JIM SILVERHEELS
Posted: Thu Mar 07, 2013 8:50 am Post subject: Ask TJ |
TJ, if pushing going into a turn I would want to widen the front end as one option, but if the kart pushes at mid turn I would want to narrow the front end. Is the narrowing of the frontend making the two front tires sit down faster and working together to make more grip? Seems logical but wanted to ask our INHOUSE EXPERT, thanks _________________ Don't get stuck in someone else's discarded chewing gum with your thought process. |
Michael Taksa
Joined: 25 Jul 2001 Posts: 1399 Location: United States, Massachusetts, Boston
Posted: Thu Mar 07, 2013 10:45 am Post subject: |
How about slowing down before the turn? )) |
Randy Mckee
Posted: Thu Mar 07, 2013 1:14 pm Post subject: |
Michael that was funny. We're all guilty of overcooking the turn.
Jim, it's more related to how long the inside rear tire is in the air. A skinnier front will keep it lifted longer so you'll have more rotation in the middle of the corner (assuming your turn-in is good). Doesn't really mean more front grip, just better rotation. I try to tune for timing the lift and drop rather than thinking in terms of grip; though I do catch myself saying front or rear grip alot.
Years ago I read a really good setup manual by Ron Sutton. It deals with the mechanics of weight transfer, timing the lift of the rear tire and how to analyze the rate and duration of that lift to maximize handling for various scenarios (e.g., sweepers verses tight turns). I've also noticed that Aussie guy with all of the excellent setup tutorials (can't think of the site at the moment) often refers to rate of lift. Same idea.
OK, speaking overcooking the turn... too wordy. _________________ Randy
#123 TonyKart - S4 Stock Honda |
JIM SILVERHEELS
Posted: Thu Mar 07, 2013 1:58 pm Post subject: Randy |
Randy, I went and watched the Aussie video and he agrees with what you said. I thought it was the two front tires working together quicker. Learned sumtin today, A wider front end will make the rear inside lift quicker but set it down faster. So, a wider rear track going into a turn prevents an initial push on turn in but sets the inside rear down faster through the turn. Thats why narrowing the rear with mid turn oversteer lets the rear stay in the air longer? thanks amigo
If TJ ain't around can we just Ask Randy?[/i] _________________ Don't get stuck in someone else's discarded chewing gum with your thought process. |
Posted: Thu Mar 07, 2013 2:06 pm Post subject: |
If you watch the KRacer vids, you'll hear "rate of lift" a lot.
Any time you increase front grip or speed up the rate of lift (widening the front), you're increasing the speed at which the rear sets down as well. A wider front will lift quicker, but set down quicker. Too wide and you risk oversteer or you risk setting down the inside rear too early, giving you exit push.
It's a compromise to find the best balance of lift speed and turning reaction. You might have to sacrifice a little turn-in to get off the corner reasonably.
So Randy basically nailed it.
Don't think about tuning the amount of "grip" you have, always think of it as the rate of lift. _________________ T.J. Koyen
www.oktanevisual.com
Exprit/Leopard |
Jim McMahon
Joined: 07 Apr 2007 Posts: 2685 Location: United States, St. Paul,
Posted: Thu Mar 07, 2013 2:17 pm Post subject: |
Biggest confusion in karting is made with "Grip" and "load transfer". The rate of lift analysis is a very good way of separating the two. _________________ Live in the midwest and have a TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart?
JIM SILVERHEELS
Posted: Thu Mar 07, 2013 4:47 pm Post subject: TJ |
TJ and Randy, got it, knew what to do, but not why.. thanks again. _________________ Don't get stuck in someone else's discarded chewing gum with your thought process. |
Russ Deubel
Joined: 17 Oct 2004 Posts: 41 Location: United States, New Jersey, Montvale
Posted: Thu Mar 07, 2013 7:34 pm Post subject: |
| Let me get this straight, I'm loose on exit with 2 spacer wide on each side. If I widen the front it should create a push and cure the loose exit. (Theoretically) |
Tim Koyen Advertiser
Posted: Thu Mar 07, 2013 7:47 pm Post subject: |
| Russ Deubel wrote: | | Let me get this straight, I'm loose on exit with 2 spacer wide on each side. If I widen the front it should create a push and cure the loose exit. (Theoretically) |
Just the opposite... _________________ High Quality American Made kart stands. Available direct to you or through one of our many dealers.
www.kartlift.com
www.facebook.com/kartlift |
Russ Deubel
Posted: Thu Mar 07, 2013 7:51 pm Post subject: |
| Got it,amazing what happens when ya read it the rite way. Thx |
Posted: Thu Mar 07, 2013 8:01 pm Post subject: |
Wider doesn't always = understeer on exit.
Wider on front usually = better turn-in, but if you get too wide, it'll lift the inside rear too quickly and set it down almost immediately, causing the kart to sit flat and push off the corner.
Widen the front to get the kart to rotate quicker at turn-in. Narrow it to slow down the rotation.
Understeer on exit caused by an excessively wide front is a case of being way out of the ballpark on your front width. It's a strange side-effect that isn't the norm for what a wide front would do.
The short and sweet of it is, don't try and fix a handling issue (in your case, exit oversteer) with another counteractive handling issue (inducing understeer on exit by over-widening the front track). _________________ T.J. Koyen
Exprit/Leopard |
Randy Mckee
Posted: Fri Mar 08, 2013 12:33 am Post subject: |
Russ, Yes, your theory as originally stated is correct. Wider front will create faster lift and drop of the inside rear tire. Since it is (in theory) dropping faster as you transition toward the exit of the turn, both rears on the ground create more exit grip. Doesn't apply to all situations -- as TJ said, "too wide" can cause other issues -- but you did grasp the idea. _________________ Randy
Russ Deubel
Posted: Fri Mar 08, 2013 7:10 am Post subject: |
| Thx,Randy. Getting the concept. |
Chris Livengood
Joined: 24 Jul 2001 Posts: 2432 Location: United States, Pennsylvania, Da Burgh
Jim McMahon
Posted: Fri Mar 08, 2013 9:31 am Post subject: |
| Chris Livengood wrote: | | The guys I've talked to who are good at this no longer talk about oversteer or understeer, they simply talk about lift duration and lift amplitude (using various terminologies). In my experience, these characteristics encompass all of the many handling ailments. |
Only thing I don't like about this terminology is that it puts too much emphasis on "lift" when really what you are looking for is "unloading". Lift is easier to determine though. _________________ Live in the midwest and have a TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart?
