Streeter - SS
Help me please : Used Road Rebel vs New Kali
Goto page 1, 2  Next
Scot Kight
PostPosted: Wed Mar 10, 2004 5:50 pm    Post subject: Help me please : Used Road Rebel vs New Kali Reply with quote
I must apologize to the people who have offered me these karts, I am new and need unbiased advice. I really am coming down to the wire on a decision, and just waiting for this final bit of information.
For everyone else the deal is this, I need to make a decision between two karts. I have been offered a 2002 Road Rebel with ~15hrs of race time on it and a brand new Kali with similar equipment. The RR is a few hundred dollars cheaper than the kali though the seat will not fit me so that has to be replaced which is offset my the mychron 2 on it. Otherwise they are fairly similar, 45mm axel on the RR and 50 on the Kali. Both have new Leopard engines and front brakes.
I have seen pictures of the RR and it looks fine.
Which would you choose? I want as many people responding as possible, including the sellers if you want to post up, I wont hold it against or for you in the end.
Mike Goebel
PostPosted: Wed Mar 10, 2004 6:02 pm    Post subject: Reply with quote
They are both great. So the only comment I have is regarding body work. I don't know how much longer the pre 2003 body work will be available.
Mike G.
Charley Schimmels
PostPosted: Thu Mar 11, 2004 8:30 am    Post subject: Reply with quote
Scott:
Before you decide find out who is going to provide you with parts support at your racing venue. If you have local support for one of your choices go that way. If you have it for both, interview the shops and find out what kind of trackside support they provide and who you are comfortable with. Pick your chassis AND your motor package based upon that criteria as well as your racing options (what classes are well attended -- it's not too fun to be a race group of 3) and your budget.
Either of the chassis will work if they are set up properly. If you don't have the experience to do this yourself then shorten the learning curve a bit and get close to a shop that does.
One other thought, I have not seen many 45MM axles available trackside on a race day (my own experience--again, see my first point). Having had to buy and install axles after a heat to make the main I'll say availability of parts is critical unless you are going to stock up on all of your chassis parts.
If you choose properly you will have a ton of fun Very Happy
Welcome and Happy Racing!
Charley Schimmels
#7 Track Magic/Rotax-Masters
Home Track: Pat's Acres
Tom Jensen
PostPosted: Thu Mar 11, 2004 10:37 am    Post subject: Reply with quote
Check the Road Rebel underneath and see if it is ground down on the metal. I think it is a better chassis. The components are better if I'm not mistaken. However, a new kart will give you the satisfaction of knowing ther is no damage to your kart.
Scot Kight
PostPosted: Thu Mar 11, 2004 12:09 pm    Post subject: Reply with quote
I will definitely ask for more details on the bottom of the RR. The 45mm axel is also a big consideration which makes me really lean towards the kali with a 50mm.
In terms of local shop support, I hate to say it but there seems to be a complete lack of support here in the Northern VA area. There are shops around, don't get me wrong, but only a very small number of them (2). Considering we have two world class long tracks and a number of short tracks, I just don't understand why there are so few. There are also a few shops up in the PA area and down in southern VA, but they are nowhere near convenient for us Virginians.
In terms of being the only guy out there, you are right, 3 karts do not make a race, especially on a long track. Fortunately I know there are a few people who are in this class and it seems to be a direction many others are headed. Plus its relatively easy for us newcomers into karting to understand. When I started I was looking at KT100 style karts, and while I am sure I could have gotten in at that level, the amount of acronyms, karts, tuneups, and things that can be done overload the newbies. Even reading the books leaves you just asking more and more questions. TAG is what it is. Buy a chassis, buy an engine, strap them together and go racing.
Scot
Mike Goebel
PostPosted: Thu Mar 11, 2004 4:37 pm    Post subject: Reply with quote
Scot
Yup all you need to do now is chose between about 10 chassis brands and about 6 different engine packages. So your set. So for each chassis you can have an engine. Therefore you can have 6 combinations per chassis, that 's only 60 combinations Laughing .
Mike G.
Scot Kight
PostPosted: Fri Mar 12, 2004 9:50 am    Post subject: Reply with quote
Each of those brands have 2-3 chassis which can be used so we are actually up to about 180 combos!
Of course one other seller reminded me there is also a birel cr32sr in the mix for possible karts. Used, but 50mm and a 2003. It costs more than the new kali though, so that is a potential issue. Then there are the brands of brakes etc, of which I dont know why one is better than the other.
Argh. Why isn't there a general comparison that actually EXPLAINS the strengths and weaknesses of the different karts out there?
joseph hollinger
PostPosted: Fri Mar 12, 2004 10:47 am    Post subject: Reply with quote
Probably because karting is about 99.9% driver and about .1% chassis.
