OTK - LB
MRP - SS
KG Plastics - FB
Carburetor Problems
Scott Loewenstine
PostPosted: Mon Feb 14, 2005 3:26 am    Post subject: Carburetor Problems Reply with quote
Anyone no where I can purchase a Rubber ( Boot ) Flange for a 99 cr250 the ones I am using the carb won't stay in the boot on the track...In addition, sometimes the boot tears as well...
Andy Kiker
PostPosted: Mon Feb 14, 2005 6:13 am    Post subject: Reply with quote
Scott, I think the straight intake for the 250 is 1979 year. Honda dealers should be able to get them. Are you supporting the air filter in some way? If not the bouncing of the air filter and carb may be the problem.
Scott Loewenstine
PostPosted: Mon Feb 14, 2005 7:08 am    Post subject: Reply with quote
Andy what did u use to support your air filter ? And how did u attach it ? Thanks for the quick reply...
Andy Kiker
PostPosted: Mon Feb 14, 2005 11:47 am    Post subject: Reply with quote
I used an alum. strap maybe 1"x1/8" from the motor mount to the back of the air filter. The k&n filter I use has a small emblem on the end that unscrews and I attach it there. I have a dzus fastener on it so I can take it on and off easy.
DB time: 0.146493 (44.18%), total time:0.331606, queries:38
