Dan Davis
Joined: 21 Jul 2002 Posts: 2194 Location: United States, Kansas, Wichita
Posted: Mon Apr 14, 2008 6:44 am Post subject: |
I believe they are as follows:
Primary Reduction: 3:1 or 63/21
1st gear: 1.8:1 or 27/15
2nd gear: 1.47:1 or 25/17
3rd gear: 1.21:1 or 23/19
4th gear: 1:1 or 21/21
5th gear: .87:1 or 20/23
6th gear: we wish |
Ian Harrison
Joined: 23 Nov 2006 Posts: 1670 Location: United Kingdom (Great Britain), Manchester
Posted: Mon Apr 14, 2008 10:28 am Post subject: |
Hi All
Dan is "on the money" as usual.
Our close ratio box for the CR250 ('02 onwards is):
1st 1.866:1 (1 tooth extra on countershaft)
2nd 1.470:1 (Standard)
3rd 1.210:1 (Standard)
4th 1.050:1 (1 tooth less on mainshaft)
5th 0.952:1 (2 teeth less on mainshaft
Overall spread is 49% (even with lower 1st) against 51.7% of the standard box.
We also have a 0.909:1 alternative 5th gear (1 tooth lower).
The combinations we use are:
Standard box
Standard box with low first
Standard box with 1 tooth lower 5th
Standard box with low first and 1 tooth lower 5th
Full close box
Our 6-speed box is undergoing a little re-engineering and I will post details when available.
Regards
Ian  _________________ Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
Championship winning Superkart race team 1997-2012 |
Chuck Bunnell
Joined: 18 Jul 2001 Posts: 558 Location: United States, Ohio, Chardon
Posted: Mon Apr 14, 2008 12:58 pm Post subject: |
| Thanks guys. Saves me from counting teeth over and over. |
Andy Kiker
Joined: 22 Nov 2003 Posts: 460 Location: United States, New Jersey,
Posted: Mon Apr 14, 2008 1:11 pm Post subject: |
WOW Ian, You must have some tight turns over there to need a lower 1st.
That or it must be good for doing burnouts or standing starts.
Never mind. I get it, with the lower 5th you may need a lower 1st. It takes me a little while to catch on.
So you have 5 different gear sets that you can use depending on the track you are going to. Each gear set will have its advantage at different tracks depending on track layout and turn speed. All you need is 5 motors set up with each gear set. or if you know what gear set works best at a certain track you just split the cases and put it in for that meeting. If you guess wrong just split the cases at the track and change it. Boy that sound just Great  _________________ Andy Kiker #24
Anderson Karts
WiWa GasGas
Powrpad |
Ian Harrison
Posted: Mon Apr 14, 2008 4:51 pm Post subject: |
Hi Andy
Pretty fair assesment So I increase your order to 5 motors then
Now I'm not driving anymore, I need something to do at race meetings
Of course with our cassette gearbox (sideloader), it's a breeze, 15 minutes for ratio changes - - - - - - - - - - - - - - - - - - -joke ).
Regards
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Roger Miller Site Admin
Joined: 19 Jul 2001 Posts: 2917 Location: United States, California, San Jose
Posted: Mon Apr 14, 2008 5:43 pm Post subject: |
| Is the '02 and up stock ratios the same as those Dan posted for the '01? Or is there a difference? |
Ian Harrison
Posted: Mon Apr 14, 2008 6:35 pm Post subject: |
Hi Roger
Standard ratios are the same for the '02 onwards.
The differences from the '01 are stronger (wider) 5th gear and 13 spline shafts rather than the 6-spline shafts of the '01
We have a prototype kit in development to allow the (wider)'02 cluster to be fitted to an '01 without any machining.
Regards
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Andy Kiker
Posted: Tue Apr 15, 2008 7:36 am Post subject: |
Let me think about this. 5 CRs or one GasGas. Boy that is a hard decision.  _________________ Andy Kiker #24
Anderson Karts
WiWa GasGas
Powrpad |
Dan Davis
Posted: Tue Apr 15, 2008 10:04 am Post subject: |
Poor Ian...
