Ocala Gran Prix - LB
Ribtect - SS (non-flash)
Phillips Petroleum Zymax 2-stroke oil???
Curtis Bosarge
PostPosted: Wed Oct 17, 2001 5:21 pm    Post subject: Phillips Petroleum Zymax 2-stroke oil??? Reply with quote
Any experience with the Zymax(?) 2 stroke premix oil?
Curtis
Steve Krock
PostPosted: Fri Oct 19, 2001 6:11 am    Post subject: Phillips Petroleum Zymax 2-stroke oil??? Reply with quote
Phillips Xamax 2stroke oil is excellent oil. We run that with Phillips P45 racing gas at all events except where a spec is required. This combo burns very good and very clean.
Thats my two Lincoln's
Steve
Sean Robbins
PostPosted: Fri Oct 19, 2001 10:51 pm    Post subject: Phillips Petroleum Zymax 2-stroke oil??? Reply with quote
I've been running Xamax in my motor for the season, and have good luck with it. You can use it both to break in the motor, as well as race it. The oil very much stickier than most others. You should plan to pull the head at the end of the weekend and clean it, as there will be a sticky oil residue on the head.
John Van Nghiem
Advertiser
Advertiser
PostPosted: Sun Oct 21, 2001 8:55 pm    Post subject: Phillips Petroleum Zymax 2-stroke oil??? Reply with quote
Hey Curtis,
don't know about the Zymax, but if you ask me, I'll say run Mobil MX2T synthetic 2-stroke oil. I've ran it for two years hard at 20:1 and it burns real clean and everything looks good, top and bottom.
No one runs it but I could care less. Worth a try.
John
Jimmy Moore
PostPosted: Tue Oct 23, 2001 5:42 am    Post subject: Phillips Petroleum Zymax 2-stroke oil??? Reply with quote
Why anyone would run anything but Red Line I don't know.
Chuck McCue
PostPosted: Tue Oct 23, 2001 6:01 am    Post subject: Phillips Petroleum Zymax 2-stroke oil??? Reply with quote
A superior lube you will hear more about is Motorex, Which is the lubricant of choice for TM Racing Srl, World Rotax Max Challenge and team Arsenal.
CM www.racearsenal.com
Jimmy Moore
PostPosted: Tue Oct 23, 2001 7:06 pm    Post subject: Phillips Petroleum Zymax 2-stroke oil??? Reply with quote
Most of this oil is the same stuff with different color dye.
DB time: 0.113545 (38.35%), total time:0.296088, queries:37
