KartSport North America - LB
Russell Karting - SS
Tony Kart/Vortex - FB
Axle Hardness...how can I tell???
Goto page Previous  1, 2
Larry Hayashigawa
PostPosted: Tue Sep 30, 2003 9:53 pm    Post subject: Reply with quote
What I don't get is the reason for 50 mm axles.
A 50 mm x 3 mm WT axle is 27% stiffer than a 50 mm 3 mm WT axle.
If stiffness is needed then why not increase a 40 mm axle wall thickness to 4 mm, which has the equivalent stifness of a 50 mm x 3 mm axle.
If less flex (softer) is the objective then why not go with a 40 mm x 2.5, which has the same stiffness as a 50 mm x 2 mm axle.
AH HA, I know! It is a conspiracy by bearing mfg to sell more expensive bearings?
Actually, there maybe differences in performance in all of these axle variations (even mild and hard steel due to differences in the damping coefficient) but what bugs me the most is that every explaination (BS) of why, never has engineering theory to back it up. I believe that most kart manufacturer don't have a good engineering understanding of how a kart works. They just know what works and use trial and error to improve the kart.
This will probably kill the thread.
Tim Lewis
PostPosted: Tue Sep 30, 2003 9:55 pm    Post subject: Reply with quote
Mike Goebel wrote:
I wonder how many times anyone has looked up the modulus of elasticity for different alloys of steel. Because if you did you would see that they vary ever so slightly. Negligible! The most influence comes from the wall thickness. Hardness has no effect either, STOP the bull**** there is no black magic in axles, Ahaaaaaaa, help me.
Mike G.
Mike,
Repeat after me. Stress over strain, stress over strain, stress over strain!
I'm completely on the same page as you. I can't understand how a different alloy or hardness could make a difference. I do know that when I stick a soft axle in my kart it is different that a stiff one.
A friend of mine has a theory that when highly loaded, axles actually work in the plastic deformation area of the curve. It's possible. I would think that we would find more of them bent or breaking due to fatigue that we do if his theory was correct, though.
Jeff Braun came up with some sort of test rig that he tests axles with on his shock dyno. He claimed that there were damping differences between axles. I found that one a little tough to swallow. Damping lends itself to the creation of heat. I've never come off the track and felt I've overheated my axle. If the axle did work in the plastic deformation range, though, then it would definitely make heat, just like a paper clip that you've bent back and forth. This pretty much means damping of one sort or the other.
Like I said before, I don't understand it, but I accept it. The 'What' is a lot easier to explain than the 'Why'
Doug Welch
PostPosted: Wed Oct 01, 2003 5:15 am    Post subject: Reply with quote
[quote="Mike Goebel
.... The most influence comes from the wall thickness. Hardness has no effect either, STOP the bull**** there is no black magic in axles, Ahaaaaaaa, help me.
Mike G.[/quote]
Mike,
You are right on about wall thickness. It controls the stiffness more than any other factor. I have found that if you make them from higher carbon steels, you do get a higher yield strength which makes for a sturdier axle. That is, it will hold up better to impacts and is less likely to bend. Most of the imported axles I have tested are made from low carbon steels, like a 1010 or 1012. They have a very low yield strength and are very prone to bending. An axle made from a medium carbon steel have as much as a 50% higher yield strength and will absorb a much higher impact before bending. So guys, if you go out banging wheels or jumping curbs, you may want an axle made from better steel.
Doug
Gary Osterholt
Site Admin
PostPosted: Wed Oct 01, 2003 8:19 am    Post subject: Reply with quote
Doug,
Does the axle materials influenced by what's called shape factor?
Which takes into account the diameter and wall thickness?
Gary Osterholt
Website Designs - http://www.godesigns.us
Dan Nasser
PostPosted: Tue Feb 05, 2013 7:25 am    Post subject: Let's go to the formulas to settle this one. Reply with quote
Basically the rear shafts should be considered a cantilever load (support on one end and hanging without support on the outside of the tire)
See End load cantilever beams formulae on this easy to read WIKI link:
http://en.wikipedia.org/wiki/Deflection_(engineering)#End_load_cantilever_beams
and:
http://en.wikipedia.org/wiki/Area_moment_of_inertia
see section on hollow cylinder.
