IKF Region 7 - LB
Top Kart USA - SS
Leading Edge Motorsports
CR125 Carb Question...
Dale Nickos
Location: United States, State of Total Confusion, Oak Lawn, IL
PostPosted: Tue Jul 24, 2001 7:25 pm    Post subject: CR125 Carb Question... Reply with quote
Im getting ready to go to St. Louis. And I was wondering On a TM38mm Mikuni Carb...Which slot on the Pin should the clip be??? Im in the Middle and it seems to still dump too much fuel in...But I am told I should run it at least 1/2 way or more open...Due to the Full throttle racing.
Does it make a difference Sprint to Long track...
DN
Rob Hogenmiller
PostPosted: Tue Jul 24, 2001 7:59 pm    Post subject: CR125 Carb Question... Reply with quote
Check out Eric Gorr Website It has lots of useful information on tuning a carbeurator.
Click 2cycle Technology then scroll down.
Carbs are generally tuned for the weather and yes also from a Sprint Track to a Road Track. YOu might be a little richer on a Road Course since you are at higher rpms for greater lengths.
Marc Miller
Advertiser
Advertiser
PostPosted: Wed Jul 25, 2001 2:51 am    Post subject: CR125 Carb Question... Reply with quote
Dale-
Call T-Mac, Trevor McAlister... he uses the TMX Mikuni a lot and also has experience with this carb on his TM as well.
His number is 214-755-3477. He also runs some long track racing too, so he should know what setting you need to start with.
MM
ps- see ya at Gateway
DB time: 0.159761 (43.82%), total time:0.36461, queries:37
