SKUSA (non-flash) - LB
Streeter - SS
Can an xxl seat be mounted on a Corsa CH11 chassis?
Dave Rutter
PostPosted: Mon Mar 11, 2013 6:23 pm    Post subject: Can an xxl seat be mounted on a Corsa CH11 chassis? Reply with quote
I'm a pretty big guy and would like to know if it is possible to mount a xxl set on a Corsa ch11 kart. If so, what make of seat? Anything special to know? Thanks in advance for any advice.
PostPosted: Tue Mar 12, 2013 8:52 am    Post subject: Reply with quote
Most times you have to cut and weld the right side seat strut. Then it becomes a matter of getting the strut as close to the engine as possible and still be able to make chain adjustments. Sometimes offset engine mounts can be used. The strut on the left can be bent to get the rest of the width.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Chuck Parker
PostPosted: Tue Mar 12, 2013 11:02 am    Post subject: Reply with quote
I use a XL tall ribtec even with just the XL you have to do as Walt mentioned. I've managed to get a XL ribtec in my Arrow and Wildkart without cutting and moving the strut but I like to move the seat a lot. If you just bend the tabs to get it in there you'll have to bend to move even just a little. Cutting off the strut and moving it over greatly simplifies the installl. You can shim the seat exactly where you want it if you move the seat strut.
DB time: 0.115669 (39.47%), total time:0.293086, queries:38
