Eric Withers
Posted: Mon Feb 07, 2005 7:42 pm Post subject: Best resource for maintaining/tuning Rotax engine? |
Hello,
Wanted to know what the best resource is for maintaining/tuning Rotax engine. Me and my brother are new to karting and just purchased 2 karts. Since we're buried in snow, we figured we should do all we can in the off season to understand the karts.
I figure we'll learn alot from trial and error once the season starts but that could get costly real quick. Are there any books, CD's, etc that we could purchase to help us out?
Eric |
Philip Johnson
Posted: Mon Feb 07, 2005 8:09 pm Post subject: |
| The manual is the best place to start. It lists most of the maintenance and tells you how to use the carb. Some maintenance stuff it doesn't seem to cover so well is the power valve: you need to take it apart after about every two 20 minute sessions or more, and clean all the oil out of the rubber boot, then clean off the metal slide (the actual valve) with brake clean and then put it back togethor so it moves freely. Use orange or black RTV silicone sealant on the exhaust, put it on the manifold, not the pipe and then attach the pipe. Keep the carb and fuel pump clean, keep the water temp around 140 F (in-head temp sensor), make sure you set the throttle so that the slide pulls all the way out of the inlet, but that the cable can't pull past that, if the slide is pulled up to hard it can stick. I bet other people have lots of usefull stuff I forgot. |
Nick Weil
Joined: 18 Jul 2001 Posts: 1801 Location: United States, Florida, Orlando, FL US of A
Posted: Mon Feb 07, 2005 11:13 pm Post subject: |
SpeedQuest has a comprehensive CD that contains:
- All current Rotax Operators Manuals (FR125, Junior, RM-1/DD2)
- Spare parts diagrams (FR125, RM-1/DD2)
- Current Rotax Service Manual
- Current Rotax Sporting Regulations
- Current Rotax Technical Regulations
- Several SpeedQuest Tech Tips (Battery Care, Carb Tuning 1 & 2 and many more)
- On-Board kart videos from Rotax Races
Check it out: http://www.speedquestkarting.com/shop/product_info.php?products_id=413 _________________ Nick Weil
Want to save money AND grow the economy? www.fairtax.org |
Mike Adams
Joined: 24 Sep 2001 Posts: 300 Location: Canada, Ontario, Guelph
Posted: Tue Feb 08, 2005 4:41 am Post subject: |
For tuning it you can't beat the Max jet software and a weather pod.
can be seen on www.maxjet.ca _________________ Thanks
Mike Adams
www.zainostore.ca
Zaino clear seal Wipe on, and walk away, you're done. No buffing. No final wipe down. Simplicity at it's best. Just apply & let dry.
Wesley Shelton
Joined: 08 Jul 2003 Posts: 3306 Location: United States, Florida, Fort Lauderdale
Posted: Tue Feb 08, 2005 5:06 am Post subject: |
Eric,
Buy the CD, I did. Most people will tell you here, the manual is way more comprehensive then you might think. Before Rotax, I had zero background doing this stuff and the manual has made it quite easy. It tells you what to do, and more importantly what NOT to do. Do the proper maintenance and the kart will reward you.
The tips you got above were good as well regarding the power valve and maxjet. The latter will cost you a few bucks, but if you're racing it is an absolute must.
Get a notebook, and keep track of the maint that you do as this will make it easier to remember what's been done and so forth. Our team also made a sort of pre-weekend checklist to ensure that we do everything before the karts get in the trailer and not AT the track.
Lastly, use this forum as a learning tool. If you have any issues, do a search of previous topics to see if and what was discussed. Chances are, it's on here multiple times. Also, recognize which guys know their stuff (dealers) and take their words with a little more conviction.
Best of luck, and have fun.
-w |
Chuck Schendzielos
Joined: 02 Sep 2004 Posts: 486 Location: United States, Colorado, Denver
Posted: Tue Feb 08, 2005 9:11 am Post subject: Re: Best resource for maintaining/tuning Rotax engine? |
| Eric Withers wrote: | Hello,
Eric |
Just get the MAXJET software..............Dave Galegor at www.g-rpm.com has that available. It takes ALL of the guesswork out.......calculates for altitude density, etc, etc. I think it's phenominal......check out the website! |
Eric Withers
Posted: Tue Feb 08, 2005 7:02 pm Post subject: |
Thanks for the feedback. I just ordered the Speedquest CD. Seems like it should help alot. We already went ahead and purchased the Maxjet software as we've read so many good things about it.
I wish someone locally would give a seminar on the maintainance/tuner workshop on the Rotax. Now that would be awesome! The folks at F1 Boston say they will be running one, so we've got our fingers crossed. |
Peter Withers
Joined: 25 Oct 2004 Posts: 330 Location: United States, Massachusetts, Templeton
Posted: Tue Feb 08, 2005 7:12 pm Post subject: |
We can definately use all the help we can get... Too bad we're getting another foot of snow on Thursday!!!  |
Joe Rosse
Joined: 29 Mar 2002 Posts: 417 Location: United States, Colorado, Golden
Posted: Tue Feb 08, 2005 8:59 pm Post subject: |
| Philip Johnson wrote: | | Use orange or black RTV silicone sealant on the exhaust, put it on the manifold, not the pipe and then attach the pipe. |
Philip--
I'm curious, why put the RTV on the manifold rather than the pipe? Especially since it's so hard to get to the bottom of the manifold? _________________ Joe Rosse
Golden CO |
Philip Johnson
Posted: Tue Feb 08, 2005 9:30 pm Post subject: |
| I put the RTV on the manifold because if it's on the pipe, it gets pushed back into the pipe and creates a little ring of silicone that gets blown into the pipe itself, which is irritating at least and could block up the exhaust at worst. It is a pain to get the bottom, but I make it a little messy to make sure it seals and when I'm done I take off the manifold and clean everything. |
Joey Guyon
Joined: 09 Aug 2001 Posts: 532 Location: Canada, Not USA, Calgary
Posted: Wed Feb 09, 2005 7:32 am Post subject: |
I would also consider the Memo Gidley 2 cycle book. It is great for new karters and even a great refresher for experienced racers. It offers great general setup and mainetance info.
JG |
