Acceleration - LB
Ribtect - SS (non-flash)
KG Plastics - FB
won't run, advice please
Goto page Previous  1, 2
Scott Nagler
PostPosted: Tue Aug 01, 2006 4:23 am    Post subject: Reply with quote
hrm, I mounted mine to the motor at the hoisting point.... got a Honda Coil bracket from ebay and used some rubber bits and clevises from Home Depot to dangle it in a good spot that is well grounded and absorbant
Still a noob, but can't wait to be "on the pipe"
Vic Madrid
PostPosted: Tue Aug 08, 2006 8:48 am    Post subject: got new ignition coil Reply with quote
so the new coil arrived yesterday, and it's not the same as what I had. I ordered the stock '99 coil, and it is much smaller than the one that I had been running. Does this matter? (other than I have to fabricate a new mount).
- Vic
- SCCA/WDCR F125 #54
- 2006 Tony//Kart Krypton 125
Vic Madrid
PostPosted: Sat Aug 12, 2006 10:46 am    Post subject: Reply with quote
just to finish the story, it was the coil. And the short one seems to work just fine. Back in the saddle! Very Happy
- Vic
Scott Nagler
PostPosted: Mon Aug 21, 2006 1:22 am    Post subject: Reply with quote
yeah the newer coils are smaller, partic the Honda ones... congrats man run'r hard n have fun
randy hofferbert
PostPosted: Mon Aug 21, 2006 5:53 am    Post subject: Reply with quote
So, jetting wasn't the answer. Vic, you're still my role model. Wink
Alan Sheidler
PostPosted: Tue Aug 22, 2006 10:08 pm    Post subject: Reply with quote
Yeeha! Glad you got it back up and blasting.
Not sure when Honda changed to the smaller coil. My '96 motor has the bigger one, the '99's I have seen use the smaller. Slightly different connection styles, otherwise interchangeable.
About coils, and this is ALL IMHO: Bolting them tight to the top of the engine is asking for trouble. The ultrasonic vibration buzzing through the head means to me it is no place for an electical device, or anything which is not a slug of aluminum or rubber. That said, I have used a longer intake bolt with three nylock nuts (two to hold the coil end between steel and rubber washers, and one to hold the intake tight) and a seperate very stiff (8GA?) wire bolted to the other end and the motor to act as a ground. The whole deal then remains flexible, and allows a fairly short plug wire.
I also think that they can be damaged by water infiltration. The dirtbike location is up under the tank or seat. pretty much away from water unless the whole bike takes a dunk. I think it best to seal the openings between the plastic outer coating and the center bar/plates with silicone. I used black so it is not noticeable.
You bringing that sucker to Topeka? Garfield won't feel right without all of the usual DC crowd around. Wink
Alan
Vic Madrid
PostPosted: Wed Aug 23, 2006 10:25 am    Post subject: Reply with quote
not looking good, Alan. Work circumstances are a big reason. Hopefully 2007 will let me do more Nat'l level events. But if Brian and Mike do well enough in Topeka, I'll have my own Nat's every month locally! Shocked
Vic
- Vic
Page 2 of 2
DB time: 0.341121 (60.98%), total time:0.559435, queries:38
