SoCal Sprinters
SuperKarts in A-Mod?
Ryan D Thompson
PostPosted: Tue Sep 27, 2005 7:02 am    Post subject: Reply with quote
Larry Andrews wrote:
Brian, I think that you might be mistaken when it comes to making *any* class that can be imagined, locally. There are insurance restrictions...
As far as I know the SCCA insurance restrictions do not go up. Currently we run a time only class here in atlanta where you can run anything you want. I think the only restrictions we have are not SUV's since their CG is way up high.
Brian Garfield
PostPosted: Tue Sep 27, 2005 8:55 am    Post subject: Reply with quote
Larry, for the Junior Karts, since the SCCA self insures, the minors cannot be in a kart that's faster than FJ4 overall. However, there's nothing in the rulebook about disallowing other classes for adults.
Now, if you ask for a clarification, you may get one. But, for the purpose of "250 Heavy" we'd probably be ok because we'd be shooting for the same power/weight ratio as F125 to help the guys that are 200+lbs. (notice how I'm not saying ADD weight to the F125 class to allow heavy people to be competitive...)
"They" usually encourage making classes to suit your Region's needs when possible. If the 250 class exists for karts and isn't faster than A Mod, it would probably be fine.
Andrew. james
PostPosted: Tue Sep 27, 2005 9:54 am    Post subject: Reply with quote
A local class would be up to the chairman and local safety stewart.
Alan Sheidler
PostPosted: Tue Sep 27, 2005 11:32 am    Post subject: Reply with quote
BZZZTTT!
Sorry, you are wrong about that. There is a specific line in the rules book which states something like: 125CC shifter karts are the fastest (read as most powerful) karts allowed. Going outside that rule for even a local event risks running without sanction/insurance. If you doubt it, drop an inquiry to the SEB.
Alan
Brian Garfield
PostPosted: Tue Sep 27, 2005 12:23 pm    Post subject: Reply with quote
Alan Sheidler wrote:
BZZZTTT!
Alan
Alan, feel free to quote something that says that. I looked pretty darn hard before I posted.
Also, keep in mind not to look under the "F125" class. We're not talking about running faster karts IN F125, we're talking about starting another class for local events to fit the needs of the members. I just looked again and found nothing as you state.
I may be missing something, but again, you'll want to quote that for me to prove me wrong.
BTW, I'm on the committe in this region, so it would be important that you prove me otherwise. We're not seriously considering this right now, but the information would be valuable should it come up.
Also, I don't see where there would be a problem if you have 500lbs (person in the high 200's) on a 250cc vs. 385 on a 125cc.
EDIT: Here is what you're probably seeing in 19.1.D.1:
"Moto: Engines must be mass-produced, single cylinder, motocross, motorcycle engines up to 125cc displacement and of the current year's production or older."
AND:
19.1.D.3:
"Other Engines: Engines must be either a) mass produced single cylinder two-stroke engines not to exceed 125cc or b) mass produced single or twin cylinder, four-stroke engines not to exceed 250cc of total displacement."
Anyhow, both of the above rules fall under the CLASS of F125, this says nothing about another class and again, nothing I've found excludes the idea. So, if the intention is to not allow any faster karts, no matter what class, the KAC will need to clarify that somewhere else in the rulebook.
Appendix G would be an appropriate location as far as I can see, but says nothing to that effect.
BTW Alan, I'm not trying to argue with you, I'm just trying to make sure that if that's a base that is 'supposed' to be covered, it's not.
Alan Sheidler
PostPosted: Tue Sep 27, 2005 2:52 pm    Post subject: Reply with quote
Well I'll be darned, Brian. It looks as though I have just been around too long, and am recalling wording from past year books. The first one I put my hands on, because it was by the computer, is from 2002. In that book, the Appendix G heading was "Karts at Solo II Events" Section III.A stated: "Kart eligibility is limited to racing karts recognized and regulated by a national kart sanctioning organization (WKA, IKF, ISRA, NSKA, etc.) with a maximim of one 125cc engine. 125cc shifter karts are the fastest karts allowed."
Because of the way in which it was worded, the rule did not just apply to the F125 class, it was a general statement about karts at SCCA sanctioned autocrosses. It was that which I was remembering. I don't have the 2004 or 2003 books handy....
As happens when rules are transferred from one section of the book to another, some wording is changed or omitted which can be construed as a change in policy or legality. When F125 was made a National Class, and taken from Appendix G's "Karts at Solo II Events" to section 19.1's "F125", it seems as though the previous intent and supporting wording was lost.
