SoCal Sprinters
Streeter - SS
Tony Kart/Vortex - FB
Tell me what you feel is the fast setup.
Goto page Previous  1, 2
Vic Madrid
PostPosted: Thu Sep 29, 2005 12:00 pm    Post subject: Reply with quote
Brian Kay wrote:
Sprint / Autocross: Ackerman GOOD
Road race: Ackerman BAD
Ackerman allows your chassis to turn 180 degrees on a dime, but only creates scrub (drag) in high speed, steady state turns.
Not being at home right now to look for myself, which set of holes creates more ackerman? The outside or the inside holes? (running OEM TonyKart Mitox spindles) Thanks!
- Vic
- SCCA/WDCR F125 #54
- 2006 Tony//Kart Krypton 125
Steve Elzinga
PostPosted: Thu Sep 29, 2005 1:56 pm    Post subject: Reply with quote
The inner set of holes on the axles will increase Ackerman. If your kart is like mine it may also have adjustments on the steering column. The outer holes there will increase Ackerman. I am running mine on the outer holes on the column and the middle holes (3 holes on my kart) on the axles. I'm still curious what others are running or have tried and what the results were. I haven't had much testing since I made this change. All of the events I have run so far have been with parallel steering and I don't think that is the right way to set it up for autocross. I didn't want to jump right to the max setting either. Anyone else have any experience trying the different settings for autocross?
Larry MacLeod
PostPosted: Thu Sep 29, 2005 3:33 pm    Post subject: Reply with quote
Really? I didn't even notice when I drove it at the Tour back in June. Most karts I've seen have at least some ackerman. I use the offset holes on the steering shaft of my old Birel. Combine that with running a wide front end, I've got very quick steering turn-in.
I like it that way, though. Maybe I didn't notice it on your kart because of the course we drove there. That wide-open, all fast sweeper course really didn't need any ackerman.
Just a thought.
F125 #196
Lefty Funk
Detroit Region
Ryan D Thompson
PostPosted: Thu Sep 29, 2005 4:20 pm    Post subject: Reply with quote
Does anybody have any pictures of using the inner holes on the steering column. I've been looking at my kart and don't see how the two tie rod ends would fit in the same place. This would be trying to get 0 ackerman.
Steve Elzinga
PostPosted: Thu Sep 29, 2005 6:52 pm    Post subject: Reply with quote
I noticed it more on the Pro course which was a lot tighter. I had originally just been driving the kart the way it came, now that I am more used to it I want to make some changes. I really didn't like the way it handled on the tighter course and I think some more Ackerman will help.
Ryan, on my kart there are spacers around the rod ends. To use the center hole you can remove the spacers and stack them so they both share the same hole on the column.
Andrew. james
PostPosted: Thu Sep 29, 2005 7:06 pm    Post subject: Reply with quote
Ryan, one would sit ontop of the other. At least thats how I did it on mine.
Bob Monday
PostPosted: Thu Sep 29, 2005 8:57 pm    Post subject: Steering shaft Reply with quote
There are usually some spacers on the tie rod bolts at the steering shaft end. Taking out all the spacers will usually give JUST enough room to put both ends on the same bolt. Depending on some angles there, the steering shaft can rub on the nuts that lock the tie rod ends... unscrewing them. Check them often when running this configuration.
Bob Monday
Nathan Fowler
PostPosted: Tue Oct 11, 2005 6:12 pm    Post subject: Reply with quote
Andrew,
Michael Fiyak and I compete in the Tennessee Valley Region. I just started this year, but Michael has been at ift for two years I believe. As soon as Shelton Wright turns 16 he will be the third shifter in our region.
I guess we need to make a trip down to Atlanta and play? Laughing
#96 - 2000 Trackmagic Demon / Stock Honda
Andrew. james
PostPosted: Wed Oct 12, 2005 7:54 am    Post subject: Reply with quote
Nathan Fowler wrote:
Andrew,
I met mike at the dothan divisional he's a nice guy, kicked my ass pretty good too. You guys definitely need to come over to Atlanta sometime. I'm sure you already know but here is our schedule for the rest of the year. http://www.soloatlanta.com/fschedule.htm
matthew brueck
PostPosted: Wed Oct 12, 2005 12:55 pm    Post subject: Reply with quote
Andrew,
My dad and I will be running the kart next year when I turn 16 in Atlanta. In the meantime we will run at the track.
04 CRG Road Rebel ICC
Page 2 of 2
DB time: 0.154087 (45.53%), total time:0.338427, queries:38
