| What caused the kart to pull to the left? |
| Uneven weight in the rear (20 lbs too much on the left) |
0% |
[ 0 ] |
| Toe set incorrectly |
45% |
[ 5 ] |
| Chassis bent |
27% |
[ 3 ] |
| Bank (crown) on the track |
9% |
[ 1 ] |
| Takeoff tires suck |
9% |
[ 1 ] |
| Aerodynamic imbalance |
0% |
[ 0 ] |
| Chassis too stiff/not stiff enough |
0% |
[ 0 ] |
| Rear axle too stiff/not stiff enough |
0% |
[ 0 ] |
| Driver can't drive |
9% |
[ 1 ] |
| Total Votes : 11 |
Jeff Sligh
Posted: Fri Mar 15, 2013 6:43 pm Post subject: Pulling left on the straights |
Ran my old 94 Coyote Wide Track Free Roller at Roebling Road for the first time this year in Clone Sit Up 410, and I noticed that on the front straight that the kart was wanting to pull to the left pretty hard, but the kart would go and hold just about anywhere I put it on the track. This kart started off life as a Dirt kart, and I modified the heck out of it to get it down to 36" wide. I had the weights at LF 94, RF 95, LR 119, RR 100, no stagger in the Dunlop tires over 1/32", both front spindles set at the same height, WB 41 1/4" on both sides, and I'm wondering if having the rear weight off that much is what was causing the kart to pull to the left, or could it be something else? I am 6'2" and 230 lbs, and I have moved the seat over to the right about an inch to try to equalize the rear weights out, but I haven't put it on the scales just yet. Getting ready for Kershaw in a couple of weeks, and any suggestions as to setup or why the kart was pulling to the left might just help me to be able to keep up with the pack instead of getting left behind would be great! Thanks,
Jeff |
Randy Mckee
Posted: Fri Mar 15, 2013 10:32 pm Post subject: |
My money is on alignment. But then maybe that chassis just misses the dirt. _________________ Randy
#123 TonyKart - S4 Stock Honda |
Dean Graves
Joined: 11 Sep 2001 Posts: 518 Location: United States, California, Lompoc (Lompton)
Posted: Sat Mar 16, 2013 11:25 am Post subject: |
| What’s the outer circumference of each back tire? |
Matt Dixon
Joined: 21 May 2007 Posts: 532 Location: United States, California, Norcal
Posted: Sat Mar 16, 2013 12:27 pm Post subject: |
Check the sweep while your at it _________________ Matt Dixon
94y Energy Corse/Swedetech |
Jeff Sligh
Posted: Sat Mar 16, 2013 12:46 pm Post subject: |
| Circumference of both rear tires is 33", and I'm not sure what you mean by "sweep" |
Matt Dixon
Posted: Mon Mar 18, 2013 4:54 pm Post subject: |
Sorry for not explaining 'Sweep' Jeff, I was waiting for someone else to go into a long complicated post about it.
In short, it makes sure your front end is lined up with your rear end so you are not 'Crabbing' down the str8. Which might add to your issues.
Im kind of a "generic answer" guy as opposed to a mind numbing complicated answer guy... _________________ Matt Dixon
Jeff Sligh
Posted: Mon Mar 18, 2013 7:05 pm Post subject: |
Ok Matt, I got what you mean now. That is something I am going to have to check. Actually, your short answer gives me more to think about than a long complicated answer would have.
Thanks to everyone who has put up an answer to the poll, except for the one guy who said "Driver can't Drive" LOL! Wasn't much need to vote for that, I already knew that...
Jeff |