The conclusions I get are:
1) deflection of shaft is proportional to downward force on the tire or loading.
2) 50mm shafts are roughly 2.5 times stiffer than 40mm shafts of same thix.
3) To get equally stiff axles, a 40mm needs to be 5mm thick to compare to a 2mm thick 50mm shaft. The 40mm shaft will be much heavier of course!
4) Increasing distance from bearing to hub mounting point by 15%, yields 50% less stiffness. This is why rear wheels have different offsets to their mounting point.
5) materials vary very little in their elastic modulus; which is proportional to deflection, so it seems weird there are soft/medium/hard shafts of the same dimensions? I believe this to be a marketing gimmick.
6) 50mm bearings are much stronger and more rigid too.
Britt Robinson
PostPosted: Tue Feb 05, 2013 8:01 am    Post subject: Reply with quote
Lazarus!
I am a precisional instrument of speed and aeromatics. - Mater
PostPosted: Tue Feb 05, 2013 9:30 am    Post subject: Reply with quote
10 years, is that a record?
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
Jim McMahon
PostPosted: Tue Feb 05, 2013 1:59 pm    Post subject: Reply with quote
Yeah quite a revival alright. I think there's been a few threads since as well. Never ending topic and part of makes karting so interesting.
It's not a gimmick. Although nobody has really been able to conclusively say what is happening you can be sure there are differences in performance on the track. Not talking placebo either.
Take the same brand of axle, same wall thickness but different "stiffness'". Now tap each of them with a metal object to make it ring like a tuning fork.
Sam Zavaglia
PostPosted: Tue Feb 05, 2013 3:08 pm    Post subject: Reply with quote
Jim,
You and Yamaha think a like.
www.samzavaglia.com
Sam Zavaglia
PostPosted: Tue Feb 05, 2013 3:16 pm    Post subject: Reply with quote
The original post was how to tell what we have, answer is either by outside marking like CRG do or by paint color on one inside of axle.
Anyway, more info for debate.
Prodezine Axles
In our experience your axle and seat are the best major tuning tools available to you.
Exclusively sourced from Europe, Prodezine axles offer the widest selection of hardness & lengths to let you fine-tune your kart no matter what the track or application.
Prodezine axle selection criteria:
Choice of length;
1040mm - longer axle adds lateral stability or
1020mm – shorter axle lets the kart roll a little making it quicker through left & right combinations and chicanes.
Pick the one to best suit the features of your track.
Choice of Hardness
Prodezine offers 5 options in 40mm, and 7 options in 50mm diameter from super soft through soft, medium, medium hard & hard up to super hard
A softer axle will loosen up the kart; reduce bogging out of turns; and help overcome increase in track grip.
A harder axle will help grip the chassis up more.
Different steels, tensile strength and yield points in here.
www.samzavaglia.com
Sam Zavaglia
PostPosted: Tue Feb 05, 2013 3:52 pm    Post subject: Reply with quote
That's because the biggest kart variables are the meat in the seat, engine output, tires, track shape and grip. When are these all constant? Can you plug these variables into your theory design computer.
How come race cars keep getting better and better if a theory computer is perfect years ago without the need of 'trial and error'?
The 'best' chassis are the ones that work friendly for most people, which brings in revenue for that company but that does not mean it's the fastest chassis in the right hands. Wink
Anyway back to axles..... Laughing
www.samzavaglia.com
Dan Nasser
PostPosted: Thu Feb 07, 2013 8:33 am    Post subject: hub length Reply with quote
Rear wheel hubs come in different lengths. This should make a big difference in ride stiffness. Is this the sole purpose for the different lengths?
Jim McMahon
PostPosted: Thu Feb 07, 2013 11:20 am    Post subject: Re: hub length Reply with quote
Yes. Typically the rear hubs are used to tune apex-exit handling. Rather than changing track width, hubs can be changed and if conditions dictate then one will go to a softer or stiffer axle when out of hub options.
Page 2 of 2
DB time: 0.160088 (39.32%), total time:0.407112, queries:38
