K1 Speed - SS
So much for the masters class
Dennis Garwood
PostPosted: Sat Feb 28, 2004 10:22 pm    Post subject: Reply with quote
I don't agree with the people that said a heavier kart is at a disadvantage. If Kart + Driver = 400 then it shouldn't matter where the weight comes from, right? I actually believe that the lighter guys will still have an advantage up to a certain point and that point is where the weight starts tearing your seat off the the mounts. because you just don't have any place to bolt on 50+ pounds of weight. In fact, weight distribution should be used as a tuning aid. If you've got one driver that weighs 200 pounds and another driver weighing in at 180 pounds, and assuming that the weights of the kart are identical to begin with and that the 200 pound driver + kart come in at weight limits, then the lighter driver has 20 pounds to place anywhere on the kart that he/she wishes. If the lighter driver needs additional weight on the nose for front/back distribution then he/she has the luxury of mounting weight on the nose and the heavier driver is stuck with his/her fat butt planted in the seat and will have to find another way to get the push out of the kart. Just my 2 cents...can I get change?
Rob Martin
PostPosted: Sat Feb 28, 2004 11:18 pm    Post subject: Reply with quote
Joseph,
Sorry but 385 is the Rotax Master weight for SKUSA not 405. Take away 5lbs for safety gear. Of several chassis and TAG motor combinations I have owned, 178 was actually the lightest. How about 185lb as an average. Now the Masters drivers weight is 195.
The 70% figure was a consideration for the ideal driver weight and does not take into account chassis weights or motor handicapping. It is not uncommon for chassis weights to vary by more than 15lbs depending on model and manufacturer.
How many manufacturers provide accurate as-built weights for their karts? If chassis weights become a key issue, more and more exotic materials will be required to reduce the weight and big-budget racing will win. This direction would be contrary to what TAG is trying to accomplish. Thus, James Bremners' kart at about 180lb, Tim Finelys' kart at 195lb, my lightest kart at 178lbs, my heaviest kart at 190+lbs should be considered fairly representative of the class.
Since, you have not responded with your actual kart weights or information about your equipment I will assume you underestimated the weight when you said 165lbs. Regardless, the class weights should not be determined by the lightest driver / chassis combo OR the heaviest driver / chassis combo.
With SKUSA Rotax Masters weight now at 385lbs, this would leave James Bremner (rotax) adding 13lbs and Tim Finely (leopard) being right on weight at 390lbs. Both drivers are roughly 190lbs not 230. Obviously higher HP motors will pay a weight penalty.
Do you think 190lbs is an unreasonable drivers weight for the Masters class?
If so, what do you think is reasonable?
joseph hollinger
PostPosted: Sun Feb 29, 2004 12:01 am    Post subject: Reply with quote
Rob Martin wrote:
With SKUSA Rotax Masters weight now at 385lbs, this would leave James Bremner adding 13lbs and Tim Finely being right on weight at 390lbs. Both drivers are roughly 190lbs not 230. Obviously higher HP motors will pay a weight penalty.
First off, Tim has already admitted that he's that heavy because of
front brakes. By his estimates, that's ten pounds. And I've never,
ever indicated that all drivers should be able to run all motors or
all chassis. If you're big, how about you make it your responsibility
to find something that works? At 405, without front brakes, that means
that Tim, who weighs 190, can still bulk up to 215 without doing
anything more strenuous than picking the right motor. How hard is
that?
Sure. How about 190 (driver) + 180 (kart) = 370? That's for the
heaviest package and we work down from there. You've indicated
that's doable for the chassis and you've already put forth 190
for the target driver weight. That leaves us with something like
#350 at the low end of the scale. Too light? okay, how about 390
at the top and 370 at the bottom? By your own numbers, that's means
the driver can weigh 210 without being penalized in any way. Oh
wait, that's where we were before.
The way it is now, even if we use your numbers, there's no penalty
until the drivers weighs more than #225. How often do you think you
are going to see that at the track?
Bill Siler
PostPosted: Sun Feb 29, 2004 11:01 am    Post subject: Kart and driver weight Reply with quote
Well I can give all of you some numbers for an Avanti with a rotax motor.
