Mark Jauregui
Posted: Mon Apr 30, 2012 4:29 pm Post subject: |
Hi,
I thought I saw a posting from Ian awhile back regarding piston skirts cracking/breaking, but couldn't find it here. What is the service life of a new Honda piston when being run with an aftermarket ignition? I had a piston skirt go through the engine. It was time for a rebuild, but I'd like to make sure that doesn't happen again.
Also, per a previous comment, it sounds like I don't need to worry about running B pistons with A barrels?
"So sizes are:
A - for 66.34mm bore size
B - for 66.35mm bore size
C - for 66.36mm bore size
D - for 66.37mm bore size
If your cylinder has been replated it could be any size, but without instruction most platers would finish to 66.34
As a by the way, Honda in their wisdom have discontinued their Flat Top A piston for the crankcase induction motor. However, we find the B piston runs fine even in a new 'A' barrel, and we don't suffer any seizures. It runs a clearance of just over 2 thou (yes Erik I was brought up on thous!!)."
Mark _________________ Mark Jauregui
F125, 250 ICE/FE
NCK
Last edited by Mark Jauregui on Tue May 01, 2012 1:34 pm, edited 1 time in total |
Ian Harrison
Joined: 23 Nov 2006 Posts: 1671 Location: United Kingdom (Great Britain), Manchester
Posted: Mon Apr 30, 2012 11:08 pm Post subject: |
Hi Mark
We run pistons for 2 race meetings. In the interim if we get any bad detonation we change them as this will weaken the top ring land and make it liable to fall off!
Thre was a period when the flat top A piston was unavailable for the 2002-2004 and Honda were saying that it's OK to fit the B. (which in most cases it is, particularly if you are running leaded fuel).
The A piston for all types and years of motor 1992 - 2007 is now availale (although not shown on the 2002 fiche, it is on the 2004 fiche, so don't let a parts man fob you off) as follows:
Cylinder induction Flat Top 'A': 13101-KZ3-505
Crankcase induction Flat Top 'A': 13101-KSK-670
Crankcase induction Dome Top 'A': 13110-KSK-730
Best Regards,
Ian  _________________ Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
Championship winning Superkart race team 1997-2012 |
Mark Jauregui
Posted: Tue May 01, 2012 1:33 pm Post subject: |
Thanks Ian! _________________ Mark Jauregui
F125, 250 ICE/FE
NCK |
Anthony Williams
Joined: 04 Nov 2004 Posts: 267 Location: United States, California,
Posted: Tue May 01, 2012 5:32 pm Post subject: |
| Hey Ian - I know this is slightly off topic BUT does that also apply to Honda CR 125 engine - is the A pistons now available? |
Ian Harrison
Posted: Wed May 02, 2012 4:52 pm Post subject: |
Hi Anthony
It depends what year you are looking for:
For instance they only make the 1999 in an A, 13110-KZ4-506 , and they only make the 2001 in a B, 13120-KZ4-A90 and they make the 2005 in both, 13110-KSR-730 (A) and 13120-KSR-730 (B)
Best Regards
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Anthony Williams
Posted: Wed May 02, 2012 9:31 pm Post subject: |
Thanks Ian - you are the man!  |
John Michael Dillon
Posted: Sun May 06, 2012 5:26 pm Post subject: |
| Ian is the man. |
Ian Harrison
Posted: Wed May 09, 2012 9:55 am Post subject: |
| Anthony Williams wrote: | | Hey Ian - I know this is slightly off topic BUT does that also apply to Honda CR 125 engine - is the A pistons now available? |
OK Anthony, you specifically wanted to specify a flat-top piston as well.
After consulting my "piston bible" it seems that all Honda CR125 pistons between '92- '03 have a flat top.
They also share the following characteristics:
Bore: 54.00mm
Crown Height: 20.00mm
Overall Length: 58mm
Dome Height: 0mm (i.e. flat top)
Gudgeon Pin Diameter: 15mm
Peg Position: 20 degrees
Rear Cutout: 0mm (i.e. no cutout)
So the 1999 'A' piston part No: 13110-KZ4-506 sounds like it will fit the bill!!
Best Regards
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Anthony Williams
Posted: Wed May 09, 2012 2:10 pm Post subject: |
| Hey Ian Thanks a lot I really appreciate the information! |
Roger Miller Site Admin
Joined: 19 Jul 2001 Posts: 2917 Location: United States, California, San Jose
Posted: Mon Sep 03, 2012 9:14 pm Post subject: |
Have been getting ready for Laguna, and due to a bit of an issue at Buttonwillow, have been doing up a set of cases for one engine.
Interesting discovery - what is the difference between the 2002 cases and the 2003 cases?
Hint, has nothing to do with the combustion chamber. |
Larry Dobbs
Joined: 19 Jul 2001 Posts: 1438 Location: United States, California, El Dorado Hills
Posted: Tue Sep 04, 2012 6:33 am Post subject: |
| Different size or location of the motor mount points?! I am guessing! |
Posted: Tue Sep 04, 2012 9:15 am Post subject: |
BZZZZ Incorrect.
OK, here ya go... I thought I had a flock of 2003 engines, so I ordered the 2003 cases... During reassembly found something didn't match up.
Seems Honda changed the size of the bolt holding the "Guide Plate" which is involved with the gear selector drum. In 2002 the three bolts are 6mm, and in 2003 they are 8mm. So it was an interesting moment when this was discovered. |
Darryl Bertram
Joined: 16 Aug 2009 Posts: 35 Location: United States, Texas, league city
Posted: Tue Sep 04, 2012 2:12 pm Post subject: Honda Piston Number |
Anyone know what the Honda piston number 13100-KZ3-880 is supposed to be. It's a dome 250 piston, two rings and measures 66.36mm
On the subject of pistons I bought a Prox piston and it's an Art manufactured piston looking a whole lot like the Honda ones?
Maybe I should stay off E Bay???? _________________ Australian American Racing
Aussies in Texas |
Joined: 29 Aug 2002 Posts: 2932 Location: United States, New York, Ossining
Posted: Tue Sep 04, 2012 2:14 pm Post subject: Re: Honda Piston Number |
| Darryl Bertram wrote: | Anyone know what the Honda piston number 13100-KZ3-880 is supposed to be. It's a dome 250 piston, two rings and measures 66.36mm
Maybe I should stay off E Bay???? |
Fiche says 95, 96.... _________________ East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com |
Ian Harrison
Posted: Wed Sep 05, 2012 1:05 am Post subject: |
Hi Guys
Chris has it bang on the button.
The piston fit's is the O/E spec for 1986-1996 crossers (in fact any '86 to '01 motor) if you want to use a dome top.
At that part number it's an 'A' and should measure 66.34mm Should also have a zero or 'A' stamped on the dome.
So Daryl, perhaps you need to search for a new micrometer off Ebay
The Prox pistons for the 1986-1996 (dome top) and for the 1997-2001(flat top) are manufactured by ART (who also cast the Honda O/E pistons).
Prox Pistons
The 1986-1996 is full O/E quality
The 1997-2001 has just changed. The casting is not quite O/E quality and now has a bisulphide coating (still seems a good piston (so far)
The 2002-2004 is now no longer ART (I wouldn't put it in a kart motor)
The 2005 to 2007 (single ring, dome top) is not an ART (I wouldn't put it in a kart motor)
Best Regards
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
