2D2W - LB
Ribtect - SS (non-flash)
SCCA Enterprises - FB
What's the best way to bleed brakes?
Goto page 1, 2  Next
Steve Libretto
PostPosted: Sun Mar 10, 2013 9:43 pm    Post subject: What's the best way to bleed brakes? Reply with quote
Before I get tornado new one for asking a question that has probably been asked before, I searched this topic and came up with 4189 results.... 215 pages of threads.... I looked at each thread in the first 5 pages, and nothing remotely resembled a "how to"
So..... What is the proper way to bleed a brake system? I have Ven05 front and rear brakes ona CRG Road Rebel. Does the reservoir cap need to be put back on and tightened each time you top off the reservoir? Seems like there's got to be a better way then what I'm thinking.
Thanks in advance for any help!
Randy Mckee
PostPosted: Sun Mar 10, 2013 11:55 pm    Post subject: Reply with quote
Not sure about the best way, but I used 2 methods depending on the circumstances. 1) Just replacing fluid, or 2) forcing out air bubbles (or bleeding empty system).
You'll want to get a gravity bleeder. Not exactly cheap, but hard to beat how easy it makes the job. See here:
http://www.accelerationkarting.com/brakebleedertool.aspx
Before starting either procedure:
A. Remove master cylinder screw
B. Screw gravity bleeder on master cylinder and turn knob to allow fluid flow.
C. Fill grav bleeder with brake fluid.
D. Pump brakes to get all air out of master cyl and grav bleeder.
E. Optional: top off master cyl reservoirs.
Method 1 (just replacing fluid). Do steps for each brake caliper.
A. Loosen outer bleed screw on caliper until you see fluid flow. Let it flow until you see clear fluid (new fluid)
B. Tighten bleed screw. Don't use a lot of torque. They break pretty easily!
C. Do same steps for inner bleed screw on caliper. Just let it flow for a second to fill that side of the caliper.
Method 2 (forcing air bubbles out). WARNING: Fluid will shoot 10+ feet.
B. Close the Gravity Bleeder knob.
C. Pump the brake pedal hard (ONCE) and HOLD IT. Fluid will shoot out of the caliper.
D. Loosen the Gravity Bleeder knob to allow flow and then slowly release the brake pedal. This will suck fluid from the bleeder back into the system, rather that sucking air from the caliper. Repeat 1 or 2 more times, and then close the caliper bleed screw.
With method 2 I usually just put a towel over the caliper to keep it from shooting fluid all over.
OK, now for the cheap methods:
Get a mustard squirt bottle with tapered cap or a large syringe. Fill with brake fluid. You can stuff the end into the master cylinder screw hole and then squeeze the fluid thru the system. This usually requires 2 people because you'll need the other person to close the caliper while you squeeze fluid into the system; otherwise air could creep in while you run across to close the caliper screw.
Automotive method, not great but it works: (requires master cylinder reservoir) This one is definitely easier with 2 people and requires some timing. Fill reservoir(s) with fresh fluid. Tell person 1 to pump brake and hold it. Person 2 loosen caliper bleed screw a bit until fluid flows. Let it flow for a while and close the caliper screw. Person 1 should slowly release brake. System will suck fresh fluid from the reservoir, so keep filling it as needed. Repeat until fresh fluid bleeds from caliper.
I hope some of that helps. Let me know if you have any questions.
Randy
Michael Taksa
PostPosted: Mon Mar 11, 2013 9:35 am    Post subject: Reply with quote
VEN05, bleed just like a car. Open rezervoir, fill, slowly press the pedal, open and close bleed screw. Repeat. Do not fill the reservoir all the way up when done, there should be a mark in there.
Gravity bleeding is for "other" systems and I found out, that even with gravity bleeder you still need some type of "pressure" in most of them. Plastic syringe with rubber nipple that you stick into maste cylinder works best.
Tyson Henry
PostPosted: Mon Mar 11, 2013 9:41 am    Post subject: Reply with quote
Ven05 are really easy to bleed.
Just make sure you close the bleed nipple before you let off the brake pedal. I always start pushing the pedal before I unscrew it again also.
