Bondurant - LB
RLV - SS
DRT Racing - FB
Ignition Curves
Goto page Previous  1, 2
John Denman
PostPosted: Wed Aug 15, 2001 4:57 am    Post subject: Ignition Curves Reply with quote
quote:
Originally posted by Bob Chiras:
Just look at the stock boxes at about $160 each. We would all have to own 5 or more.
Bob,
Do you know what the timing curves are for these 5 models of OEM boxes? If so, could you let us know?
Bob Chiras
PostPosted: Wed Aug 15, 2001 6:20 am    Post subject: Ignition Curves Reply with quote
I have the curves. I'll have to get them from the device which we have to read the boxes. Send me your email address and I'll send you the curves.
I'll send the years needing replacement stator and rotors as well.
Mike Speed
PostPosted: Wed Aug 15, 2001 8:36 am    Post subject: Ignition Curves Reply with quote
quote:
Originally posted by John Denman:
Mike,
Will the new PI be programmed via PC? It would seem to make the most sense to use a PC and a serial port connection along with some VB or JAVA software to write to the PROM on the PI. That way programmability would be within reach of the users as it should be pretty low cost.
The programmer is (and will stay) PC based using the RS232 port. The software will run on Windows 3.1,95,98,2K & NT
John Denman
PostPosted: Wed Aug 15, 2001 9:17 am    Post subject: Ignition Curves Reply with quote
quote:
Any projections on cost? As I recall from the SPI unit the software and cable was priced at roughly twice the cost of the PI itself. Brings the cost to have a complete Programmable unit up to the $1200 neighborhood right?
Todd Bellew
PostPosted: Wed Aug 15, 2001 3:35 pm    Post subject: Ignition Curves Reply with quote
When I bought my Vortex programmer it was 1200 dollars for that one little disc. So those prices are in line with currently available products.
Plus, while the Vortex software provides the curves for all sorts of years of different model bikes. However, there has been some question to how accurate they are. Many times when the stock ignition was tested back to back with a programmed box with the stock curve for that year, results were different. Why? I have an idea but not sure.
Bottom line, there are many other factors involved in producing a good ignition box, besides just the curve.
Todd BEllew
John Neilson
PostPosted: Wed Aug 15, 2001 5:02 pm    Post subject: Ignition Curves Reply with quote
I think the light bulb is on and getting brighter!! Over the last 6 months or so, there has been a lot of talk about PI's and the legality for next year. Besides that, I think people are finally starting to see what the final result from optimizing the ignition is. No longer do you have to compromise the ignition timing due to the non-adjustable factory boxes. We have been working with Speed's CR80 unit, in a word,
FANTASTIC. Thanks, Mike!!
John
Mike Speed
PostPosted: Wed Aug 15, 2001 7:22 pm    Post subject: Ignition Curves Reply with quote
Ok Here is the stock box timing points. (the box ith the white stamp).
10.0 20.0
10.5 17.5
11.0 15.0
11.5 17.2
12.0 9.6
12.5 7.3
13.0 5.7
13.5 5.0
14.0 5.0
14.5 5.0
John D. the programmer price is still the same price.
Mike
Page 2 of 2
DB time: 0.116543 (38.51%), total time:0.302668, queries:37
