KartSport North America - LB
Top Kart USA - SS
Leading Edge Motorsports
New Rotax clutch
William French
PostPosted: Fri Jan 02, 2009 6:31 am    Post subject: New Rotax Clutch Reply with quote
I have already purchased mine from my engine builder. He has them in stock and available on his web site listed below.
http://www.pktaxles.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PKTS&Product_Code=ROT281720&Category_Code=RTXCL
Marc Miller
Advertiser
Advertiser
PostPosted: Fri Jan 02, 2009 6:54 am    Post subject: Reply with quote
Walt Gifford wrote:
Drive gears? The clutch is driven by the main crankshaft, the plastic gears don't drive the clutch.
The plastic gears are on the other side of the engine and just drive the balance shaft and the water pump like they always did.
I like the idea of steel gears instead of plastic so, the point is academic but, the gear connection with the clutch sounds like a plot.
Gif Cool
Sorry Walt... I meant balance gears. My assessment though is still true - as the new clutch puts more strain on the plastic components, resulting in the need for the upgrade.
Keep in mind that BRP and the distributors warranty many items - however, if you do not use them as specified/recommended - it can void that warranty, like anything else.
"Luck is when Preparation meets Opportunity"
Director of Brand Development (MRP/Birel) www.BirelAmerica.com /
Advanced Instructor - MRP Speed Schools - www.mrpmotorsport.com
Professional Driver/Driver Coach - http://www.themarcmillershow.com
william keyes
PostPosted: Fri Jan 02, 2009 6:55 am    Post subject: Rotax clutch Reply with quote
Ditto on the reply by Mr. French, PKT had in stock. Already installed and ready to go.
Joe Stalker
PostPosted: Sat Jan 03, 2009 4:26 pm    Post subject: Reply with quote
We ran ours this weekend, pretty easy & straight forward to install. Does make a tad of a ringing noise since you now have metal on metal.
2 Questions: Since there is no way of holding the clutch drum secure when tightening the drive gear nut, is there going to be some sort of special tool manufactured ? Also, when are the drums available alone and how much $$$ ?
Red Gloves Rule...See ya at the Front.
Joe Stalker
VP Los Angeles Karting Championship
John Savage
PostPosted: Sat Jan 03, 2009 4:59 pm    Post subject: Reply with quote
"is there going to be some sort of special tool manufactured ?"
Well I call it a chain Wink
Andy Seesemann
Expert
Expert
PostPosted: Sat Jan 03, 2009 5:16 pm    Post subject: Reply with quote
Joe,
There is a new part number for a holding tool that has a pattern for each drive gear. I believe that it shows it on the instruction pamphlet that is in the clutch kit box that you got from me a few days ago.
I haven't seen one yet. I'm not sure if any of the importers have them in stock.
No news on the cost of the item, nor the cost of the drums.
A
P.S. You could have just called. You have my cell number.....
Andy Seesemann
FULL THROTTLE KARTING
Orange County, CA.
www.fullthrottlekarting.com
Rotax Challenge of the Americas
www.rotaxchallenge.com
WKA District 10 Trustee
www.worldkarting.com
Really Good Guy.
Joe Stalker
PostPosted: Mon Jan 05, 2009 10:18 am    Post subject: Reply with quote
Andy Seesemann wrote:
Joe,
Yeah, I know. But It hought it would be more fun to pass some time on the forum.
"I haven't seen one yet. I'm not sure if any of the importers have them in stock".
Makes it tricky trying to tighten that nut without it. Came loose on us once. OK now.
"No news on the cost of the item, nor the cost of the drums".
Hope the drums are released soon. P.I.A. having to change the drive gear instead of the drum.
Stop by later this week.
Joe Stalker
Robert Brooks
PostPosted: Mon Jan 05, 2009 11:06 am    Post subject: Reply with quote
I sure hope this is not an item that if you don't have you can't compete at the front. Maybe it's beeen talked about, but is this part faster or slower than the current spec, and is it an option for 09, or required, or?
I sure dont need another way spend $. I just bought a new clutch and had two others rebuilt in the past two months. One of the reason we went Rotax is to avoid the part of the month club.
Straightaways are for fast karts, corners are for fast drivers....
Joey Guyon
PostPosted: Mon Jan 05, 2009 11:35 am    Post subject: Reply with quote
We have clutch/balance kits, gear holders, and each individual part in stock as well:
Drums
Balance gears
Clutch bolts
www.overdrivekarts.com
Contact me for pricing: info@overdrivekarts.com
Joey Guyon
Lewis Cronis
PostPosted: Mon Jan 05, 2009 11:55 am    Post subject: Reply with quote
Robert Brooks wrote:
I sure hope this is not an item that if you don't have you can't compete at the front. Maybe it's beeen talked about, but is this part faster or slower than the current spec, and is it an option for 09, or required.
IIRC, Mark Ouimet (SSCEast) in a previous thread (WKA Daytona discussion IIRC) stated that BRP's position is that there is no performance advantage to the new clutch/gears, based on their testing prior to release.
Lewis Cronis
PostPosted: Mon Jan 05, 2009 11:56 am    Post subject: Reply with quote
I am of course assuming that the new clutch meets the same/existing spec for slip/engagement RPM.
Ray Chiappe
PostPosted: Mon Jan 05, 2009 12:38 pm    Post subject: Reply with quote
Just blew out my plastic gears! Can the new gears be used with the old style clutch???
Carlos Calderon
PostPosted: Mon Jan 05, 2009 1:49 pm    Post subject: Reply with quote
So Joe,
What's your initial testing show? Is the new clutch kit faster, slower, or the same? Any differences in terms of performance or driving?
Aluminos
Joey Guyon
PostPosted: Mon Jan 05, 2009 2:26 pm    Post subject: Reply with quote
Hi Carlos,
Our testing at the worlds was good with no slippage or failures. We did not have the chance to test back to back versus the old style clutch so I can't give you performance suggestion.
On the dyno the engagement is within 200rpm of the old style (slightly higher).
On another note - the new steel balance gears are a drop in replacement for the plastic ones and are highly recommended to avoid failure of the plastic gears!!!
Joey Guyon
Carlos Calderon
PostPosted: Mon Jan 05, 2009 2:33 pm    Post subject: Reply with quote
Yep, that's what I'm interested in.
That's interesting, thanks. Was that test done by comparing two unused clutches (and associated parts)?
Aluminos
Page 2 of 6
DB time: 0.261663 (41.39%), total time:0.632173, queries:38
