Tony Kart/Vortex - FB
Rotax - Emulsion tube
Roger Miller
Site Admin
PostPosted: Wed Nov 07, 2001 6:58 am    Post subject: Rotax - Emulsion tube Reply with quote
What is it? And what are the published specs for it?
Dustin Stewart
PostPosted: Wed Nov 07, 2001 7:15 am    Post subject: Rotax - Emulsion tube Reply with quote
I bet if you got a hold of Alfonso he would know.
Mark Givens
PostPosted: Wed Nov 07, 2001 10:18 am    Post subject: Rotax - Emulsion tube Reply with quote
Emulsion Tube is a technical name for the Needle Jet in the carburetor. In the RotaxMax Challenge, the needle jet (emulsion tube) must be stamped with "FN266". Don't know if this is the violation that DQ'd Alfonso, but it would be a good guess.
The official word is 13.5 at: http://www.maxchallenge-rotax.com/Kart/TechSpecFR125MAX-2001-02.pdf
Hope that helps
Stephen Buckley
PostPosted: Wed Nov 07, 2001 10:23 am    Post subject: Rotax - Emulsion tube Reply with quote
Roger,
The emulsion tube, mostly referred to as the needle jet, is a spec item in the RotaxMax series, as is the slide (#40) and the jet needle (choice of 2, K54 & K27). For specs, SRA Karting in Quebec, has the various manuals available on their website.
John Gilbert
PostPosted: Wed Nov 07, 2001 5:39 pm    Post subject: Rotax - Emulsion tube Reply with quote
Alfonso was an arrive and drive, he still has not a clue what it does. He does not even know what size tool it requires.
Dave Stevens
PostPosted: Wed Nov 07, 2001 6:21 pm    Post subject: Rotax - Emulsion tube Reply with quote
quote:
That sucks.....Who was providing the kart?
Dave
Jeff Franz
PostPosted: Thu Nov 08, 2001 7:35 am    Post subject: Rotax - Emulsion tube Reply with quote
quote:
Mark,
To my understanding of the situation, you are correct. That was the basis of the DQ; the tube in question had a different number stamped upon it.
Jeff
Stephen Buckley
PostPosted: Thu Nov 08, 2001 8:17 am    Post subject: Rotax - Emulsion tube Reply with quote
I wonder if somehow he got a Mk. I carb??? It came with a different needle jet, floats, and jet needle.
I'm surprised that their isn't a way to "seal or mark" the needle jet with fingernail polish or QC dope. If the engine is a arrive and drive, maybe SSC can track the past rental use, person by person. That is, unless the motor was brand new. Seems as if another lesson is learned here.
John Gilbert
PostPosted: Thu Nov 08, 2001 2:42 pm    Post subject: Rotax - Emulsion tube Reply with quote
I see three things could have happened
1) it was wrong when assembled at rotax I do have a BM260 tube where the 0 is not stamped cleanly.
2) it was changed at SSC, the motor may have been run before.
3) the motor was run with a junior @ 5000', and may have been previosly leaned for this, I dont think so because this is a very uncommon part and was only raced once.
The kart andrew was running was a school kart and had never been touched.
If you know andy and andrew you know that they have no clue on delorto's or even where to get parts.
John
DB time: 0.133919 (40.63%), total time:0.329607, queries:37
