OTK - LB
MRP - SS
one person kart scales
Goto page 1, 2, 3, 4, 5  Next
joseph hollinger
PostPosted: Mon May 05, 2008 10:37 pm    Post subject: one person kart scales Reply with quote
Longacre scales cost way too much. At least for me. So I bought four of these:
Each one is a used Fairbanks Ultegra shipping scale. Total cost for the set was about $350. Other Fairbanks models are available for even less on Ebay and other sources. I hooked them to my laptop using four USB serial ports and a USB hub. That's about another $75:
Here's a gratuitous shot of the kart sitting on the scales with the laptop in the background:
To run the scales, I wrote a windows interface using MS Visual C++. Here's an actual screen shot:
I'm pretty proud of the results. It's super accurate (five times more accurate than commercially available scales) and has a unique countdown feature that stops measuring and freezes the display 60 seconds after I click a countdown button. That way, I can click the button, get into the kart, wait about thirty seconds and the program measures and saves the results. No more need to get a second person to read the scales or for me to write down anything while measuring.
Anyway, besides just plain bragging, I'm more the willing to give my program to anyone who wants a copy. Not that it's a piece of art, but it works and obviously there's no need to reinvent the wheel. Just send me a PM if you are interested.
Randy Lyon
PostPosted: Tue May 06, 2008 2:41 am    Post subject: Reply with quote
That is nice!
What's the best way to shim the individual scales so they are level and at the same hight?
Rick Worth
PostPosted: Tue May 06, 2008 4:02 am    Post subject: Reply with quote
Spare floor tiles work good.
Chuck Bunnell
PostPosted: Tue May 06, 2008 9:26 am    Post subject: Reply with quote
Old magazines work well to if they're the glossy type. Just another reason to keep all those karting magazines.
joseph hollinger
PostPosted: Tue May 06, 2008 9:32 am    Post subject: Reply with quote
The scales I used (Fairbanks Ultegras) have four feet that allow them to be individually leveled. If your floor is reasonably level, you can use that method to do scale to scale adjustment. I do that and use floor tiles as well. The combination allows me to make the scales as level as time and patience allows.
It makes me wonder how super level surfaces are constructed. I bought a pretty good level, but there's a limit, right? I mean, the level is really only as good as your eyes. On a kart, a very, very small height difference at one corner can make a pretty big difference in readings.
bo rougeou
PostPosted: Tue May 06, 2008 1:35 pm    Post subject: scales Reply with quote
THAT IS SWEET!!! they make scale stands that we use. got four leveling legs with bolts to give you an infinite adjustment. mine are homemade. with your skills it would be a snap.
Steve O'Hara
PostPosted: Tue May 06, 2008 5:35 pm    Post subject: Reply with quote
Joeseph,
Nice! No need for anything more complicated than that. What is the maximum weight limit on those scales? Have you experimented with the position of the wheel (tire) on the scales to see if they are sensative to placement? Some of the older digital race car scales were single strain gauge designs that gave different readings depending on the position of the tire on the scale. Some of them use more than one gauge now to eliminate that problem. The price is so high on the current race car scales that it makes your system much more attractive even if you have to be careful about the tire placement.
I would like to try your system ... please send me your program.
Regards,
Steve O'Hara
steveohara@msn.com
Steve O'Hara
PostPosted: Tue May 06, 2008 5:37 pm    Post subject: Reply with quote
Oops..... Either Joe or Joseph.... not Joeseph.... Embarassed
joseph hollinger
PostPosted: Tue May 06, 2008 10:15 pm    Post subject: Reply with quote
Steve O'Hara wrote:
Joeseph,
Regards,
Steve O'Hara
steveohara@msn.com
I didn't have an answer for your question about wheel position. So, I moved the kart and remeasured. Compared to the results I got yesterday, no wheel changed more than .75 pounds and the total weight changed by .59 pounds. Since my weight probably changed a little, I assume the scales are relatively insensitive to this sort of thing.
In fact, I'm pretty pleased that the repeatability was that good. .59 is 0.15 percent. I can't imagine beating that under any circumstances.
The scales I used are limited to 150 pounds each with 3X overload protection. There's no reason the same program won't work with other scales with very simple modifications.
joseph hollinger
PostPosted: Tue May 06, 2008 10:17 pm    Post subject: Reply with quote
Thanks everyone for all the positive feedback. As I've told many of you by PM, I'm going to clean up the program a little and send it to everyone next week.
Jacob Hennie
PostPosted: Tue May 06, 2008 11:49 pm    Post subject: Reply with quote
Joseph, VERY IMPRESSIVE!! Did you use MFC? Which VC++? 6?
Been a C++ programmer myself, signal intelligence/electronic warfare systems, In-flight entertainment systems, now a software manager for a GPS company. The funnest stuff was always multi-threaded apps in WinCE........
Again, great job, and very cool!
Tom Hennie
Gary Lawson
PostPosted: Wed May 07, 2008 8:05 am    Post subject: re Reply with quote
While it looks like a decent setup you have $425 tied up in them. Compared to a new set up scales for 1200 that sounds good. But, right now you can find used scales for sale very easily. You even said your scales were used. I just sold a set up scales that were just recalibrated (intercomp) for $600. That is about the going rate right now for used scales. Again, not really knocking your idea, I just want to let you and others know the options that are out there. 4cycle.com has some scales for sale in the misc. section pretty often.
Dan Davis
PostPosted: Wed May 07, 2008 9:03 am    Post subject: Reply with quote
Very Cool Joeseph!!
The type of ingenuity that you applied here is a large part of this sport....keep it up. It seems like the scales that can be connected to a PC cost more than the std. $900-$1000 new. I really like the delay or countdown feature too.
The only thing I see that might be a problem is the tread plate type surface on the pads/load cells. Getting all of the scales on the same plane might be difficult when using a level that depends on surface contact with the pads to be accurate. Most Racing scales have machined flat surfaces that might make leveling using a long bubble level easier to get more accurate using the eyes.......but I see you added the tiles over the top of the tread plate surfaces of the pads in the "gratuitous" pic.....That should help.
Impressive....I like. Wink
Seth Blackburn
PostPosted: Wed May 07, 2008 9:18 am    Post subject: Reply with quote
Hey, could you send me the program too? I'm taking C at college this semester, and it would be neat to see how you programed it, and I may use it if I buy some of those scales in the future. What OS's is it compatible with?
joseph hollinger
PostPosted: Wed May 07, 2008 9:46 am    Post subject: Re: re Reply with quote
I think that's a valid criticism. The supply of the Ultegra model tends to be pretty low and prices are relatively high. In fact, it took me a couple of months to get four scales at the prices I mentioned. That said, it's also true that there's a much larger supply of older Fairbanks scales with the same capacity and they tend to sell on Ebay in the $20 to $30 range. And there are numerous other manufacturers as well. I also bought my USB stuff at Fry's. I'm sure it can be sourced online for much less. In particular, I know you can buy non-powered USB hubs for something like $7 each. So, if you're really into driving costs down, there's no reason that you can't do what I did for less than $200. And that's one-third of what you ballparked for used intercomps which do less and are less accurate.
Page 1 of 5
DB time: 0.255113 (48.71%), total time:0.523773, queries:38
