MIR Racewear - LB
K1 Speed - SS
Leading Edge Motorsports
cr80 mount
Scott Minehart
PostPosted: Mon Jul 23, 2001 4:47 am    Post subject: cr80 mount Reply with quote
The mount I have for my CR80 is for a trackmagic. Would this same mount fit a Tony Mitox? Thanks
Scott
Tim Blaney
PostPosted: Mon Jul 23, 2001 6:23 am    Post subject: cr80 mount Reply with quote
Scott,
You're best bet is to call JR at Power Source or a Tony dealer. They should be able to help. If it won't fix, the PSR mounts are excellent.
John Denman
PostPosted: Mon Jul 23, 2001 6:25 pm    Post subject: cr80 mount Reply with quote
Maybe. I measured our Trackmagic to be 90mm center distance between the rails and the Tony (Extreme) to be 92mm give or take a mm, but no less than 2mm diference.
If it does clamp down on the wider rails, you may want a stop bolt to keep the mount from sliding back.
John Denman
PostPosted: Mon Jul 23, 2001 6:26 pm    Post subject: cr80 mount Reply with quote
Maybe. I measured our Trackmagic to be 90mm center distance between the rails and the Tony (Extreme) to be 92mm give or take a mm, but no less than 2mm difference.
Scott Minehart
PostPosted: Tue Jul 24, 2001 7:38 am    Post subject: cr80 mount Reply with quote
Thanks for the info. My Mitox comes in a little over a week from now. I will try to dig up some info. Whats a good place to get Tony parts? thanks
Scott
Larry Ferguson
PostPosted: Tue Jul 24, 2001 8:54 am    Post subject: cr80 mount Reply with quote
I totally agree in regards to Power Source! Awesome product backed by an even better warrantee! Nothing better.
Larry
DB time: 0.307798 (75.2%), total time:0.409307, queries:37
