KartSport North America - LB
RLV - SS
All Things CR250
Goto page Previous  1, 2, 3 ... , 25, 26, 27  Next
Sam Moss
PostPosted: Mon Oct 08, 2012 3:56 pm    Post subject: Reply with quote
On a cr250 we don't run water cooled cases but new twins do, other than DEA which uses a gallery at the front of each cylinder. I think gallery is the word I'm after?
My question is due to not having water cooled cases do we see a loss in power from cases getting hot around the crank and loss of possible pressure?
Ian Harrison
PostPosted: Mon Oct 08, 2012 6:04 pm    Post subject: Reply with quote
H Sam
You could have just given me a call Wink
Yes, with "heat soak" the cases become hotter throughout a race. This causes the incoming cool mixture to be heated up and therefore the density reduced.
Less mixture into the cylinders = less power.
The DEA has heavily finned cases, so it looses heat to the air (like aircooled cylinder fins), whereas others circulate the cool water returning from the rads through the cases and then up into the cylinders to keep the crank chamber walls cool hence power remains more consistent.
Next time your at Anderson's ask Russell to show you the DEA cases, if he has one in the shop. The castings (they are sand cast) are a thing of beauty!!
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
Sam Moss
PostPosted: Mon Oct 08, 2012 6:35 pm    Post subject: Reply with quote
Thanks Ian, I didn't think you'd appreciate a call from a noisy factory in the middle of the night Smile
Ian Harrison
PostPosted: Sat Oct 13, 2012 5:00 am    Post subject: Reply with quote
Hi Sam
Your probably right!!
Glad to hear your keeping the wheels of industry turning Cool
See you at Donington Very Happy
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Dan Davis
PostPosted: Tue Oct 23, 2012 2:59 pm    Post subject: Reply with quote
Howdy All!
Does anybody (Ian Wink) know the difference between the wrist/piston pin bearing called out for 1989-2004 CR250 with P/N 91015-KZ3-003 and the 2005-2007 with P/N 91015-KSK-731? Besides double the price for the earlier bearing?
On top of that, ProX calls out the same bearing for 86 and 07 P/N 21.1316
Different supplier maybe ??
PostPosted: Tue Oct 23, 2012 6:15 pm    Post subject: Reply with quote
The older bearing is twice the price, generally in the Honda you are correct they found another supplier. That also means that the old part's life is on borrowed time. In general terms, the later stuff is of better quality, I know all the 125/250 stuff 05-07 was the latest and greatest before they put the kibosh on 2 strokes...
I see the wrist pin on the older models updates to a KSK model, so it's a matter of time for that bearing.
Maybe Ian has hands on experience with that bearing....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Roger Miller
Site Admin
PostPosted: Tue Oct 23, 2012 7:45 pm    Post subject: Reply with quote
We have 2002/03 engines and use the KSK bearing and pin from the 2005/07 parts lists.
Dan Davis
PostPosted: Tue Oct 23, 2012 7:59 pm    Post subject: Reply with quote
Excellent!
I'll buy a burger with that savings. Wink
Ian Harrison
PostPosted: Wed Oct 24, 2012 1:46 am    Post subject: Reply with quote
Hi Guys
We always change the little end (wrist pin) bearing when we change the piston. That little bearing has a hard life!! KSK and KZ3 Honda bearings are interchageable.
I have to say that I have seen a few recent "early life" failures with the KSK bearing. I have spoken to other UK tuners/engine builders and they have seen the same thing. That's strange as the KSK actually looks stronger??? By "early life" I mean in less than the life of one piston. Not huge numbers, but perhaps enough to make you think it's a little more than a string of coincidence/bad luck.
The earlier bearing had a very dark finish on the cage (sort of very deep brown/gunmetal) as does the Prox. The KSK part number has a cage that is (currently at least) a mid-grey colour.
We actually source a high quality bearing direct from Japan (just waiting for new batch), or have found in the past the bearing that Pro-X supply to be very good also, although it does have slightly shorter rollers, so perhaps a tiny bit less stability, but the bigger side shoulder perhaps adds more strength to the cage. All the bearings have 15 rollers.
Apologies for image quality:
Right - Honda KSK little-end bearing
Centre - Honda KZ3 little-end bearing
Left - Prox little-end bearing
Dan - put that burger on hold
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Dan Davis
PostPosted: Wed Oct 24, 2012 8:57 pm    Post subject: Reply with quote
Oh well, i guess I'd rather pay $6 more now versus hundreds later. Thanks for all of the input everyone!
Sam Moss
PostPosted: Sat Nov 03, 2012 6:19 am    Post subject: Reply with quote
Any chance we could get away with something like this Question Surely the rings are very prone to catching and making a big mess Question
http://www.bikechatforums.com/viewtopic.php?t=232424
Also could you explain eyebrow ports a bit more. Not much is said in Mr Bells book.
Gerry MacNutt
PostPosted: Sun Nov 04, 2012 1:58 am    Post subject: Reply with quote
Hi, while were on the topic of the small end, will the 2001 wrist pin work on the 2002 motor?
John Benson
PostPosted: Tue Nov 27, 2012 7:12 pm    Post subject: Reply with quote
Does anyone know the actual power loss from high water temp? Say the difference between 150f and 180? Thanks John.
Riley Will
PostPosted: Tue Nov 27, 2012 8:09 pm    Post subject: Reply with quote
Over 140F is 10% on our engines. 180F would be 15%!
Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com
Ian Harrison
PostPosted: Tue Nov 27, 2012 8:10 pm    Post subject: Reply with quote
Sam Moss wrote:
Any chance we could get away with something like this Question Surely the rings are very prone to catching and making a big mess Question Also could you explain eyebrow ports a bit more. Not much is said in Mr Bells book.
Hi Sam, that old bridged-port vs eyebrow port argument Wink . There are passionate arguments on either side. It's just 2 ways of getting round the fact that you can't do the width of exhaust port that you would like in one hit. There has to be a divider somewhere. Generally you open the exhaust sub ports later than the main port to send a stronger initial sonic pulse into the expansion chamber. On the bridged port a similar effect (along with a reduction in ring wear) is produced by the roof of the port window being angled down from the centre. It is my belief that the bigger the bore the more compelling the arguments in favour of a bridged-port become.
A good deal of what Graham Bell said in his book (some time ago it must be said), has been "disproved" or "modified" over time, but it is still a must read for anyone who has an interest in 2-stroke tuning.
They are the same pin: 13111-KSK-730
Any Honda pin from 1986 - 2007 has the same external dimensions.
The balance factor is improved (for kart racing) and crank stresses reduced, by loosing piston weight. If you compare aftermarket pins there is some variation in weight and some small improvement to be had. My current weighed variation max to min is 14 grams!!
That's 65 C to 82C!!!! Shocked
First off they are both too hot. For power the cooler the better 40-50C (104-122F) is good and as long as the piston clearances, ignition timing and jetting are correct you won't get any cold seizure problems.
Between 65 and 82C power loss would be at least 3Hp (above 75C you are risking failure due to reduced heat gradient between piston temp and cylinder wall temp).
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Page 26 of 27
DB time: 0.172863 (42.47%), total time:0.407037, queries:38
