SKUSA (non-flash) - LB
Brett King Design
lead weight
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Juniors Only Section
A I
Guest
PostPosted: Tue Aug 05, 2008 11:11 pm    Post subject: lead weight Reply with quote
a question for the juniors. what class do you run, what's the weight limit, and how much lead do you need to add to your kart?
i'm running rotax at 365 lbs, and i have to add 36 pounds to make weight.
Luke Oxner
PostPosted: Wed Aug 06, 2008 12:27 am    Post subject: Reply with quote
I run World Formula, also at 365lbs, but i only have to add 25 to make min. weight
Julian Garfield
PostPosted: Wed Aug 06, 2008 4:37 pm    Post subject: Reply with quote
I run a FR125 Rotax Mini Max Which has a minimum weight of 265 lbs. I add about 35 lbs. on my kart.
Arrow AX9-4S/KT-100 - SCCA Solo
Daniel Gorin
PostPosted: Fri Aug 08, 2008 12:12 pm    Post subject: Reply with quote
I run hpv2, minimum is 310, and i have ~30 lbs.
Zack Knotts
PostPosted: Fri Aug 08, 2008 3:12 pm    Post subject: Reply with quote
i run jr can and have to add about 10 pounds
Cameron Smock
PostPosted: Sat Aug 09, 2008 8:23 pm    Post subject: Reply with quote
i run jr. sportsman and have to add about 40 lb to get to 250. Shocked Mr. Green
it's going to be bad next year in jr can at 305. we make our own wiehgts with a smelter Rolling Eyes . it's fun. Laughing
never underestimate the power of stoopid people in large groups
Blaise Haynes
PostPosted: Tue Aug 12, 2008 8:50 pm    Post subject: Reply with quote
I run Jr. Can 305 lbs and i have about 14lbs on it or so. I run HPV-2 310 lbs and i have about 15 lbs on it
Blaise Haynes
#3 Jr.Supercan
Cameron Smock
PostPosted: Tue Aug 19, 2008 1:45 pm    Post subject: Reply with quote
i only weigh 79lbs and im 13 NO IM NOT ANNERXEC!!!!!!!!!!!!!!!!!!! Mad
Eli Salamie
PostPosted: Fri Jun 12, 2009 5:18 pm    Post subject: Reply with quote
I run in Jr. Can and I have to be 305 pounds. We add about 25 pounds of weight.
Dennis Gur
Location: United States, New York, Longisland, Farmingdale
PostPosted: Sat Oct 24, 2009 1:48 pm    Post subject: Reply with quote
i run senior sportsman 4 hole can. 360lbs limit , 55lbs of weight, 145lbs driver, 160lb chassis+engine
EJ Fitzgerald
PostPosted: Thu Jan 14, 2010 9:07 pm    Post subject: Reply with quote
I race mini max [ my weight for my class is 265 ] and I only add 5 pounds but I am 5 pounds over and jest to make sure I leave that on their. Razz Razz Razz Very Happy
joe Di Marco
PostPosted: Sun Mar 07, 2010 4:55 pm    Post subject: Reply with quote
I race in Senior Sportsman the weight is 340 so I have to add 60lbs of weight!!!
Kyle May
PostPosted: Mon May 24, 2010 5:49 pm    Post subject: Reply with quote
i run jr can the wheight is 305 and i have maybe 10 punds in it and its my first year in can Crying or Very sad
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Juniors Only Section All times are GMT - 8 Hours
DB time: 0.078138 (40.68%), total time:0.1921, queries:38
