Bondurant - LB
Ribtect - SS (non-flash)
Leading Edge Motorsports
Tuning a Keihin PWM???
Gary Osterholt
Site Admin
PostPosted: Fri Aug 10, 2001 3:34 pm    Post subject: Tuning a Keihin PWM??? Reply with quote
Last weekend, I got my new carb. It's a Keihin PWM.
This may sound like a dumb question.
But how can you tell if the carb is rich or lean?
I'm using only watch water temperature. Can you tell if the carb is lean or rich from the water temperature?
I had trouble getting off the line, seems like no matter what I did.
Gary Osterholt
www.garyosterholt.com
Patrick Ashby
PostPosted: Fri Aug 10, 2001 3:49 pm    Post subject: Tuning a Keihin PWM??? Reply with quote
Gary, tuning of the khein carb is just like any other. You should be able to tell if the carb is rich or lean by reading your plug. If the porcelan is whit you are lean if its dark then you are rich. This is a very general statement though, there are many other variables in reading a plug but generaly this is true. In terms of getting offf the line, you can possibly improve your starts by adjusting the needle setting. If you want I can go into more depth but this should help you get pointed in the right direction.
Gary Osterholt
Site Admin
PostPosted: Fri Aug 10, 2001 3:58 pm    Post subject: Tuning a Keihin PWM??? Reply with quote
Patrick,
Thanks.
Here some more info.
-First heat
way too lean, plug was pretty darn white.
=Riched the pilot and main both one size.
-Second heat.
plug looked good, still couldn't get off the line good.
=moved the needle up
-Third heat
still couldn't get off the line.
My problem is knowing what to change.
You have the main jet, pilot jet, air screw, needle position.
I just get confused sometime. Is there a book I can read or something.
Gary Osterholt
Bill Givens
PostPosted: Fri Aug 10, 2001 4:42 pm    Post subject: Tuning a Keihin PWM??? Reply with quote
Gary...go here for a good start...
Carb Tuning
Gary Osterholt
Site Admin
PostPosted: Fri Aug 10, 2001 5:22 pm    Post subject: Tuning a Keihin PWM??? Reply with quote
Bill,
Thank You
Gary
Matt Kull
PostPosted: Fri Aug 10, 2001 7:14 pm    Post subject: Tuning a Keihin PWM??? Reply with quote
you might also find this very helpful. this is what the guys that tune the rs125 GP bikes use.
OOOps I guess that I should include the link.
http://www.bloke3000.com/125site/Jet.htm
[ August 11, 2001: Message edited by: Matt Kull ]
Matt Kull
PostPosted: Sat Aug 11, 2001 7:42 am    Post subject: Tuning a Keihin PWM??? Reply with quote
If anyone can translate Chineese can you please translate the rest of the information in the diagram found in the link below.
DB time: 0.081955 (45.43%), total time:0.180412, queries:37
