JIM SILVERHEELS
Joined: 22 Jul 2006 Posts: 590 Location: United States, Massachusetts, LUDLOW
Posted: Wed Mar 13, 2013 4:05 am Post subject: ASK TJ |
Usually people move the seat forward as an option for push, seems moving the seat up or backwards would rotate the rear of the chassis making the inside tire lift higher and for a longer duration. correct? _________________ Don't get stuck in someone else's discarded chewing gum with your thought process. |
Posted: Wed Mar 13, 2013 6:19 am Post subject: |
I pretty much never move my seat. Two reasons:
1. Factory settings are there to give you the best possible baseline to start from and will make all your other chassis adjustments react the way they are supposed to.
2. My seat weighs like 60 pounds and moving it sucks.
That's not to say it's not a legitimate adjustment. I know some guys who ONLY move their seat to tune.
We've had quite a few instances where we moved the seat up before trying to get higher CoG and get better lift.
I remember one national race in juniors, we were struggling to get front grip so we moved the seat forward. Then I qualified on pole. The next event, the kart was handling poorly again and we moved the seat back, past where we had it originally, and it came to life again.
As with anything in karting, it's a balance you need to find. Move it too far forward and you're just swinging the rear around and not getting any side bite. Move it too far back and you're not generating front grip and the kart is plowing. The factory settings are designed to get you close to that balance. _________________ T.J. Koyen
www.oktanevisual.com
Exprit/Leopard |
Chris Livengood
Joined: 24 Jul 2001 Posts: 2432 Location: United States, Pennsylvania, Da Burgh
Posted: Wed Mar 13, 2013 6:36 am Post subject: |
Moving your weight forward or backward isn't as simple as people like to believe.
If your tire temps are low on one end or the other, it is likely they need mass, as greater loads will increase temperature and increase grip. If tire temps are maybe too high, then removing mass may lower temperature. Depending on the tire, it may increase grip because the tire was greasy in its overheated state. Or this may decrease grip if tire goes below optimum temperate. I have seen very few of the club style tires ever get so hot as to blister, so that makes them harder to read. Some of the softer tires are clearer on what is overheated and under-heated.
Then add in verticle C/G and things get crazy.
In my experience, I prefer to over work the rear tires a bit more than front. This typically required a a c/g a little more rearward, but as TJ mentioned, it can be totally dependent upon track conditions, etc. etc. etc.
Finally, "ASK TJ" is really crappy thread title as it doesn't add any meaningful information for future searches. _________________ http://www.Chrislivengood.net
http://www.Work-Racing.com
http://www.OurZeal.com
http://www.Karting101.com
Last edited by Chris Livengood on Wed Mar 13, 2013 11:09 am, edited 1 time in total |
Ray Lovestead
Joined: 21 Dec 2011 Posts: 156 Location: United States, Colorado, Louisville
Posted: Wed Mar 13, 2013 9:06 am Post subject: |
If you have a track with long fast sweepers and sharp corners, could you not physically move your butt (and upper body) forward in the seat on the sharp corners and lean back on the sweepers to get a chassis combo that works "everywhere" on the track? _________________ "Karting Expert Since 2014" |
JIM SILVERHEELS
Posted: Wed Mar 13, 2013 10:00 am Post subject: EMM |
To get back to the question about the seat. Shouldn't moving a seat up or back make the rea rend rotate better and make a higher and longer duration of lift? of course moving it back takes weight off the front but if it was pushing would it help? i know i have read this somewhere. _________________ Don't get stuck in someone else's discarded chewing gum with your thought process. |
Chris Livengood
Posted: Wed Mar 13, 2013 11:39 am Post subject: Re: EMM |
| JIM SILVERHEELS wrote: | | To get back to the question about the seat. Shouldn't moving a seat up or back make the rea rend rotate better and make a higher and longer duration of lift? of course moving it back takes weight off the front but if it was pushing would it help? i know i have read this somewhere. |
Like Chris said, there's no single answer.
What if you move it back and the front end pushes more because you've moved the weight bias too much? It's a balance. Like I said, that's why there's factory recommended settings for the seat. They'll get you close to that balance.
If your kart was pushing, moving the seat would be one of my last resorts. I'd first tune the 92 other adjustments you can to see if you can get the push out. Seat placement is too touchy and can cause too many variables to be messing with it to tune out simple handling issues in my opinion.
It's valid, just not the first thing I'd do.
Try and watch some of the top Euro drivers in the rain. See where their body leans and that should tell you where you need the seat/weight to go to get the most lift.
http://www.youtube.com/watch?v=lwcPyPTCdaI
Check out right at 22:12 in this video. Fore is trying to get as much lift as possible with his body. _________________ T.J. Koyen
Exprit/Leopard |
Rob Kozakowski
Joined: 05 Apr 2010 Posts: 211 Location: Canada, Alberta, Edmonton
Posted: Wed Mar 13, 2013 12:25 pm Post subject: Re: EMM |
| TJ Koyen wrote: | If your kart was pushing, moving the seat would be one of my last resorts. I'd first tune the 92 other adjustments you can to see if you can get the push out. Seat placement is too touchy and can cause too many variables to be messing with it to tune out simple handling issues in my opinion.
I'd agree 100%. Make no mistake, seat placement is critical, but... within reason. Get it close, and fine tune with the other stuff.
Start with the factory recommendations. If nothing you do really works, or you're miles off and can realistically rule out the driver, then move the seat. If you just need a "little something" somewhere, moving the seat will likely mean needing a lot of something else to compensate.
I remember Anthony Davidson in Formula Super A in Las Vegas back in the late 90's moving his seat out of desperation because they just couldn't make the kart work, after trying pretty much everything else at their disposal over a couple of days. If the top drivers at the top of world karting view moving the seat as an act of desperation, I think there's a lesson to be learned from that. |
JIM SILVERHEELS
Posted: Wed Mar 13, 2013 1:23 pm Post subject: GOT IT |
Got it, will take your advice and leave the seat at factory recco's.. thanks very much guys ! _________________ Don't get stuck in someone else's discarded chewing gum with your thought process. |
Tim Koyen Advertiser
Posted: Wed Mar 13, 2013 1:33 pm Post subject: |
I realize this is TJ's thread, but one more thing with regards to seat moving. I only move the seat when other changes aren't making a difference, or a significant difference. In other words, if the karts not responding, move the seat. Still no response, get a new kart.  _________________ High Quality American Made kart stands. Available direct to you or through one of our many dealers.
www.kartlift.com
www.facebook.com/kartlift |
Chris Parks
Joined: 09 Sep 2001 Posts: 1504 Location: Australia, not USA state,
Posted: Thu Mar 14, 2013 2:17 am Post subject: |
If you make a significant change to a kart and you can't feel the difference the seat is in the wrong spot, either the long CoG is wrong or perhaps the Vertical CoG but you need to fix it. why people get so wrapped up in seeing daylight under a rear wheel has always mystified me, all that is needed is to unload it so the tyre patch has such reduced friction it is ineffective. By lifting the rear too high you significantly load the opposite front and that is the last thing you need. _________________ understeer happens on road courses and usually is pronounced with a British accent. Push happens on ovals and usually is pronounced through a wad of chew. Other than that, I don't think there's a difference - Jim Derrig
Chris |
