KartSport North America - LB
KG Plastics - FB
Kart/Stand Protection
Keith Burnett
PostPosted: Fri Feb 22, 2013 6:33 pm    Post subject: Kart/Stand Protection Reply with quote
I have a double stacker kart stand. What is the purpose of wrapping the horizontal bars in rubber/foam? To protect the kart? To protect the stand? To keep the kart from sliding/moving so easily?
Also, what is the "best" material to use? I've seen some type of black hose and pool noodles.
Any info/advice is appreciated.
Keith
Spencer Uzri
PostPosted: Sat Feb 23, 2013 7:47 am    Post subject: Reply with quote
I went down to the local Ace HW store & bought some braided hose. I cut it lengthwise (which takes some time/effort because it's thick) in order to be able to wrap it around the tubing & secured it with zip ties. It's just a way to prevent the stand from marring the chassis.
Tim Koyen
Advertiser
Advertiser
PostPosted: Sat Feb 23, 2013 10:31 am    Post subject: Reply with quote
The purpose of the hose is to protect both the kart and the stand. Imagine how powder coated metal against itself would grind down while riding in a trailer?
I recommend rubber air/water hose for this job. It lasts longer than pool noodles and it affordable. For 1 1/4" square tubing, which is what double stands typically are, I use 1" I.D. I make kart stands for commercial use and this is what I put on them. If you can't find it locally, an industrial supplier like McMaster-Carr has it online.
www.kartlift.com
www.facebook.com/kartlift
Keith Burnett
PostPosted: Sun Feb 24, 2013 8:36 am    Post subject: Reply with quote
Thanks for the info...
Jason Bane
PostPosted: Mon Feb 25, 2013 8:30 pm    Post subject: Reply with quote
On a couple different stands, I always had a problem with the rubber hose or padding coming loose, wearing down, zip ties breaking, etc. I took a piece of 1" pvc, and cut it to match the length of the kart stand rail. I then slowly heated it up in the oven with tinfoil underneath. Once it got flexible, I cut it with a razor knife down its length, gently worked it over the pipe (using welding gloves)and held it in place as it cooled/hardened. It worked pretty good. It has held up for 2 years now, and the PVC does not mark the underside of my frame.
Jonathan Gih
PostPosted: Wed Feb 27, 2013 2:03 pm    Post subject: Reply with quote
I find that old mountain bike tires work best. Wide enough to cover the bars and enough cushion to not damage the chassis or stand.
2012 Tony Kart EVRR - 2Wild Karting
IAME Leopard - Tru Tech Racing Engines
Tim Koyen
Advertiser
Advertiser
PostPosted: Wed Feb 27, 2013 4:07 pm    Post subject: Reply with quote
This is a clever idea. But doesn't the kart slide easily on the pvc?
As a side note: Once, years ago in a previous life, I toured a hot tub factory. I was amazed at how they warmed up pvc pipe in a hot box and could easily bend it around the curves and contours of a molded hot tub. I'm still looking for something to build using that idea!
www.kartlift.com
Mark Erpelding
PostPosted: Wed Feb 27, 2013 5:19 pm    Post subject: Stand Reply with quote
I just went to NAPA and got some 1" or 1 1/4 can't remember now automotive heater hose.. Slit it and held it on with jip ties.. They brake every once in a while but not to often.. Don't use Harbor Freight zip ties they do not last.. I bought a big bag at lowes (500) reasonable and they hold up good.
We spend our money on Racing, Whiskey, and Women ~ The rest we waste!
Jason Bane
PostPosted: Wed Feb 27, 2013 7:12 pm    Post subject: Reply with quote
It does, but it works perfect on my Kartlift Pro. I have a plastic rear bumper so the back doesn't move, so the front just needs to support the weight, no movement thanks to a great lift design..... Wink
Mark Erpelding
PostPosted: Tue Mar 05, 2013 3:57 pm    Post subject: Kart stand Reply with quote
I was always thinking about takeing mine down to the local truck spray in bed liner guy and have them mask up the top rail and shoot it when they are doing a truck bed. I bet if you were flexible on how long they had to get it done they would do it reasonable. Just don't choose one that is super hard to the touch. I would prefer the stuff that is a little rubbery. And the guys around here do it in colors, So it would make your stand reconizeable. A plus when you go to a large event and there is a bunch setting around
DB time: 0.141808 (40.63%), total time:0.349029, queries:38