We weighed my kart with driver, and yes I am one of those over weight drivers working on losing weight. 40 lbs so far. We weighed the kart on digital scales the total weight was 409. I weight 218 with all my gear.
So that leaves 191 for chassis with motor. Also that was with a half tank of gas. I understand gas is about 6lbs per gallon? For comparison at Irwindale they had a light class at 355 and a heavy class at 400 last year. There were as many as 25 drivers in heavy and 20 or so in the 355 class. I'm don't sure what a good weight for the heavy class would be, but I do think that with a 400lb class you will see a lot of drivers showing up for that class. My understanding is that they have a 355 and 400lb tag class in northern California and the heavy class at 400lbs is as big as the light class. Both classes from what I have been told are very big. Just my 2cents.
Bill Siler
Rob Martin
PostPosted: Sun Feb 29, 2004 6:17 pm    Post subject: Reply with quote
Joseph,
I'm still waiting to hear your actual weight and not the phantom 165lbs chassis weight you originally claimed.
Tim's kart at 195lbs-10lbs for front brakes = 185 (not 180).
175-180 is for light weight, small tubing karts with minimal attachments like 4th rail and torsion bars. Almost every TAG/Rotax kart will weigh more than 180lbs.
At any rate, 185 was just used as an example.
Here is the math in case you are having trouble following:
385lbs rotax masters weight (skusa) - 185lbs chassis= 200lbs
200lbs for driver and all safety gear. As far as I can tell, no drivers are born with a snell 2000 rating, this means helmet, suit, shoes, gloves, neck collar as a minimum (ribvest or body armor optional). 5lbs minimum for all required safety gear and another couple pounds for any optional gear.
This leaves a driver weight well under 200lbs not 210 as you claim my calculations support.
I think 385 is a great Master weight but I am also not likely to whine or complain if the weight is 405.
There are many terrific 200lb plus drivers who enjoy racing Rotax and Tag masters. Why work so hard to exclude them from competitive racing?
For some strange reason, when underweight drivers lose to heavier drivers, weight always becomes the excuse.
I was tired from lifting my kart.
My kart doesn't handle as well as Bubba's kart.
My chassis isn't designed to work well with the extra weight.
My brakes don't work well with the extra 20 lbs.
My chassis is going to wear out prematurely with the extra weight.
In Europe they only weigh _______ (fill in your favorite number in kilograms)
If you don't like the weight additions why don't you provide some concrete data to lobby for a change.
Or better yet, just lose a few pounds and move down to a lighter class.
_______
Bill,
Thanks for sharing your numbers.
I'm certain you are not in the minority when it comes to a chassis weight of 190lbs plus. Your driver weight is also certainly not uncommon for a class of mature adult males.
Some racers deliberately forget to include fuel and other items like safety gear when they are doing weight calculations.
I know others may not agree but I personally believe 385 is a good minimum Masters SKUSA / TAG or club weight.
joseph hollinger
PostPosted: Sun Feb 29, 2004 6:43 pm    Post subject: Reply with quote
Rob Martin wrote:
Joseph,
Rob, why is that so important to you? I mean, even if I'm wrong,
that doesn't mean you "win" the argument, does it? Or are you
just being a little bit of a jerk? You've already put forth 178, I've
accepted 180. Can we move on? If not, why don't you tell us all
what number you are happy with?
Maybe this is where the problem comes from. As far as I know,
we are talking about SKUSA TAG. Not Rotax masters. Max TAG
weight is 405. Not 385. So, Let's up your number by #20. That's
still #30 more than the 190 you've put forward. How difficult
is that to understand?
You're whole point seems to be that allowing for #190 drivers
somehow means that 70% of all prospective karters get to drive.
Let's put aside for the moment the fact that you've pretty much
pulled that one out of thin air (to put it politely). Instead, please
note that 190 + 185 is 375. 405 - 375 is #30. That's a pretty
big helmet, wouldn't you say?