While I don't personally have an issue with a local "250 Heavy" class, the SEB might. Before a wheel turns under 250 2-cycle gearbox power at any SCCA autocross, I'd highly recommend a clarification from the SEB. The time to find out is before, not after, the tire burning begins. Laughing
Thanks for bringing it up, and pointing me to the CURRENT rule book.
Alan
BZZZTTT!
Alan
AND:
19.1.D.3:
Mark Brown
PostPosted: Tue Sep 27, 2005 2:58 pm    Post subject: Reply with quote
Try this
Appendix G Section III Paragraph A
NSKA, etc.) with a maximum of one 125cc engine. 125cc shifter
This was taken from SCCA National Solo 2004 Rules
Personally I would like to be able to run my Anderson superkart at a Solo event, but I really think it would be a bit much. A 250 on a sprint type chassis would work much better IMHO. But I would have to ask why? The 125's work pretty dang good. We are not in AM were are in F125. I still try to beat thier times anyway. Some times I do, some times I don't.
Brian Garfield
PostPosted: Tue Sep 27, 2005 3:03 pm    Post subject: Reply with quote
Good to know Alan, I figured you weren't "wrong" but I wanted to be sure there wasn't something I was missing.
I wouldn't plan on doing something like that without checking on it, but I'm glad to know there used to be something there.
I had remembered something as well, but when I looked it up in the '05 book, I figured it must have just been the passages in there that didn't apply.
Anyhow, we'll give them a heads up. I'll check on an approval for an "F250 Heavy" class as well, just to know for the future.
Mark,
EDIT: YEP! Sure enough, the 2004 book has the section you refer to, but that entire section "III. Kart Eligibility" is not even in the 2005 book. Actually, neither is section "IV. Safety", however, it's covered in the F125 Class section.
Andrew. james
PostPosted: Tue Sep 27, 2005 3:34 pm    Post subject: Reply with quote
I would not be in f125 so those rules do not apply. If it's not listed as banned in the appendix then the arguement can be made that it is allowed to run. Time only would probably be the only class it's allowed in but as far as I can tell it's allowed. Send a letter to KAC and ask is the best bet.
Vernon Head
PostPosted: Tue Sep 27, 2005 4:03 pm    Post subject: Reply with quote
Before you get too excited about 250 cc. karts, I should tell you that a few years back SKUSA allowed them at Supernationals. I can no longer find any results archives, but I do know that they were slower than the 125s. This is not to say that they wouldn't be faster in the hands of the top drivers but it's food for thought.
Brian Garfield
PostPosted: Tue Sep 27, 2005 6:56 pm    Post subject: Reply with quote
Vernon, I assume you mean the 4 stroke, not the 2 stroke. We (or at least I) was referring to a 250 2 stroke, clearly much faster.
However, the 250cc 4 stroke IS legal for F125.
Vernon Head
PostPosted: Tue Sep 27, 2005 7:25 pm    Post subject: Reply with quote
I do mean the 2-stroke. I read about it in Shifter Kart Illustrated. The 250 class were good drivers, just not at the level of the 125 drivers. The class was also fairly small, which is probablyl why they eventually dropped it.
Vernon Head
PostPosted: Tue Sep 27, 2005 7:36 pm    Post subject: Reply with quote
Don't believe me? I found these two results pages from 1999 Supernationals:
First go to: http://209.35.195.160/supernats99/final_80jr.htm
Then go to: http://209.35.195.160/supernats99/final_250.htm
Even the 80 juniors were faster than the 250s. Actually a second faster in qualifying.
Brian Garfield
PostPosted: Tue Sep 27, 2005 7:56 pm    Post subject: Reply with quote
Point taken. Although, we all know the driver can make all of the difference. It's easy though to make the generalization that when a class is that much smaller, the talent pool is as well.
Also, is there even a power/weight difference. If the 250 has to carry too much weight, it won't be any faster.
Bob Monday
PostPosted: Tue Sep 27, 2005 9:07 pm    Post subject: 250s Reply with quote
Vernon brought the data for the point I was thinking as I read the thread. The 250s have higher top speed when running "long tracks", but additional weight works against them in sprint tracks and lower speed stuff. Their forte is horsepower, and it's hard to really use that "extra" on stuff as tight as an autocross course.
Bob Monday
Page 2 of 3
DB time: 0.130058 (35.41%), total time:0.367312, queries:38
