Jason Datoc
Joined: 19 Feb 2013 Posts: 6 Location: United States, California,
Posted: Mon Mar 11, 2013 3:38 am Post subject: Front Spindle/Wheel Nut Torque |
| I have an 04 Alpha chassis and the front wheel attaches directly onto the spindle with a single center nut to secure it. What torque should this nut be at? I tighten it to the point where the wheel still spins freely without any side-to-side slop, but the bolt can still be tightened further. Only thing is, the tighter I make it, the more drag there is on the wheel to the point it won't spin freely anymore. Thanks in advance. |
Joined: 03 Oct 2004 Posts: 1413 Location: United States, Wisconsin, Sun Prairie
Posted: Mon Mar 11, 2013 6:57 am Post subject: |
I always tighten until it stops the wheel from spinning freely and then back it off 1/4 turn. _________________ T.J. Koyen
www.oktanevisual.com
Exprit/Leopard |
Michael Taksa
Joined: 25 Jul 2001 Posts: 1391 Location: United States, Massachusetts, Boston
Posted: Mon Mar 11, 2013 8:58 am Post subject: |
| Our tech men wants to be able to spin the spacer on the spindle with force. If it spins freely nut not tight enough, if it does not spin, nut too tight. I whould not tighten it too much and then back off, since you are distorning the bearings every time you do it. |
Jason Datoc
Posted: Mon Mar 11, 2013 4:56 pm Post subject: Nut |
| Got it, thanks guys! |
Dean Graves
Joined: 11 Sep 2001 Posts: 518 Location: United States, California, Lompoc (Lompton)
Posted: Tue Mar 12, 2013 9:50 am Post subject: |
| Castle nut and cotter pin works great. Hand tighten back off one castle. A very small amount of slop is better than bind. |
Joined: 19 Jul 2002 Posts: 4285 Location: United States, South Jerrrsey,
Posted: Sun Mar 17, 2013 7:38 pm Post subject: Spindle mount wheels |
If you leave the nut loose it can loosen even more on the left wheel (causing a deadly hazard) and tighten down hard on the right wheel. I've seen guys smoking the right front tire all the way around the track.
If you can turn the nut until the wheel doesn't spin freely then you need to reduce the width on one of the spacers.
The nut should be tightened down hard on the spindles shoulder and the wheel should then have .010" to .020" axial end play.
Hope that helps,
Yamaha KT100 Service Center
40 years karting experience |
Jason Datoc
Posted: Wed Apr 03, 2013 2:07 am Post subject: |
| Thanks, I'll try that too. |
Jim McMahon
Joined: 07 Apr 2007 Posts: 2657 Location: United States, St. Paul,