Jon Andrews
PostPosted: Sun Feb 29, 2004 7:45 pm    Post subject: Reply with quote
joseph hollinger wrote:
Joseph,
From the recent SKUSA press release RE weight;
Quote:
SKUSA TAG - Updated Weights - Feb. 27, '04
Rotax
Junior N/A
Senior 355 lbs
Masters 385 lbs
So 385lbs is the correct weight.
Secondly I don't know where you guys think that all safety gear weighs 5lb. I just weighted an Arai GP5 helmet, codura 1-piece suit, neck collar, sparco nomex shoes, simpson gloves and the weight was 12lb. My KRT 32mm tracker chassis with an FR125 with coolant but no fuel, no torsion bars and 2003 plastic weighs 175lb. By my math....
385 - 175 - 5lb (fuel) - 12lb = 193lb
So a 190lb driver would have to add 3lbs, and would probably be exactly on for weight if the torsion bars were in.
I'd say 385lbs for the Masters Rotax in SKUSA, TAGUSA etc. is spot on. Now quit yer whinin' Laughing
Jon.
KRT Tracker
Bill Siler
PostPosted: Sun Feb 29, 2004 8:11 pm    Post subject: Weights for tag Reply with quote
Joseph, you are in the area in northern California that has the big turnout in tag. I was talking to Doug Sharp and he told me that they have a very large turnout in the heavy class. My understanding is that they do not even allow someone to race a Rotax setup. Just BM and Leopards. I beleave the Inporter for the BM motor said that the heavy class is even larger than the light class sometimes. Do they not run at 400lbs for the heavy class up there. According to the weights I see here for Skuza they have those two motors at 390lbs. Hope they keep something at 400lbs even when I lose the other 20lbs I hope to be able to add a little weight for setup of the kart. PS I know of two friends that weight in at 200lbs + and are in great shape. I guess in to good of shape if they end up not having a motor package for someone of that weight.
Bill Siler
joseph hollinger
PostPosted: Sun Feb 29, 2004 9:54 pm    Post subject: Re: Weights for tag Reply with quote
I live here, but race with some buddies in So Cal. So far, we haven't
really seen any big fields, but we'll see. Smile
joseph hollinger
PostPosted: Sun Feb 29, 2004 9:56 pm    Post subject: Reply with quote
Joseph,
Rotax
Junior N/A
Senior 355 lbs
Masters 385 lbs
Jon.
Jon, I don't know how many times I've got to say this, but I don't
care what the Rotax weight is. If I were big, I'd certainly go with
one of the bigger, heavier classes. Doesn't that make sense? Last
I looked, they even had a better hp to weight ratio. Why every
driver has to be able to race every motor (and every chassis)
is a little hard to understand. Big people have options, maybe not
rotax, but there's definitely room for you all to race.
Rob Martin
PostPosted: Mon Mar 01, 2004 12:24 am    Post subject: Reply with quote
Joseph,
My discussions are not "win or lose".
My interest is your chassis weight is strictly statistical.
You presented a TAG chassis weight and have yet to clarify its accuracy and still you continue to distort or criticise others findings.
While some may think me argumentative or perhaps even a "jerk" as you put it, at least my information is fairly accurate. I have never claimed it to be gospel as there are to many variables.
Having already stated quite clearly that I believe you were wrong,
I dont really care if you ever recognize this fact or admit a mistake may have been made on your part. My only interest is in dispelling any belief that the current Masters weights are unreasonable or out of line.
FYI, According to many credible sources, the average US male weighs 180lbs. Using this weight would only equalize 50% of the class. The other 50% would automatically be over-weight. Adding 10lbs to the mean would surely capture at least another 10% of the population. As with most things in life, a compromise is necessary. 190-195lbs seems to be a good compromise number that will capture greater than 50% of the racing population.
____________
Jon,
Thanks for presenting your findings on safety gear.
When I was presenting 5lbs as a weight for safety gear, this was obviously a low estimate. Some might argue that typical driver weights should already include shoes and clothing. This would leave gloves, collar, and helmet. I'm surprised the GP5 doesn't get you in under 10lbs total for the gear. Obviously not everyone owns a GP5.