Important....make sure you aren't letting the brake fluid drip on the pads.
joseph hollinger
PostPosted: Mon Mar 11, 2013 9:42 am    Post subject: Reply with quote
VEN05? Buy this: http://www.harborfreight.com/mityvac-vacuum-pump-39522.html
Bleeder screws need a little teflon tape to prevent air leaks through the threads when the screws are loosened. Once you've done that, use the vacuum pump and draw out all of the old fluid and air. Fast and easy.
Ken Schilling
PostPosted: Mon Mar 11, 2013 10:00 am    Post subject: Reply with quote
Motion Pro Mini Bleeder!!!
I have VEN05 brakes.
This is the best, easiest and fastest system I know of!!!
http://www.youtube.com/watch?v=ZYvCH69gWTM
Ken Schilling
SKUSA Data Administrator
joseph hollinger
PostPosted: Mon Mar 11, 2013 10:34 am    Post subject: Reply with quote
The receptionist at Motion Pro is H A W T. But otherwise, that looks pretty similar to a wrench and tube. Maybe I'm missing something.
Here's the thing: when you pump CRG brakes, they are going to make a little brake fluid geyser. Unless you do it really slowly. And the geyser is a mess. Buy the vacuum pump and there is none of that. You don't have to open and close the bleeder screws--it's all one step. They use vacuum bleeders on cars for the exact same reason.
Chris Parks
PostPosted: Wed Mar 13, 2013 2:15 am    Post subject: Reply with quote
One of these
http://www.google.com/imgres?imgurl=http://image.shutterstock.com/display_pic_with_logo/569083/569083,1316037570,7/stock-photo-two-plastic-sauce-bottles-brown-and-red-on-white-background-84683479.jpg&imgrefurl=http://www.shutterstock.com/pic-84683479/stock-photo-two-plastic-sauce-bottles-brown-and-red-on-white-background.html&h=470&w=346&sz=35&tbnid=7ZF9hHqiGePyVM:&tbnh=91&tbnw=67&zoom=1&usg=__2ZMuraIt7EHkbIBL8-o6FxRz5Us=&docid=vHcdwVuu6wsQEM&hl=en&sa=X&ei=FkNAUbvdGYXdmAXeuoGgAg&ved=0CE4Q9QEwBQ&dur=3228
Fill with fluid, press into opening of MC, undo bleeder and squeeze. Costs a dollar for a pressure bleeder and works every time
Chris
PostPosted: Wed Mar 13, 2013 5:08 am    Post subject: Reply with quote
Pop the caps on the masters. With a small hose on the bleeders force fluid back to the masters. Flush and bleed in one operation.
http://images-partners-tbn.google.com/images?q=tbn:ANd9GcRh-exLnRpbLTkeGyZvfb9tW6uvBzwvbhz_gfA-WFStYKURmB4W_v5zFXk
PostPosted: Wed Mar 13, 2013 11:29 am    Post subject: Reply with quote
Gravity bleeding is for "other" systems.
+1 This is correct for Ven05, just use DOT4 fluid.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Jimmy McNeil
PostPosted: Wed Mar 13, 2013 6:28 pm    Post subject: Reply with quote
If you have air trapped in the line between the master and the caliper, it would take forever to get it out using this method.
Tyson Henry
PostPosted: Wed Mar 13, 2013 6:56 pm    Post subject: Reply with quote
I have bled calipers/lines from nothing in them with this method. Worked good. Maybe a bit longer than using a vacuum system, but it works.
Jimmy McNeil
PostPosted: Wed Mar 13, 2013 7:13 pm    Post subject: Reply with quote
Your method is moving a very small amount of fluid at a time, if theirs air trapped in a high spot in the line, it may not be enough to get it (for a lack of a better term) over the hump. The air mite move a little, then settle back in the high spot. Not to mention, it takes more time, and is tough to do the rear by yourself.
Dave Holstein
PostPosted: Sat Mar 16, 2013 7:03 pm    Post subject: Reply with quote
I made a gravity bleeder using a 10mm brake line adapter and a brake line tube and some brass fittings, worked like a champ.
Michael Taksa
PostPosted: Sat Mar 16, 2013 7:10 pm    Post subject: Reply with quote
For the other systems the thing in the pictures below works like a charm (you can even get a rubber adaptor for it). Yes I have a gravity bleeder, but for some reson birel brakes wanted to be pressurised.
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.140126 (38.36%), total time:0.365266, queries:38
