Margay Racing
Brett King Design
Tony Kart/Vortex - FB
New belt drivers available for Max from HEGAR MFG.
Chris Hegar
PostPosted: Tue Mar 02, 2004 3:43 pm    Post subject: New belt drivers available for Max from HEGAR MFG. Reply with quote
Now available for axle clutch setups...
30mm wide all aluminum belt drivers.
19-22 tooth aluminum and or steel sleeves.
20mm wide all aluminum belt drivers.
19 & 21 tooth aluminum sleeves.
Turn your broken starter ring gear into a useful part again. Bolts up in seconds.
Send us your starter ring gear for the ultimate high tech Waterjet cut lightening holes. (Open classes only)
Please call for more info and pricing. Smile
E mail for pics.
HEGAR MFG.
503-659-1234
www.Hegar4.com
Hegar4@Europa.com
Chad Stapleton
PostPosted: Tue Mar 02, 2004 5:45 pm    Post subject: Re: New belt drivers available for Max from HEGAR MFG. Reply with quote
.......Turn your broken starter ring gear into a useful part again. Bolts up in seconds.
Chris,
are you saying this driver eliminates the Rotax clutch completely ?
Chad
Chris Hegar
PostPosted: Tue Mar 02, 2004 6:30 pm    Post subject: Reply with quote
Yes, these drivers are designed to bolt up where the clutch used to mount on the starter ring gear. The gears were designed because of a request by some enduro laydown racers that prefer to run axle clutches on their karts. The small stock clutches can be a problem for long track racers if abused.
DB time: 0.135218 (42.79%), total time:0.316033, queries:38
