OTK - LB
RLV - SS
SCCA Enterprises - FB
check this out
John Bosanek
PostPosted: Wed Oct 03, 2001 6:15 am    Post subject: check this out Reply with quote
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1013449703
Pete Muller
PostPosted: Wed Oct 03, 2001 6:45 am    Post subject: check this out Reply with quote
I think the Turf-Saver tires pull it all together.
Jan Lapke
PostPosted: Wed Oct 03, 2001 7:15 am    Post subject: check this out Reply with quote
Somebody had too much time on their hands!!!
Glenn Holland
PostPosted: Wed Oct 03, 2001 5:11 pm    Post subject: check this out Reply with quote
Sounds like something that we'll end up seeing in the "Darwin Awards".
Mike Young
PostPosted: Wed Oct 03, 2001 8:00 pm    Post subject: check this out Reply with quote
Where the hell are the brakes?!?
Marshall Martin
PostPosted: Thu Oct 04, 2001 2:32 am    Post subject: check this out Reply with quote
Brakes! What do you want brakes for, that is what you use the guy in front of you for (or whatever gets in your way)
Wayne MacGregor
PostPosted: Thu Oct 04, 2001 3:48 am    Post subject: check this out Reply with quote
I think I'd RATHER be in front of the thing if anywhere! Check out the tailpipe.....I think behind = BBQ. With that "massive" amount of rubber on the ground, I wonder how you set the thing up to go around corners???? Or do you even care?
S. Clark
PostPosted: Thu Oct 04, 2001 5:13 am    Post subject: check this out Reply with quote
He says ..... and go until it runs out of gas . Guess there aren't any brakes .
Rodney Ebersole
PostPosted: Thu Oct 04, 2001 5:55 am    Post subject: check this out Reply with quote
It has a reverse in the burner to slow ya down. Mount it on a good kart and I would give a try on the salt flats.
Ardy Sadeghi
PostPosted: Thu Oct 04, 2001 8:13 am    Post subject: check this out Reply with quote
Atleast he could have used a racing kart and not a yard kart!!
I got this from another karter.. just checkout the sound!!
http://www.jetkart.co.uk/index.htm
Pete Muller
PostPosted: Thu Oct 04, 2001 9:10 am    Post subject: check this out Reply with quote
Check out the photo on the "Technical/Spec" page. Looks like some new, super-secret front end alignment thing going on.
Roy Harris
PostPosted: Thu Oct 04, 2001 2:27 pm    Post subject: check this out Reply with quote
From a road race perspective I don't belive I would want to draft with kart.
Roy Harris
Jimmy Moore
PostPosted: Thu Oct 04, 2001 5:28 pm    Post subject: check this out Reply with quote
That has to be a portable test stand for jet engines. How could you turn it with two rear axles?
DB time: 0.130861 (40.07%), total time:0.326613, queries:37
