MIR Racewear - LB
RLV - SS
DRT Racing - FB
Water Temps
Bryan Scott
PostPosted: Mon Feb 09, 2004 7:59 pm    Post subject: Water Temps Reply with quote
New to water cooled, New to Leopard, What temps should I be running? How do you tell is your running to lean? Im not very sure about reading the spark plug, Any info welcome thanks
Patrick Hubbell
PostPosted: Mon Feb 09, 2004 10:01 pm    Post subject: Reply with quote
120 to 140 degrees F. Use EGT to tune the engine. Take the plug out and look at the piston crown, s/b tan colored like cardbord. Look inside of the header, tan like cardboard. Black = too rich, white = too lean.
Patrick Hubbell
robert pearson
PostPosted: Mon Feb 09, 2004 10:05 pm    Post subject: egt vs h20 temp Reply with quote
patrick,
what about h20 temp. all the tags i have seen use this, not exhaust gas. your advice is always welcome.
thx
scott
Patrick Hubbell
PostPosted: Mon Feb 09, 2004 11:41 pm    Post subject: Re: egt vs h20 temp Reply with quote
robert pearson wrote:
patrick,
thx
scott
The 120 to 140 is H2o. You want to keep it under 140. Egt can be anything from 800 to 1300 depending on the location of the sensor with respect to the piston.
Patrick Hubbell
Jose Rodo
PostPosted: Tue Feb 10, 2004 7:53 am    Post subject: Reply with quote
It's also a good idea to have a thermostat or a heat exchanger www.wildkart.it
DB time: 0.13479 (41.73%), total time:0.323037, queries:38
