2D2W - LB
Brett King Design
KG Plastics - FB
Brake Lines Is There A Difference?
Rob Hogenmiller
PostPosted: Sat Sep 08, 2001 9:53 pm    Post subject: Brake Lines Is There A Difference? Reply with quote
What are my options for brake line plumbing?
and is there a preferred product or competitive advantage with a certain kind?
Rob Hogenmiller
rob@nationalkarting.com
www.nationalkarting.com
[ September 08, 2001: Message edited by: Rob Hogenmiller ]
lynn haddock
PostPosted: Sun Sep 09, 2001 4:11 am    Post subject: Brake Lines Is There A Difference? Reply with quote
Go for the line that offers the lowest expansion rate under pressure.
Jack Burroughs
PostPosted: Sun Sep 09, 2001 5:24 am    Post subject: Brake Lines Is There A Difference? Reply with quote
I allways had good luck with industrial Poly-flo tubing components, the hard tubing 1/4",(cause that's what they stocked at work) matched fittings 450lb. p.s.i. rated. the only thing to remember is to use the correct ferrules, there are several diff.types.
Gary Kozuma2
PostPosted: Mon Sep 10, 2001 6:45 am    Post subject: Brake Lines Is There A Difference? Reply with quote
Good morning Mr. Rob,
Heres' my experience and observation regarding brake lines. Actually, as far as the lines go, I've not seen an issue or performance difference. I would suspect any high quality product will be fine.
I do have 2 experiences where the fittings have failed. In both cases the fittings were the same type, with the ferrel not permanently attached to the end of the line. It was the slip fit compression type. What I've seen is either the line comes out, or the fitting cracks. Either way, your into the hay bales, mowing the lawn or rearranging the barrier.
Be safe, have fun,
Gary K.
DB time: 0.060079 (38.94%), total time:0.154296, queries:37
