Bernie Adamson
Posted: Sat Apr 19, 2008 5:39 am Post subject: |
Ian,
| Quote: | | I have one US driver chomping at the bit and heading the queue |
Am i missing an e-mail  _________________ Bernie Adamson
WWW.USKGP.com
An excellent man; he has no enemies; and none of his friends like him.
Oscar Wilde |
Ian Harrison
Joined: 23 Nov 2006 Posts: 1671 Location: United Kingdom (Great Britain), Manchester
Posted: Sat Apr 19, 2008 6:05 am Post subject: |
deleted, double posting disease. Ian _________________ Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
Ian Harrison
Posted: Sat Apr 19, 2008 6:48 am Post subject: |
Bernie, My lips are sealed, but check your mail
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Championship winning Superkart race team 1997-2012 |
Sam Zavaglia
Joined: 23 Nov 2004 Posts: 1187 Location: Australia, Sydney,
Posted: Sun Apr 20, 2008 4:04 pm Post subject: |
Is this open to a guessing competition or do we all check our email?  _________________ www.samzavaglia.com |
Chuck Bunnell
Joined: 18 Jul 2001 Posts: 558 Location: United States, Ohio, Chardon
Posted: Sun Apr 20, 2008 6:40 pm Post subject: |
| Not to get back on topic, but for an O-ring sealed head, what material is used for the washer under the acorn nuts on the head? Brass or copper? |
Ian Harrison
Posted: Mon Apr 21, 2008 12:03 am Post subject: |
Hi Chuck
Yes I didn't want to reply to Sam as it was "drifting", but Sam guess all you like (just not on this thread ) . Only me and Bernard know the truth for sure!!
Now then:
We use brass with stainless steel acorn nuts. Acorn nuts are taller than domed nuts allowing for the protruding stud length without bottoming out (as Chuck obviously already knows).
Brass washers are more durable than copper, which tend to squash and spread gripping the stud threads and making them difficult to remove, brass also looks nicer !!
You may sometimes (rarely) get a slight weeping with brass washers until they have gone through a running/heat cycle. Don't worry they will seal on their own and never seem to weep again even when removed and re-used.
Best Regards
Ian Harrison  _________________ Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Erik Frank
Joined: 18 Jul 2001 Posts: 839 Location: United States, Texas, Fort Worth
Posted: Mon Apr 21, 2008 9:12 am Post subject: |
Here's the hot setup:
Yamaha YZ-125 domed acorn nuts (high dome with nice wide flange at the base)
Suzuki "thick" copper washers....probably .060" (1.5mm for Ian) thick and made from a harder copper so they don't wear out as fast.
I'll have to dig for the part numbers, but this is what I used as my preferred setup.
-erik _________________ Member of the Fisher-Price Racing Team |
Andy Kiker
Joined: 22 Nov 2003 Posts: 460 Location: United States, New Jersey,
Posted: Mon Apr 21, 2008 11:08 am Post subject: |
I agree with Erik on this. Yamaha acorns and suzuki copper works best.
Also works well on brand X with this topic.  _________________ Andy Kiker #24
Anderson Karts
WiWa GasGas
Powrpad |
Ian Harrison
Posted: Mon Apr 21, 2008 5:03 pm Post subject: |
Hi Guys
My nuts and washers will look great long after yours are dull and tarnished
But to show there's no hard feelings:
Yamaha YZ125 Flanged Acorn Nuts - Pt.#. 90176-08026-00 - $3.01 Each
Suzuki Head Nut Washers 8.5 x 17 x 2mm Pt.#. 09168-08021 - $1.22 Each
That's $25.38 the set. Boy you guys have money to burn!!
Can't find any 1.5mm thick Erik, but these seem to be listed for all M/X bikes.