Especially for a beginner who is starting out in TAG (bad idea) and
in road racing (another bad idea), it's going to be a long time
before the chassis makes any difference.
Rob Linders
PostPosted: Fri Mar 12, 2004 11:10 am    Post subject: Reply with quote
Hey Joseph,
I am a sprinter, but why do you think road racing is a bad place to start? Heck, my only experience racing the big tracks was road-racing motorcycles and that has got to be more dangerous than taking a kart out with a TAG engine. I do agree you can go quite fast on road race tracks versus sprint tracks, and that is what I presume you are talking about.
joseph hollinger
PostPosted: Fri Mar 12, 2004 11:18 am    Post subject: Reply with quote
Rob Linders wrote:
Hey Joseph,
Two factors:
1) compared to sprint racing, it's going to be nearly impossible to get
as much seat time. And seat time is the single most important part of
going fast.
2) sprint racing has about 10,000 times more people racing. You can't
learn to kart running with two or three other guys.
Just my opinion.
Scot Kight
PostPosted: Fri Mar 12, 2004 11:51 am    Post subject: Reply with quote
While I agree with you in principle, I am not saying that I will not be doing sprint racing.
*My* main mission is to do road racing. I have been doing it for years in my car, and want to make the transition to a kart. To do this I want all of my requirements and purchased items to meet the minimum specs of roadracing, without the confusion of some of the older classes. TAG makes this part quite easy really being a very simple "idea", at least in theory. Since the requirements of TAG RR classes are, in general, much higher than than sprint racing, I think this is still the right way to go. On the weekends without a road race, I can find my way up to frederick or baltimore, disable the front brakes, and zoom around the track for a while. Gaining more and more seat time. Then on the weekends with RR, hit the practice day and do real track work.
Scot
Im not going into this with my eyes closed. I am here to win, not to just put around the track. That takes time, dedication, and to some extent, the right equipment (oh and $$$, which is always the hard part!). I know the ability is there, its just the practice to let it come through. Of course right now the $$$ and the equipment are at odds, and my next year or two hinge on making the right decision.
Rob Linders
PostPosted: Fri Mar 12, 2004 12:24 pm    Post subject: Reply with quote
$$$$$ is one of the reasons I quit bike racing and got into karts. On a bike it wasn't uncommon to spend between $500-1000 per race weekend. This was at the amateur level. I was single and making good money so I could afford it at that time. A practice day alone was usually between $100-150 just to get through the gate. On a thrills per $ ratio, biking is way cheaper than karting, the rush on a bike is way more intense. However, the crashes & broken bones are much less fun. Surprised
When I started karting with Tri-C a practice day at adams in 2000 or 2001 was $20 and the race was only $35. Now a practice at Moran is $39 and a race is $55. So there has been some inflation, and we have gone to a brand new track.
I don't know how much road racing a kart costs, but I presume with higher track rentals is gets quite pricey, just like road racing a bike did. This was another reason for me to choose sprint karts. I think I may road race karts someday, but when I do, it will probably be in a shifter. Then I will have to step-up the budget quite-a-bit from my current racing budget of next to nothing. Very Happy
Scot Kight
PostPosted: Fri Mar 12, 2004 12:29 pm    Post subject: Reply with quote
Arright everyone, I appreciate the feelings on the rr vs sprint karting, but I have made my statement and unless you think I am way off lets not focus on that anymore.
Ok now back to the topic at hand.
What do you think I should do and why?
CRG RR used 2002 Least expensive
CRG Kali New Middle
Birel CR32SR 2003 Most expensive
The range is <1000 dollars.
Scot
joseph hollinger
PostPosted: Fri Mar 12, 2004 12:32 pm    Post subject: Reply with quote
I think you're missing the point. Karting is not about equipment. It's
routine to see good drivers in crappy old beater karts beating the
daylights out of guys with brand new top of the line stuff. My guess is
that your next two years hinge on you, and it's going to make very
little difference what kart you buy. Nothing wrong with trying to
get the best thing you can find, but no point in totally agonizing over
it either.
joseph hollinger
PostPosted: Fri Mar 12, 2004 12:47 pm    Post subject: Reply with quote
CRG Kali New Middle
Scot
It really depends on your budget. Since you are starting off, there
is a ton of other stuff that you are going to buy. Some of it you'll
need and some you'll probably buy anyway (at least if you're
like the rest of us). If saving $1000 now means that you'll get to
practice more, I'd go the cheap route.
When I started karting, I bought all brand new gear. And lots of
it. I've got friends who started at the same time with used stuff.
We're pretty much at the same level these days. Fortunately, I
managed to spend the most getting there.
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.148981 (39.56%), total time:0.376631, queries:38
