OTK - LB
KG Plastics - FB
Moto Motor Shift Linkage
Goto page 1, 2, 3  Next
Charles Frerking
PostPosted: Fri Mar 15, 2013 6:50 am    Post subject: Moto Motor Shift Linkage Reply with quote
working on fabbing up (I use the term "fabbing" loosly) a shift linkage for the moto motor (CR 125) I just put in my kart, anyone have any creative solutions?
There's the obvious solution, which is throwing a bend in a tie-rod, but has anyone else come up with a better idea? Pictures of said solutions would be great!
Tyson Henry
PostPosted: Fri Mar 15, 2013 8:20 am    Post subject: Reply with quote
Seems kind of silly to do anything other than just put a bend in a long shift rod. Seems to work just fine.
Charles Frerking
PostPosted: Fri Mar 15, 2013 8:28 am    Post subject: Reply with quote
Then I guess you weren't my target audience. I get it, it works, but I'm just seeing if anyone else has done anything a little more "innovative"
Matt Dixon
PostPosted: Fri Mar 15, 2013 8:32 am    Post subject: Reply with quote
No need too, just keep it simple. Put 2 bends in it and if you have to shorten it make sure to cut the right hand thread side in case you nee to rethread it.
If you aren't racing and don't have to pass tech then last month the was a whole bunch of bickering about an air shift do hicky that ultimately fails...
Matt Dixon
94y Energy Corse/Swedetech
Ace Rossi
PostPosted: Wed Mar 20, 2013 8:05 pm    Post subject: Reply with quote
Uhh on the contrary, my air shifter is on and works great! Legal? No, but the way I installed it, I was able to leave the manual shifter intact and the air shifter can be disconnected in a matter of seconds making my kart legal to race! So with that said, I have the best of both worlds!
As for the manual shift arm? Definitely put the necessary bend/s in the arm and run the J-arm in the UP position! Some run it down but the shift pattern is backwards!
Don't know why everyone is negative about playing with an air or aftermarket shifter! As for failing? There's not a lot that can go wrong. Maybe a .50 O ring or a 5.00 belt. I guess you can compare that to a piston ring or a crank bearing that cost a BUNCH more! Yea running an air shifter is surely a risk!
Paul Makarucha
PostPosted: Thu Mar 21, 2013 4:34 am    Post subject: Reply with quote
^ your logic makes my faith in man-kind diminish.
CKR/KZ
CRG/ICA
http://Jaymotorsports.com
Todd Kageals
PostPosted: Thu Mar 21, 2013 9:57 am    Post subject: Reply with quote
What about a cable shifter? I did some research but ultimately bent a rod and it works just fine. I'd love a paddle shifter but as mentioned above, not lega.
Ken Schilling
PostPosted: Thu Mar 21, 2013 11:13 am    Post subject: Reply with quote
DD2's have a cable type shifter, yes I realize it's only a two speed, and it's very problematic.
KISS - use a shift rod which is the easiest and best solution.
Ken Schilling
SKUSA Data Administrator
PostPosted: Thu Mar 21, 2013 7:28 pm    Post subject: Reply with quote
DD2's use a 2 cable system on a paddle. It can also be done with a push/pull single cable. Typically a marine control cable is used. It's called a morse 33C.
The DD2 is probably the simplest aproach. The paddle shift assembly is around $200 and it mounts on the steering shaft under the wheel. You'd just have to fab cable mounts on the engine side.
Can you tell I've been thinking about this?
Benn Herr
PostPosted: Thu Mar 21, 2013 7:48 pm    Post subject: Reply with quote
Sometimes it's fun to be complicated!
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
Mike Goebel
PostPosted: Thu Mar 21, 2013 8:24 pm    Post subject: Reply with quote
NO WAY only $200??? show me the link.
Mike G.
Closet KZ Lover!!!
mfg Technology Centre
PostPosted: Fri Mar 22, 2013 5:08 am    Post subject: Reply with quote
This is the new style the old style is cheaper http://store.nexternal.com/mrp/dd2-paddle-shift-kit---retrofit-p1023.aspx
Then you still need some mics parts so your right a little more than $200
PostPosted: Fri Mar 22, 2013 5:46 am    Post subject: Reply with quote
Mike G.
How about $300?
http://www.shiftmn.webs.com/
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Ace Rossi
PostPosted: Fri Mar 22, 2013 5:52 am    Post subject: Reply with quote
Why all of a sudden is there this much interest in aftermarket shifters? I caught so much flack when I was putting my air shifter on my kart just to play with!
Clark Gaynor
PostPosted: Fri Mar 22, 2013 5:56 am    Post subject: Reply with quote
Wow, Benn! Gotta' love those 250's!!
Nice setup.
Page 1 of 3
DB time: 0.083527 (42.51%), total time:0.196477, queries:38
