SoCal Sprinters
DRT Racing - FB
Chewed Up Bead
Jimmy Moore
PostPosted: Fri Sep 14, 2001 5:01 pm    Post subject: Chewed Up Bead Reply with quote
Someone gave me a good set of tires except that they were removed from the wheels with a screw driver. The bead is kind'a chewed up a little. I can't get them to bead because they leak too much and, if I get them to bead I'm afraid they won't hold air very long. Is there a fix for this? It seems a shame to toss them?
Rick Crow
PostPosted: Fri Sep 14, 2001 11:08 pm    Post subject: Chewed Up Bead Reply with quote
jimmy
I had some tires like that, I got a can of brush on bead sealer like the tire stores use and it worked fine. I think I got it at NAPA.
Rick
Todd Bolton
PostPosted: Sat Sep 15, 2001 11:36 am    Post subject: Chewed Up Bead Reply with quote
You can also use a bead of silicon caulk around the wheel/tire.... Put on the caulk and air tire till it beads(without the valve stem) then let dry and go racing.....
DB time: 0.109123 (38.29%), total time:0.28502, queries:37