Mine also give an extra 2hp and 400 rpm e-x-c-e-p-t when used on brand X. Then gives 5HP and 1,000rpm less
Regards
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Larry Dobbs
Joined: 19 Jul 2001 Posts: 1438 Location: United States, California, El Dorado Hills
Posted: Mon Apr 21, 2008 7:10 pm Post subject: stock piston for 2001 |
I just bought a couple of top end kits I thought would be for a stock CR250, 2001, but these pistons are domed and mine are flat? Can someone tell me what is stock for what or are they A verses B or something like that? Any help would be appreciated  |
John Stafford
Joined: 23 Jul 2001 Posts: 251 Location: Danville, Ca
Posted: Mon Apr 21, 2008 7:18 pm Post subject: |
Larry!!!
Take those pistons back to wherever they're from!
Then call me. |
Ian Harrison
Posted: Tue Apr 22, 2008 12:20 am Post subject: |
Hi Larry
I love questions like this, right up my street (alley?)
There are 2 possibilities for those pistons (there are more, but then you are going way back before 1986):
1986 - 1996 used a dome top 2-ring piston. Some guys use these on the later barrel induction engines 1997-2001 as they seem to give less detonation (but the head must be squished and volumed to suit).
1997 - 2001 as standard was a flat top 2-ring piston and is probably the most popular in barrel induction race engines. (and is what you were after). The Honda part number for the bare piston is: 13101-KZ3-505 (A size) or 13102-KZ3-505 (B size).
2002-2004 crankcase induction used a flat top 2-ring piston. (This is what we use in our race engines)
2005-2007 crankcase induction uses a dome top single ring piston.
If your piston has a cutout at the rear it is a 1986-1996
If it has no cutout it is a 2005-2007.
A, B, C & D
Pistons (and cylinders) are graded by size.
If you look around your cylinder flange you will see a punched A or B.
This tells you that when the cylinder left the factory it had a finished bore size of:
A - within tolerance of 66.34mm
B - within tolerance of 66.35mm
Pistons are sized the same way. Honda produce A & B, aftermarket also produce C & D as well (Wiseco go even bigger!!).
My interim Super CR250 has a 68.5mm bore
So sizes are:
A - for 66.34mm bore size
B - for 66.35mm bore size
C - for 66.36mm bore size
D - for 66.37mm bore size
If your cylinder has been replated it could be any size, but without instruction most platers would finish to 66.34
As a by the way, Honda in their wisdom have discontinued their Flat Top A piston for the crankcase induction motor. However, we find the B piston runs fine even in a new 'A' barrel, and we don't suffer any seizures. It runs a clearance of just over 2 thou (yes Erik I was brought up on thous!!).
Just to confuse things aftermarket manufacturers also have their own systems of numbering/marking.
Wiseco include the bore size in their part number and the part number is stamped on the top of the piston with a series of dots.
Prox mark the top of their piston (in black ink) with a number and their part numbers all end in A followed by a sizing number as below:
Honda size A = Prox part number ends A = Piston marked 0 = 66.34mm bore size
Honda size B = Prox part number ends A1 = Piston marked 1 = 66.35mm bore size
Size C = Prox part number ends A2 = Piston marked 2 = 66.36mm bore size
Size D = Prox part number ends A3 = Piston marked 3 = 66.37mm bore size
Wonderful
Having said all that if you post the part No. I'll tell you exactly what it is
Best Regards
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Andy Kiker
Posted: Tue Apr 22, 2008 5:57 am Post subject: |
| Ian Harrison wrote: | Hi Guys
Regards
Ian  |
Ian, To keep your nuts and washers from getting dull and tarnished you have to give them a polish once in a while mate.  _________________ Andy Kiker #24
Anderson Karts
WiWa GasGas
Powrpad |
Dan Davis
Joined: 21 Jul 2002 Posts: 2194 Location: United States, Kansas, Wichita
Larry Dobbs
Posted: Tue Apr 22, 2008 8:27 am Post subject: |
Thanks Ian.
What about coated pistons? I don't even know what coatings I am talking about! |
