DID Chain
MG Tires - SS
KG Plastics - FB
Removing spindle bearings
Pete Muller
PostPosted: Sun Sep 02, 2001 12:26 pm    Post subject: Removing spindle bearings Reply with quote
This exact question was asked here about a month ago. Here's the link to that thread: http://www.ekartingnews.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic&f=2&t=000021
PM
Whoops... just realized you're asking about the spindle, not the hub(s). If that's the case, heat will accomplish nothing since the spindle is steel, and the bearings are steel. You'll need to get the spacer "off center" far enough to get in through one bearing with a drift and drive out the far side bearing. Once one bearing is out (and the spacer, of course), you can reach though and drive out the other bearing.
PM
[ September 03, 2001: Message edited by: Pete Muller ]
Paul McKenzie
PostPosted: Sun Sep 02, 2001 10:07 pm    Post subject: Removing spindle bearings Reply with quote
Does anyone know how to remove the two bearings and spacer from a front spindle?
If I use heat, won't it fry the bearings? Or is there another way to do it.
Thanks.
DB time: 0.1553 (46.54%), total time:0.333685, queries:40