I'd be good with one Honda 05 CR250 with one 6 speed installed......Unless I can get a Gas Gas package for under 5 g's and be able to completely rebuild it myself using OEM parts that I can purchase without the ridiculous exchange rate and modify if necessary. I kinda thought that was what ICE was originally intended to be. I'm not moaning about it but just pointing out how close to FE the newer kid on the block really is.....awesome is the only word that comes to mind.
Otherwise, discarded GP TZ's in FE sure sounds attractive for similar cash outlay. I sure liked the feel of that package testing at MSR. Soooooo smooth. |
michael beamer
Joined: 25 Jul 2003 Posts: 243 Location: United States, Virginia, north
Posted: Tue Apr 15, 2008 5:53 pm Post subject: Fe |
I think that has been the view of the rest of the world as well. They treat the amazing $13000.00 gasgas as an Fe . But a few genius's in the US think otherwise.Lets see , two of Ian's cr250's with a few thousand left over, versus one gasgas. Not much to consider for most people.Maybe we should start a USHSK seies. Are you listening Bernie?
Beamer |
Erik Frank
Joined: 18 Jul 2001 Posts: 839 Location: United States, Texas, Fort Worth
Posted: Tue Apr 15, 2008 7:15 pm Post subject: |
Gents,
Lets not turn this thread into another CR-250 vs. GasGas bitching contest. I wanted this topic to be a repository for CR-250 info.
-erik _________________ Member of the Fisher-Price Racing Team |
Dan Davis
Posted: Tue Apr 15, 2008 8:34 pm Post subject: |
Thx Erik, I didn't mean to help turn on the ICE blender. I'm really perfectly content competing in USSK's experimental "SS" classification. I do not think the Gas Gas should be in FE. I think it belongs right where it is. So what if a fast driver beats many of the FE karts. A fast driver in a Honda will beat some of the Gas Gas powered karts out there too. The rules including it in the US ICE class existed long before this debate started. MSR showed a good turnout for "SS" proponents so things seem just fine with racing OEM based Honda's in USSK. With that said, I'm sorry I'll not be able to attend Eagles Canyon but I'll be shooting for Mid Ohio with some new setups to work with. So bring your Honda's out & support US superkart racing where you can....at the moment it is the only way to race with a good number of superkarts in North America with exception to the USKGP events.
Oh yea....a litte contradiction in my last post......the OEM 5 spd will due for the $$ & class sake....sorry Ian. I'm sure that you will come up with a contender for the all out CR250 cased GP package. It'll be interesting to see how it all unfolds for sure.
Back to work... |
Andy Kiker
Posted: Wed Apr 16, 2008 8:15 am Post subject: |
Sorry Erik, I did not intend to do that either. The point I was trying to make was that to have all available gear ratios could be expensive.
As Dan said they are not oem based and would not be legal in a oem class. _________________ Andy Kiker #24
Anderson Karts
WiWa GasGas
Powrpad |
Ian Harrison
Posted: Thu Apr 17, 2008 10:51 am Post subject: |
Hi Guys
I'm with Erik on this one too.
I thought Andy was just pulling my leg (as usual!!), but of course he has a perfectly valid point.
I always pull the motors down between meets, so what we actually do is change ratios then. As we know all our tracks well, selection is easy.
Our gearbox regulations are free as long as you use the same number of ratios (i.e. five), so it's all perfectly legal (for us).
With the 6 speed box we wouldn't need to change ratios, but this is not allowed for us.
Regards
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Ian Harrison
Posted: Sat Apr 19, 2008 3:21 am Post subject: |
Hi Guys
Just to round off on Andy's comment/question.
The one tooth lower top is £127.50
The close box (which includes the low first) is - £375.00
So that's £502.50 for the full set to give our 5 options . Just damn that exchage rate for you guys .
Apologies for getting commercial, but the question was raised.
The 6-speeder is nearly ready and I'll post details when it is fully tested. As Dan says this is no good for the your SS (or ICE?) class and will probably see light-of-day in the US at VIR and hopefully Laguna .
I have one US driver chomping at the bit and heading the queue (in Pole Position you might say ). Let's hope we can put the deal together and put on a good show for you all with the "Super CR250" whatever stage it is at by then
If it comes off. both our karts twin and single may be for sale after VIR.
Best Regards
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Last edited by Ian Harrison on Sat Apr 19, 2008 6:52 am, edited 4 times in total |
