MaxSpeed - LB
MG Tires - SS
Franklin / Merlin USA - FB
FAQ: Topics of repeated discussion
Post new topic   This topic is locked you cannot edit posts or make replies    eKartingNews.com Forum Index -> Tech Talk
Pete Muller
PostPosted: Sun May 08, 2005 3:06 pm    Post subject: FAQ: Topics of repeated discussion Reply with quote
Hi all,
Since there are certain questions that are repeatedly asked in this Forum, I've decided to make a "sticky" message that references these frequently debated/discussed topics.
I will edit this page from time to time and keep it as updated as possibly.
Pete Muller
moderator - Tech Forum
_____________
Frequently asked questions / discussed topics
Gear ratio thread / same ratio using large or small sprockets?
http://www.ekartingnews.com/viewtopic.php?t=2673
Honing cylinder bores and fitting rings.
http://www.ekartingnews.com/viewtopic.php?t=25643
Rotating weight vs. static weight / moment of inertia
http://www.ekartingnews.com/viewtopic.php?t=22813
Cryo treating of parts
http://www.ekartingnews.com/viewtopic.php?t=3233
http://www.ekartingnews.com/viewtopic.php?t=2763
Oil mixing ratios / castor vs. synthetic oil
http://www.ekartingnews.com/viewtopic.php?t=22724
Axle bearings; std vs. ceramic / lube for axle bearings
http://www.ekartingnews.com/viewtopic.php?t=33287
http://www.ekartingnews.com/viewtopic.php?t=118723
Axles; size vs. hardness vs. flex
http://www.ekartingnews.com/viewtopic.php?t=39356
Pop off pressure in the carb
http://www.ekartingnews.com/viewtopic.php?t=85124
Muller Machine
How-to pages, tech documents, & more
Ultra-precision machining/blueprinting for engine builders
Post new topic   This topic is locked you cannot edit posts or make replies    eKartingNews.com Forum Index -> Tech Talk All times are GMT - 8 Hours
DB time: 0.067163 (35.3%), total time:0.190246, queries:38
