Bob Monday
Posted: Wed Nov 23, 2005 11:35 pm Post subject: 250 shifter |
A friend wants to assemble a shifter just to keep himself in shape for other forms of racing. All he's going to do is run laps, and frankly, he's not much for "maintenance"... even basic stuff. He's also 230#+, so wants more "umph" than a stock 125.
What 4-cycle engines seem to work well on a 125 shifter chassis? We don't want to have to fabricate a lot of parts (motor mounts, J arms, etc.) if we can avoid it. This kart will not be used for any racing, so doesn't have to meet any particular rules.
I have a chassis, so all we need is to put a motor on it. Suggestions, especially if you've done it? If you're speculating, pls say so!
Bob Monday |
Ted Long
Posted: Thu Nov 24, 2005 1:02 am Post subject: |
| CR450F!!!!!! Got the oomph and plenty more. Plus its very similar to mounting a 125, so not a whole lot of mods needed. |
Larry Andrews
Joined: 13 May 2002 Posts: 2847 Location: United States, California, SC Mtns
Posted: Thu Nov 24, 2005 9:39 am Post subject: |
| I'm pretty sure that the guys at PSR have built a mount for the 450. The CRF engines have a big advantage of not needing an external oil tank like the Yamaha 4/S's do. Exhaust might have to be a custom job...probably do-able with a length of flex stainless following the stock headpipe, and a custom bent tube running to a supertrapp on the back bumper. |
Brendan Wales
Posted: Thu Dec 01, 2005 6:16 am Post subject: |
^ He said he DOESN'T want a lot of maintence.
A 450 would be a bad choice in that case. |
Danny Lerner
Joined: 08 May 2005 Posts: 188 Location: United States, New York,
Posted: Thu Dec 01, 2005 5:38 pm Post subject: |
Check out the kawasaki ninja thread. I have been doing some research on the topic. The EX250 Anderson combination is slightly faster than cr125s on a long track - from what I have heard so far.
Scroll to the next to last post on the kawasaki thread (should be mine). The link in that post has pictures of the EX250 kart. Tooling will definately need to be done to build this kart. I have searched hi and low for a 4 stroke 250 motor that is reliable and will fit on the kart. This is the only compromise I have seen yet. AND, it IS a compromise because of its size...
If he wants more umph, he should really consider a stock cr250. I don't like 2 strokes because of the maintenance level, and because I have reliability issues with them, but a stock cr250 is about as reliable as 2 strokes can get, and have tons of power. No matter what your friend does, he is going to have to do basic maintenance. There are no real shifter karting specific engines that are even slightly maintenance free.
Danny |
Bob Monday
Posted: Thu Dec 01, 2005 6:25 pm Post subject: Weakness |
What's the weakness(es) of the CRF450?
A 4-stroke would have to be less maintenance than a 2-stroke, and easier to fabricate an exhaust system. |
Danny Lerner
Posted: Thu Dec 01, 2005 6:34 pm Post subject: |
From what I understand, the crf needs somewhat constant valve attention?
Danny |
Ted Long
Posted: Fri Dec 02, 2005 12:05 pm Post subject: |
Put your friend on a diet!! lol
I agree with Danny about the cr250, its a good motor and it will go for a while before it needs anything. You won't find a "maintnance free package" anywhere though, so he'll just have to learn to work on whatever he ends up with. |
Josh Schultz
Posted: Sat Dec 03, 2005 11:17 pm Post subject: |
| How about an XR400? They are air cooled so you don't have to screw with the radiator, very reliable on a bike. They only make 35hp but how much power do you need just to keep in shape for other motorsports? |
Bob Monday
Posted: Sun Dec 04, 2005 2:44 pm Post subject: How Much |
He wants to keep up with me. It's no fun to run "with" someone if they can leave you without notice. I saw a couple 450s sell on ebay last week. Combining that with a fairly stiff CRF chassis I already have would make an affordable toy.
Bob |
Danny Lerner
Posted: Sun Dec 04, 2005 4:39 pm Post subject: |
| Brendan Wales wrote: | ^ He said he DOESN'T want a lot of maintence.
"From what I understand, the crf needs somewhat constant valve attention? "
Might as well get him a stock cr250.... Only disadvantage is you have to mix gas/oil....
Danny |
Bob Monday
Posted: Mon Dec 05, 2005 5:59 pm Post subject: 250 vs 450 |
It would seem that a 2 stroke is going to be a lot more sensitive to pipe and jetting than a 4 stroke. He wants to unload and run some laps, not hunt for the right jet for 45 minutes.
It always seemed like a bad design idea to mix fuel and oil and call it "lubrication".
If anyone runs across a stock 450 that seems affordable, let me know. A totaled bike would probably be ideal as we'd get all the ignition stuff, too.
Bob |
