OTK - LB
Russell Karting - SS
Franklin / Merlin USA - FB
AIM Lambda Install
Jeff DeMello
PostPosted: Sun Oct 21, 2012 8:32 am    Post subject: Reply with quote
Cesar you don't need it
Jeff DeMello
Emmick F125 Pavesi
Cesar Rull
PostPosted: Sun Oct 21, 2012 9:42 am    Post subject: Reply with quote
Jeff so I am told I don't and EGT, you tell me I dont need a wideband. So I will respectfully ask thing. How do you guys tune your engines? Because I understand that every time at the track you need to change jets or whatever going in the carb. I have no experience with a carburetor, but I do have experience tuning fuel injected cars on a dyno and road. I always had a wideband to KNOW where the A/F was and what I needed to change.
Can you please, maybe via PM explain how the tuning on the CR125 is done out any tools?
Tim Salvino
PostPosted: Sun Oct 21, 2012 9:59 am    Post subject: Reply with quote
http://www.ekartingnews.com/viewtopic.php?p=577577&sid=6794f81d534f583efdd9106cf62be733
Many people tune by pulling out the plug and reading both it and the piston top. But read through that thread above, pay attention to the last few posts.
Cesar Rull
PostPosted: Sun Oct 21, 2012 10:14 am    Post subject: Reply with quote
^ like an RC car... ill read it thank you.
Jim McMahon
PostPosted: Sun Oct 21, 2012 8:28 pm    Post subject: Reply with quote
"Baselining". It comes down the the stopwatch and the appearance of the piston crown/exhaust header. Its old school but it works. Start with a bigger jet and work down until the correct appearance is found, note jet size and air density. Then monitor air density changes and change the jet size according to change in air density.
EGT at the best of times can be affected by many different factors, including the driver. It's handy as a reference but really to start out I would buy an air density gauge or weather station before buying an EGT probe for a shifter.
PostPosted: Mon Oct 22, 2012 3:07 am    Post subject: Reply with quote
Lean it out still it sticks, go up one jet size!!!! Very Happy
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Jim McMahon
PostPosted: Mon Oct 22, 2012 6:51 am    Post subject: Reply with quote
CR
This works too.... Just don't stick it at 5PM one day and hit the track at 6AM the next hehe. At least not in September up in the Midwest.
Johnny Brooks
PostPosted: Mon Oct 22, 2012 8:47 am    Post subject: Reply with quote
Hope yer not buyin that stuff by the gallon due to 'necessity'? Embarassed Razz
The pessimist sees difficulty in every opportunity. The optimist sees the opportunity in every difficulty.--Winston Churchill
Jim McMahon
PostPosted: Mon Oct 22, 2012 1:16 pm    Post subject: Reply with quote
Haven't bought any yet. When I blow a motor, acid ain't gonna fix it!
PostPosted: Mon Oct 22, 2012 3:22 pm    Post subject: Reply with quote
Actually works extremely well for different weather conditions if you recorded what the weather was when you stuck it, add one jet, then use that for a baseline, adjust your jetting according to a relative air density calculation....
BTW back in the day when men were men and cylinders had cast iron liners, that's basically how it was done......
CR
Steve O'Hara
PostPosted: Tue Oct 23, 2012 12:04 am    Post subject: Reply with quote
Now that this thread has come back to life after three years the real question is.... has anyone that employed the Lambda sensor on a two cycle kart engine found it to be truly useful in identifying and correcting a fuel delivery problem?
If so, please share your experiences and data.
Steve O'Hara
PostPosted: Tue Oct 23, 2012 5:33 am    Post subject: Reply with quote
There was a thread with a guy Richard Bruckner, owner of High Gain Tuning.
They build EFI conversions for 2 stroke scooters and other 2 strokes. He uses a Lamda probe for all his tuning.....
CR
Chris Parks
PostPosted: Tue Oct 23, 2012 6:43 am    Post subject: Reply with quote
Steve O'Hara
We use fuel pressure for that and lambda for mixture or that was plan A. I had some debate with the experts and expressed my opinion that that fuel pressure would not work on our version of pump around and it turns out that I was right and the experts were not so that got thrown over the left shoulder. I think that fuel pressure is the correct tool for system problems. It (FP)may work on a conventional pump around as they run restrictors in the fuel line where as we don't.
Chris
joseph hollinger
PostPosted: Tue Oct 23, 2012 7:21 am    Post subject: Reply with quote
Steve O'Hara
In my experience, the Lambda data is very hard to read. Even AIM admits that you cannot look at the number in isolation and that its only valid when RPM is rising. That, combined with the fact that you cannot run it with leaded fuel (once again, my experience) makes it somewhat impractical.
I've got a detonation detector on the Honda now but I haven't spent any time testing. I'm hoping the detector does what the Lambda does not.
Jim McMahon
PostPosted: Tue Oct 23, 2012 10:32 am    Post subject: Reply with quote
CR
That's a mighty big "If" there. That was my point if you went from one day to the next like that and were not monitoring air density you might end up sticking again.
Hone is cheaper than a replate thats for sure. Most of the FA motors were iron cylinders too...
Anyway, back to our regular scheduled programming.
Page 3 of 6
DB time: 0.128735 (49.87%), total time:0.258156, queries:38
