if you know the roller diameter). From there it's similar to drawing gears.
John
Pete Muller
PostPosted: Tue Jul 14, 2009 11:49 pm    Post subject: Reply with quote
Just don't forget that a chain actually doesn't lay along an arc, per say.
There is a straight line that connects each roller to the next, so technically it's a bit different to draw than a gear. More like a polygon.
On sprockets with large numbers of teeth, the difference is minute -- on the order of only about .002" in diameter on a 90T 219 sprocket. On a 10T 219 sprocket though, the difference becomes just over .016"... very significant!
Kyle Vallarino
PostPosted: Sat Jul 18, 2009 9:38 pm    Post subject: Reply with quote
i was taught on mastercam. i have actually only done it once, for a #35 chain, and i was taught to draw half the recess then half the tooth and just mirror it over at 360 divided by # of teeth. just trying to remember how to calculate the diameter at the center of the roller. want to try to make 219 stuff.
#31 Intrepid
Pete Muller
PostPosted: Sat Jul 18, 2009 11:03 pm    Post subject: Reply with quote
You can get close by just using (pitch x N) / pi
However that's not quite correct as mentioned in my previous message. On a big sprocket, the difference is almost nothing, but on a small (drive) sprocket it's significant.
You can do one iteration from the initial diameter you get using the formula above -- and then you'll have it nailed.
PM
Dan Haynes
PostPosted: Mon Nov 26, 2012 8:29 pm    Post subject: Reply with quote
Sorry for resurrecting an old post but found it in a search. I bought a small CNC machine a few months ago and am learning Mastercam. Thought I would try making a rear gear. I have gear software called Sprocketeer. It will create the DXF that I will import into Mastercam to finish up.
How did your gear work for you?
Blaise Haynes
#3 Arrow X1-CIK
TaG
DB time: 0.382941 (70.13%), total time:0.54601, queries:38
