2D2W - LB
MRP - SS
Franklin / Merlin USA - FB
water temp gauge for rotax max
Charles Pou
PostPosted: Mon Oct 29, 2001 1:17 pm    Post subject: water temp gauge for rotax max Reply with quote
Does the Digatron water temp sensor WT-102 work on the Rotax Max? My concern is the fitting on the sensor that connects to the engine. I called Digatron, and the person I spoke with wasn't familiar with the Rotax Max.
If not, what about the CHT sensor SS102? It looks like you would need to machine the Rotax Max head a little to enlarge the area around the sparkplug for the Digatron CHT sensor to fit properly.
Otherwise, if the sensors for the CHT or water temp fit the engine properly, I understand the Digatron gauge will work properly.
John Burgess
PostPosted: Tue Oct 30, 2001 6:23 am    Post subject: water temp gauge for rotax max Reply with quote
The thread in the Rotax head is an 1/8" npt thread. Just buy a compression type fitting that is 1/8"npt to what ever size your thermocouple is. I bought a 1/16" od TC from Mcmaster Carr supply.
Charles Pou
PostPosted: Tue Oct 30, 2001 9:52 am    Post subject: water temp gauge for rotax max Reply with quote
John Burgess
posted October 30, 2001 07:23
"The thread in the Rotax head is an 1/8" npt thread. Just buy a compression type fitting that is 1/8"npt to what ever size your thermocouple is. I bought a 1/16" od TC from Mcmaster Carr supply"
John,
Sorry, I'm a little confused. Is your fix for the CHT sensor or the water temp sensor?
Thanks for your help.
Charles
John Burgess
PostPosted: Tue Oct 30, 2001 12:51 pm    Post subject: water temp gauge for rotax max Reply with quote
Sorry for the confusion. I was speaking about the fitting for the water temperature. You remove the plug in the head to install the fitting. I also forgot to say you have to drill out the body of the compression fitting to allow the TC to be in the water flow area. I have a Micron and it uses a Type "K" thermcouple. I bought a type K from McMaster Carr with the correct boynet fitting that pluged directly into the Microns pigtail. Hope this helps you out.
Charles Pou
PostPosted: Tue Oct 30, 2001 1:48 pm    Post subject: water temp gauge for rotax max Reply with quote
John, I think that's what I needed. Thanks for your help. Charles
John Denman
PostPosted: Tue Oct 30, 2001 11:07 pm    Post subject: water temp gauge for rotax max Reply with quote
Charles,
Look me up and give me a call.
DB time: 0.125177 (40.99%), total time:0.305366, queries:40
