OTK - LB
MRP - SS
SCCA Enterprises - FB
Head temp verses water temp.
Gary Kozuma2
PostPosted: Wed Aug 15, 2001 7:16 pm    Post subject: Head temp verses water temp. Reply with quote
I was just reading the thread on cold stick lean stick and there was a comment about head verses water temp. I just switched to a head temp sensor, so I'm I still looking for 130-135 deg or is it different?
Gary K.
Dennis Brown
PostPosted: Wed Aug 15, 2001 8:05 pm    Post subject: Head temp verses water temp. Reply with quote
My experience with using both sensors indicates that the difference between CHT & H20 is minimal once the engine is at operating temp. 5-10 deg.
DB
Brian Wilhelm
PostPosted: Fri Aug 17, 2001 3:52 am    Post subject: Head temp verses water temp. Reply with quote
I think it depends on the motor. I run a Pavesi 125 type C rotary and I usually see about 200deg head temp and about 150 water temp. My MacMinarelli ran about the same.
Pete Muller
PostPosted: Fri Aug 17, 2001 6:53 am    Post subject: Head temp verses water temp. Reply with quote
It depends on how much mass (aluminum) is immediately around the sparkplug, what the water flow is around that area, and how much surface area of the sparkplug boss is directly exposed to the water.
Terry Tilton
PostPosted: Sat Aug 18, 2001 3:26 am    Post subject: Head temp verses water temp. Reply with quote
Gary-
I run a head temp and I also have a infared laset temp gun. My head temp during a race is about 170 while the water temp is about 140. Thats the way it is on my motor. cr125
Ronnie Swyers
PostPosted: Mon Aug 20, 2001 1:54 pm    Post subject: Head temp verses water temp. Reply with quote
I run an o-ringed head on our Honda and see about 35 degree higher on CHT over the water temp. I believe Mr. McKnight told me 10-15 degrees higher is what I would see. Either, or, If I started to see a pattern different then what I'm use to seeing, I would start looking at a possible detonation problem. I look for drastic change, If I see none....I know I'm still ok.
Ronnie Swyers www.RSwyers.com
DB time: 0.074589000000004 (42.52%), total time:0.175414, queries:37
