Andersen Racing - LB
Darcy DeCoste Racing - Double Button
Decal Zone - Button
Ocala Gran Prix
KartSouth.com
Corsa Racing Kart America - Button
High Rev Engineering
Helmet Cams
Brad Wunder
PostPosted: Wed Mar 14, 2007 10:41 am    Post subject: Helmet Cams Reply with quote
OK, so I took one of the NFRA helmet cams out to our 2nd test session day to give it a try. The output wasn't tooooo bad considering how inexpensive (yes cheap) the camera is. One thing that I'm looking for help on is sound quality. If you check out the video links below (especially part 1) you'll notice that when the motors fire up things sound great. Once on the track, however, the wind noise takes over most of the time. So my question is, does anyone with experience with these things have any suggestions on how to eliminate or at least reduce the wind buffeting noise?
http://youtube.com/watch?v=R-aS1jBtQZU
http://www.youtube.com/watch?v=usozZiO1pog
Thanks for any suggestions/thoughts you might have.
Brad Wunder
Brad Wunder
President, NFRA
www.norcal4cycle.com
Thom Andresen
PostPosted: Wed Mar 14, 2007 11:05 am    Post subject: Reply with quote
Just putting a windsock over th external mic will keep out the wind blast, however my problem is that once I get over 8,000rpms, the electrical static is terriffic. Sitting so close to the resistor plug and the CDI unit, there is no way to get away from it. Don't know how to shield all that out?
http://video.google.com/videoplay?docid=-5130918925738946970&hl=en
Happiness is a warm gun.
Mike Spear
PostPosted: Wed Mar 14, 2007 12:57 pm    Post subject: camera Reply with quote
Your mic doesn't have to be "outside" I keep mine in the battery bag with the batteries that power the camera. I get no wind noise or static and you can hear the engine just fine.
Here is a video you can look at to see what I get with my set up.
Road Ameraica Video
Mike Spear Sr.
rider_61wing@yahoo.com
www.spearmotorsports.com
Powered by WIWA Gas Gas
Kurt Raisley
PostPosted: Wed Mar 14, 2007 1:44 pm    Post subject: Reply with quote
What is a NFRA helmet cam, where do you get them and what is the cost. Your video looked pretty good.
Brad Wunder
PostPosted: Wed Mar 14, 2007 2:31 pm    Post subject: Reply with quote
At the risk of sounding stupid, what is a wind sock? Laughing I don't really have the option of locating the mic away from the camera lense as it is built-in.
Kurt, the cameras we are using in the NFRA are the Tony Hawk hemet cams. They go for anywhere from $49 to $80. Video/audio is recorded on SD cards. The NFRA camera #1 has a 2GB card which will record about 2 1/5 hours. Cams 2 & 3 are equiped with 1GB cards.
Brad Wunder
President, NFRA
Greg Nelson
PostPosted: Wed Mar 14, 2007 3:54 pm    Post subject: Reply with quote
A wind sock is the foam cover over the mic, supposed to reduce wind noise over the actual mic surface.
Motohead
Mike Goebel
PostPosted: Wed Mar 14, 2007 6:19 pm    Post subject: Reply with quote
Put a piece of duct tape over the mic.
Mike G.
Patrick Hubbell
PostPosted: Wed Mar 14, 2007 8:45 pm    Post subject: Reply with quote
I have a HelmetCam.com brand of camera that has an external mic. They put the mic in the housing with a hole drilled to accept audio. They also make a mic that you can clip on inside the helmet. The later bypasses the mic that mounts on the helmet.
Patrick Hubbell
www.kartproducts.net
408-569-7317
Kart Start(tm)
Patrick Hubbell
PostPosted: Wed Mar 14, 2007 8:51 pm    Post subject: Re: camera Reply with quote
Road Ameraica Video
Mike, that sounds awesome. What type of kart/engine was that?
Patrick Hubbell
408-569-7317
Kart Start(tm)
rick schmidt
PostPosted: Fri Mar 16, 2007 11:55 am    Post subject: Reply with quote
http://youtube.com/watch?v=l2Eel5mcUmc
We found clipping it in the driving suit works well.
Rick
Jeffory Mott
PostPosted: Fri Mar 16, 2007 12:35 pm    Post subject: Reply with quote
Rick. What camer did you use? I note the NFR cam is very jerky and yours seemed to capture video without the jerks.
Tim Benoit
PostPosted: Fri Mar 16, 2007 11:52 pm    Post subject: Re: Helmet Cams Reply with quote
Brad Wunder
Hey Brad I did'nt know you were behind me in that second video I was chasing my son hear is a video I took a few months back
http://video.google.com/videoplay?docid=-1862462580356811726
Famous last words
Hey Watch this
Copyright © 2002 - 2010 Ekartingnews.com. All Rights Reserved.       Maintained by Holbi LLP
DB time: 0.116799 (36.68%), total time:0.318404, queries:34