Either way, your input on the weight of safety gear helps to add credibility to the argument for heavier class weights.
With your torsion bars installed I bet your chassis weight falls right in line with most estimates.
I consider myself to be an average demographic of the Rotax/TAG masters class. Over 40, disposable income, around 190lbs.
I have no interest is racing young hot-shoes weighing 145lbs but I also don't want to be at a huge performance disadvantage. After all, I'm racing for the competition and the fun not the large cash prizes.
joseph hollinger
PostPosted: Mon Mar 01, 2004 1:43 am    Post subject: Reply with quote
Okay, last Gatorz race. Kart weighs in at 370. I weigh 165.
Let's say 8 pounds for shoes, driving suit, ribtect, neck brace, helmet,
tee shirt, socks, boxer shorts and knee pads (as you've admitted, five pounds is a little light). Throw in a gallon of gas (6 pounds). So we've got
370 - 165 - 8 - 6. That's 191. Now subtract 20 pounds for ballast and
you've got 171. My original quote said, "closer to 165 - 170". I'm off
by a pound. Not even mentioning there a number of things I could
change on that kart if I was really worried about cutting weight.
That's not exactly what "average" implies. Especially in a situation like
this where the population being averaged includes some very large
people (i.e., morbidly obese) whose overall contribution is
certainly going to drag the average higher. It also completely
ignores the fact that extraordinarily large people (who are
counted in the calculation of "average") are probably never going
to sit in a kart. My guess is that you are really looking for the
median value. What the median value is (for likely partcipants)
is pretty much anyone's guess.
I really think it comes down to some pretty simple stuff. If you want
#190 drivers, and you want them to be able to run any chassis
motor combination, the current rules are fine. If you expect people
to make responsible choices (such as choosing an appropriate motor
for their weight) there's no justitification for the current limits. I'd
rather see a compromise where big people are accomodated by
bigger motors, and smaller people don't have to add #40 to #60
pounds of lead.
Bill Siler
PostPosted: Mon Mar 01, 2004 9:08 am    Post subject: What chassis do you have Reply with quote
Joseph, What chassis and motor combo do you run. 170 is light for motor and chassis. And how do you like the motor package. I am looking for a new chassis and would like to lose some weight in the chassis in the process. I am also looking to move from the Rotax package to a Tag package. The Avanti I have has the new body work I understand that is about 5 to 7 pounds if I change that out. By the way were do you run when you come down to southern California?
Bill Siler
joseph hollinger
PostPosted: Mon Mar 01, 2004 9:27 am    Post subject: Re: What chassis do you have Reply with quote
Margay Brava 1.2/Leopard. I believe it's a 2002 chassis and
uses the old style bodywork.
As for tracks, this year I'm planning on doing more of the Gatorz
races, so Buttonwilllow, Grange, Moran, Willow Spring etc.
I'll probably skip Perris. Also doing some of the SKUSA races, which
means more of the same tracks Smile
I also want to drag the kart up here for Sears Point. We'll see.
Rotax looked good at Buttonwillow a couple of weekends ago.
I'm not sure I'd change if I already had the chassis.
Rob Martin
PostPosted: Mon Mar 01, 2004 12:52 pm    Post subject: Reply with quote
Joseph,
Your numbers and your points are well taken.
I'm not, however, saying I agree that it is the responsibility of heavier drivers to select a motor package based upon the handicapping system.
The idea of TAG is to offer a variety of choices in both motor packages and chassis selection.
Please remember that the national average is based upon millions of samples. The few morbidly obese 300lbs plus samples are offset by the few slight 100lb adult males also included in the sample.
Height is obviously a contributor to overall weight and has not even been a consideration. A true adult kart racing sample would likely not include drivers over 6' 3" (est) or drivers under 5' 3" (est).
The point I'm hoping to make is that an average adult male is much closer to 190lbs than 165lbs.
Unfortunately this difference requires an adjust of some kind to help even the field.
Page 3 of 4
DB time: 0.169984 (38.28%), total time:0.444087, queries:38
